Hot Rods What radiator to use with a Anglia
Discussion in 'The Hokey Ass Message Board' started by 68l78, Jun 9, 2016.
  1. 68l78
    68l78
    from Minnesota
    Looking for a nice period correct looking radiator for my Anglia. Anyone have at suggestions ?
    Thanks !
    [​IMG][​IMG]
  2. mcsfabrication
    mcsfabrication
    My car is all stock original tin and I tried a cheep aluminum one from Speedway. So far, so good. I've got a ZZ-4 crate motor and running air. Spal 16" fan (puller) with the Spal controller. 180 stat. Runs 180 idling. Runs 180 on the highway. Air on / off. I would recommend. Has a few thousand miles so far.
  3. 68l78
    68l78
    from Minnesota
    Which speedway one did you go with ? As far as dimensions.
    Did you mount on top of frame rails or go inbetween ?
  4. Willys Jeep. They got used in a lot of things back in the '60s will cool most small blocks and if all it has to do is cool it for 1320 feet you are golden.
  5. I put an early Mustang in my buddies Anglia. Cheap to buy as a reproduction. Nice brackets to make mounts off of. And you can get the lower outlet on either side.
  6. mcsfabrication
    mcsfabrication
    The Speedway one is part# 917-5161. 16" wide x 26" tall. You have to put a fill neck on it, the one I used was available from them then, but I don't see it listed anymore. They do show one to splice into the upper hose (1 1/2") that should work.
    I mounted mine on top of the ch***is, made some brackets off the perforated side rails of the radiator.
    It lists it at $299.99 now, but I'm certain I did not pay that much, probably 4 years ago. But it works.
    I can send pictures to your e-mail, but still can't figure posting pictures on here.
  7. blue 49
    blue 49
    from Iowa
    003.JPG Here's an early Mustang in my Henry J.
  8. jimmy six
    jimmy six
    Falcon...before the Mustang..
  9. 68l78
    68l78
    from Minnesota
    Ended up buying a radiator for a 65 mustang. Fits great! Thanks guys
    [​IMG][​IMG]
  10. hotroddon
    hotroddon
    They are basically the same - My 63 Falcon has a 65 Mustang radiator in it - Direct bolt in, can't tell the difference :)
