Technical What radiator cap for 53 Ford 239 ?
Discussion in 'The Hokey Ass Message Board' started by Brians53vicky, Jun 29, 2016.
  1. Brians53vicky
    Brians53vicky
    from Monroe, MI
    Whats the correct lb radiator cap for a 239 flathead in a 53 Ford ?
    Thanks !
  2. nevrDUN51'
    nevrDUN51'
    from Nashua, NH
    4lb
    Extra deep neck.
    Available from shoeboxcentral.com
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    My new 1951 239 flathead radiator came with a 12lb cap.
  4. AVater
    AVater
    Pressure capability more likely dependent upon water pumps. 4 lb more like old spec pumps.
  5. Russco
    Russco
    from Central IL
    I can't remember the application but there were a few options available with the deep neck. If I recall correctly 1 was a tractor and 1 was a foreign car that had a 7 lbs cap. If you have a good radiator ( been re- cored ) you can probably get away with more pressure than the stock cap.
  6. Rusty O'Toole
    Rusty O'Toole
    The rad may take more pressure but will the heater? I usually put a lighter cap on an old car than it came with stock, to ease the pressure on the rad, heater, hoses and pumps.
    Packard is another car with a deep radiator neck, that takes a special cap.
