Technical The Painting at home in the driveway or garage thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Sep 15, 2014.
  1. taildragger1957
    taildragger1957
    Thank you. Im following your ford build. Really digging what your doing voodookustoms
    voodookustoms likes this.
  2. bostonhemi
    bostonhemi
    Here is my 34
    Tow Truck Tom likes this.
  3. voodookustoms
    voodookustoms
    Thank you!
  4. manyolcars
    manyolcars
    What are brand names and sources for supplied air hoods?
    Which do you like?
  5. Blue One
    Blue One
    from Alberta
    I have an Allegro 9901 Full Face Mask for Supplied Air Respirator
    It fits nice and is a quality unit.
    I also have a bunch of peel off visor protectors that are made for it and work well.
  6. manyolcars
    manyolcars
    Thanks! $232 on Amazon
    What else?
  7. manyolcars
    manyolcars
  8. Blue One
    Blue One
    from Alberta
    I have the hobby air turbine to supply the breathing air to the Allegro mask . The hobby air masks are poor quality.
  9. 57 Fargo
    57 Fargo
    I'm currently in the process of painting my off topic truck in my Quonset with a gravel floor, far from a show truck but more than a respectable job!
  10. manyolcars
    manyolcars
    Thanks Blue one. Can you recommend one system?
  11. Blue One
    Blue One
    from Alberta
  12. Blue One
    Blue One
    from Alberta
    chiro likes this.
  13. manyolcars
    manyolcars
    The value of my lungs?? HAHA Too late! The doctor says a loss of 25% capacity. Yeah, doc, I could have told you that. Imron, 1975. I wore a mask but learned later it had the wrong filters . I'm getting old so it wont matter much longer but I definitely want to keep it from getting worse. I had been looking at the one you suggested on ebay. A credit card is a dangerous thing :) Thanks!
  14. Blue One
    Blue One
    from Alberta
    True enough for the credit card being dangerous.
    One of the things that bothers me the most with this whole painting respiratory protection thing is what you see on all of the TV shows from Foose on Overhauling on down the list.
    What I mean is that you never see the so called pros ever using much more than a cartridge respirator.
    Mind you they are spraying in a downdraft booth but still....
    Surprises me somewhat although I know that TV shows are a long way from reality :D
    I am expecting to do fine in a garage booth with the reduced over spray that my turbine spray system will produce.
  15. K13
    K13
    The real world is not much different. I would be surprised if 50% of the painters I see wear supplied air systems. Thankfully the majority of the ones that do are the younger painters so it may be improving.
  16. Great thread! Hopefully later this year I'll get to the point of painting the 63.5 Falcon in my avatar.
  17. jakesbackyard
    jakesbackyard
    from ND
    image.jpeg image.jpeg image.jpeg Painted the front end parts to the "A" yesterday.
  18. aafc1
    aafc1
  19. aafc1
    aafc1
  20. willys36
    willys36
    Here are the two most recent paint jobs. This is the fanciest job I have done; epoxy white sealer, pearl white intercoat, 3 coats House of Kolor lime gold candy, 3 coats clear, all catalyzed urethane. Bob Coslett did the striping, I have never got the hang of that.
    Painted my grandson's '59 Elky urethane Chrysler Deep Water Blue metallic pearl,
  21. lowcoe
    lowcoe
    Here's a start on my first vehicle. Owned for 30 years. Bought it with paper route monies and help from my folks. Parked it under a tree in Tacoma after the loosey goosey steering box locked up when I gunned it out into traffic and I hit a parked car. [​IMG][​IMG]
  22. Pooch
    Pooch
    from Oklahoma
    I have been painting a lot in the last few weeks 13690770_1381602241855404_3802785895878228058_n.jpg 14064211_1411450735537221_1217552602292203660_n.jpg 14046041_1411450505537244_1206359610624833439_n.jpg 13781776_1381602285188733_4116931233761105528_n.jpg 14238107_1426647777350850_7605612444192665281_n.jpg
  23. Blue One
    Blue One
    from Alberta
    Nice work to be sure however the spirit of this thread is painting at home without the fancy spray booth.
  24. Blue One
    Blue One
    from Alberta
    I like it. I see that you are doing what I intend to do. D**** everything with plastic and go at it.
    I installed an exhaust vent and I'm building a filter box for the industrial snail cage blower that I have.
    They really move air.
    That will take care of overspray which there should be less of with the HVLP system.
  25. Ulu
    Ulu
    from CenCal
    I keep wondering if I should spray with the gun I have and already know well, or if I should go buy an HVLP rig.
    I'm a hobbiest, so not painting too much.
  26. Ford blue blood
    Ford blue blood
    I'd stay with what you have. I'm in the same boat, bought a new HVPL gun but just don't trust myself with it. Use it for jamming so far. Still not comfortable with it. I too am a hobbyist so the infrequent painting just doesn't give me much practice with the new gun.
    Tow Truck Tom and loudbang like this.
  27. Blake 27
    Blake 27
    Put up a cheap canopy on a slab,screens in one end and a fan in the other. Sprayed early in the mornings. I only had a couple bugs (re-sprayed) It came out pretty good for my first paint job in forty five years. DSC05917-001.JPG DSC06037-001.JPG DSC06070.JPG DSC06938-01.jpg
  28. K13
    K13
    If you don't paint much then you probably haven't really developed any insurmountable habits painting with your old gun. HVLP's will save you a ton on materials which are not cheap these days. You just have to be aware that more paint is actually making it to the surface (which is the idea of painting) with an HVLP and adjust your speed accordingly.
    6-bangertim, Blue One and loudbang like this.
  29. Sporty45
    Sporty45
  30. Ben38
    Ben38
    from Minnesota
