Event Coverage Official 2016 Meltdown Drags Thread - What are you doing to get ready?
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Nov 23, 2015.
  1. Tickety Boo
    Tickety Boo
    from Wisconsin
    I have been using Hy-per Lube, says that it contains no Anti-freeze and is safe for all types of race tracks.
    Wanted something to lube the electric water pump.:rolleyes:
    The only bad thing is, it has discolored my fast orange engine paint around the gaskets o_O
    rawcjw19, Dog_Patch and powrshftr like this.
  2. powrshftr
    powrshftr
    What,you mean it turns the heads aluminum color...?;) lol
    30dodgeboy likes this.
  3. powrshftr
    powrshftr
    Norb,that motor looks su****iously like it's in a dyno cell....Spill the beans!:)
    Scott
  4. saltflats
    saltflats
    from Missouri
    Who has time to paint?
    Looks like a track dyno cell to me.
  5. powrshftr
    powrshftr
    Also,got the old,hacked up wiring harness out from under the dash today,cut the seat brace and made up an adjustable piece,got the new harness in and about 75% terminated,pulled both seats and the carpet out to mess with the tunnel to make sure we had plenty of room for the shifter in this thing.
    Had something to eat,and going to head back out to finish the wiring and get the seat and shifter squared away.
    Pick up the motor Monday,should have the tank,pump,filter,regulator,and all the plumbing done Friday.
    So far so good....
    Scott
  6. Deuced Up!
    Deuced Up!
  7. Tickety Boo
    Tickety Boo
    from Wisconsin
    Dyno Cell ?
    Only got Cheese :D speedy.jpg
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    I wish they were Aluminum heads:rolleyes:
    Under the fuel pump block off plate, you will see the gray A body cross member.
    Don't need the Dyno sessions or the better heads yet this year, Just going to drive on by through the smoke you
    make, trying to get 722 pretty ponies to the ground. :)
    Keep the turn signal on so I know where you are.:p
    30dodgeboy, loudbang and 55belairx2 like this.
  9. Okiedoker
    Okiedoker
    from Wisconsin
    All-
    A very important "Know Before You Go" e-mail was sent tonight to all registered racers. Please check your e-mail and take the time to read it.
    It contains all of the times of the event and other important stuff such as we have a designated parking areas for Mustangs...ha-ha!
    Have a good night fellas....23 days! Can't wait!
    30dodgeboy and loudbang like this.
  10. Zettle Bros.
    Zettle Bros.
    23 days before the Okie Doker gets beat like a redheaded stepchild.
  11. Okiedoker
    Okiedoker
    from Wisconsin
    Lots of hostility Zettle... Feels to me like you have a little Okie envy... I understand...
  12. powrshftr
    powrshftr
    Norb:
    You're 101hp north of what we made....Well....I have a confession to make.
    That was actually somebody else's stroked 410" Windsor on the dyno that day.
    I knew it was going to make insane numbers,so I hung around the shop and had Fred change some info on the dyno printout to read like it was my motor making all that steam.He thought it was hilarious.
    By the way,I didn't have the money to run mine on the dyno,but he figures my motor should make a solid 475hp.
    I wish I could have seen the look of panic on some of your faces!lol!621hp!Baaahaaahahahahahaaaaaaa!!!!![emoji16]
    Scott
  13. Okiedoker
    Okiedoker
    from Wisconsin
    Scott-
    Whew...I was worried...now I have a chance. Thanks for giving me some hope.
  14. powrshftr
    powrshftr
    Kind of a cruel joke to play,but I couldn't keep a straight face any longer...lol
    Scott
    Okiedoker and Tickety Boo like this.
  15. 55chieftain
    55chieftain
    What are you solid axle guys running for toe-in? I have mine at 1/8 ?
    I would leave it at 1/8" toe in . as try to get quite a bit of caster as least 6 degrees.
    Falcon Gasser likes this.
  16. Dog_Patch
    Dog_Patch
    I still don't believe you o_O its probably closer to 800HP and you are luring in unsuspecting SBC owners.
    Tickety Boo and powrshftr like this.
  17. Dog_Patch
    Dog_Patch
    I'm running 1/8th toe and 14 degrees of caster.
  18. 55chieftain
    55chieftain
    I guess the faster you go the more caster you really need, i'm figuring on 125 in the 1/4 . i'm between 4 and 5 and was debating on to put the 4 or 8 degree wedge I have to put in. May just go with the 8 wedge.
  19. saltflats
    saltflats
    from Missouri
    I don't fast enough to worry about caster in my car only the ones under my tool box.
    racer-x and powrshftr like this.
  20. enloe
    enloe
    from east , tn.
    Couple of pics of saltflats car from the Hot Rod Reunion.
    Tons more pics in the thread linked in my signature.
  21. Dog_Patch
    Dog_Patch
    I think 8 or 9 is plenty. The issue I had was that raising the rear of the car to get tires to fit etc, was eating away at the little caster I had last year so this year, went overkill. Its steady and straight but lazy as hell in a sharp turn.
  22. stupesnova
    stupesnova
    from wisconsin
    Just read the "know Before You Go" and it says NO P***ENGERS! Hope they make an exception for Carly or she may have to go alone!:eek:
  23. Zettle Bros.
    Zettle Bros.
    Guess the Hairy Hauler will have to go solo this year.
  24. bigslim55
    bigslim55
    Zettle, you called it! Front parking light housings weren't grounding to the turn signal buckets... S****ped a lil paint off & it was ****er! It's nice, brakes lights & turn signals work perfect with headlights on now!
  25. saltflats
    saltflats
    from Missouri
    You going to need them head lights to see where all those Chevy,Pontiac and Mopar's whent.
    55belairx2, Tickety Boo and bigslim55 like this.
  26. bigslim55
    bigslim55
    Scott, you better tell Your dad to bring that bad boy to the Meltdown! That's pretty sweet!
    powrshftr likes this.
  27. bigslim55
    bigslim55
    Yeah James your probably right, I'll need them headlights to see all them tail lights at the other end of track... Maybe someday I'll be able to drop a Cleveland in her & play in your yard...
  28. saltflats
    saltflats
    from Missouri
    No shame there Jim. I have seen my share of tail lights and still seeing them.
    But that's okay with me it's all about the fun one haves with what they got(and I ain't got much)
  29. Tickety Boo
    Tickety Boo
    from Wisconsin
    Playing Possum o_O Bet he still has that grin on;)
  30. Okiedoker
    Okiedoker
    from Wisconsin
    They will in your instance. The management at Byron is the best...we all know that. They will let you take a p***enger as long as you are running a partial p*** or on the slower side. They just need to cover their you know what.
    stupesnova and Falcon Gasser like this.
