1952-59 Ford Mini spool 1956 Fairlane
Discussion in 'Off Topic Hot Rods & Customs' started by Falkenracing, Jul 7, 2016.
  1. Falkenracing
    Falkenracing
    Hello. I want the wheels on my car connected so I can do them nice two wheeled burn outs until I transplant a 9" rear in to the car. Was first thinking of welding the spindel gears together. but then I started to have second thoughts, it might be nice to be able to return the stock rear back to just stock. So now I wonder, before I tear anything down, is there a mini-spool from another ford that will fit a 1956 fairlane rear?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Texas57 likes this.
  3. Texas57
    Texas57
    Listen to Jeff...bad idea! Your car won't want to go around corners.
  4. Falkenracing
    Falkenracing
    I have driven cars with welded rears before and lived. Not many Explorer/ranger around On this side of the pond (located in sweden) so the only thing I want to know, would it fit?
  5. bobss396
    bobss396
    I've driven spools in stock cars, they are really not for street use.
  6. Falkenracing
    Falkenracing
    Well, be that as it May. Do the spool for the 9" axle fit the 56 or not?
  7. 56longroof
    56longroof
    I don't think it will. You'll have to find a 57 and up rear end for that.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    No,the 1949-56 Fords had a Dana 41 rear end no parts interchange with the 9" rear. If you read the link I sent you the 8.8" was used in a lot of other Fords maybe something else will be more common where you are.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    I ran 1/4 mile dirt back in the late 60's guys would weld up the rears in pre-1957 Fords thinking it was an advantage they usually ended up breaking I never did and came off the corners better and beat them and never lost a rear.
  10. bobss396
    bobss396
    Lots of guys with GM rears welded the spiders when I raced. You'd be on the track... smell hot gear oil and sure enough, someone would lose an axle when it let loose.
  11. 57Custom300
    57Custom300
    from Arizona
    Waaay back in 68 I welded the spiders on my 56. Didn't last very long.
  12. DIYGUY
    DIYGUY
    from West, TX
    My son and I ran a pinto on dirt, tried and tried a welded rear and always resulted in DNF. Then I found out that a spool for a 9 in will also fit a 8 in, and that's what we ran until we changed cl***es. Still won't help with a 56 unless you change the rear.
  13. fordsbyjay
    fordsbyjay
    from Lafayette
    I ran a welded 8" in my Pinto for a lot of years. Eventually the side gears cracked so I put a mini spool in it. They are cheap. If you don't have access to a mini spool weld it up just knowing that at some point it will fail.
