Projects 1928 Chevy Coupe
Discussion in 'The Hokey Ass Message Board' started by squirrel, Jul 2, 2016.
  1. A Chitty Chitty Bang Bang reference.... this place NEVER stops surprising me. Well played.
    tb33anda3rd likes this.
  2. A boat tail speedster WOULD be cool... just sayin'.
  3. squirrel
    Probably out of reach, with my limited woodworking capabilities....
    els likes this.
  4. pat59
    pat59
    Ah just buy an old wood boat and cut out whatever don't look right. :)
    Hansa1100 and tb33anda3rd like this.
  5. Moondog13
    Moondog13
    There's always fibergl***! :D
  6. Just how far back is that axle bent?!?!?!
    squirrel likes this.
  7. squirrel
    As if there were any wooden boats around here!
    I got the clutch out. It was kind of stuck from the rodent rust. And I got the engine to spin over freely. The lifters were mostly stuck, once I got them all "up" it turns pretty easily. I've been working them up and down, and got 5 of them out and lubed. The faces look ok, mostly shiny still, so I'm not too worried about rust scale on the cam. I also disconnected the oil line to the filter, hoping that oil will eventually squirt out of it....no luck so far. And under the distributor cap was the rotor...but only one point...the other is MIA. The first part I know I'll need to buy to get it running.
    oh yeah...the little chunk of carbon in front of the spark plugs is part of the throwout bearing. Oops. 20160707_185323.jpg 20160707_180626.jpg 20160707_170217.jpg
    els, kiwijeff and Tim like this.
  8. LostBoy
    LostBoy
    My grandfather had either a 27 or 28 Chevy parked in an old derelict chicken coupe since before I was born. It was ghostly, but the solid wheels always caught my eye. It's amazing how something so insignificant can impact a young mind. He used to tell me that one day he would pull it out, but it didn't move till after he p***ed. Anyway good luck with it. I would love to get working on something like that, even if like you say it's just to learn how things were done back then.
  9. Babyearl
    Babyearl
    Just enough to change the wheel base for deep staging with roll out advantages. That should get your brain storming started. New ride??
    Nailhead Jason likes this.
  10. bobss396
    bobss396
    It was a stock car.. shorten the WB on the left side, goes into the corners easier.
  11. squirrel
    I don't know what the car hit, but the left front fender and running board were missing, the right side stuff was sill on the car. I guess it might be related. Looks like the axle is bent just inboard of the spring, and also might be twisted outboard of the spring. Might need a replacement, if I get that far.
    I piddled with the engine some more...got all the lifters out, cleaned, lubed, and back in. Freed up the rockers and lubed them, and put them back on, and adjusted the valves. Some of the lifters even spin! when I crank the engine.
    Also I pulled the distributor, and spun the oil pump with a drill, and got it pumping.
    Time to investigate the carb, and maybe order some points.
    els, kiwijeff and LostBoy like this.
  12. Watching, this is cool, thanks for taking the time to post!
  13. ClarkH
    ClarkH
    I love this kind of stuff! Add my vote for speedster.
    LostBoy likes this.
  14. squirrel
    A little more progress, I had been squirting a bit of PB blaster and oil into the cylinders....hoping to get the rings to do their job. After I got done with just about everything else I could do, I decide to see if there was any compression, by holding my thumb over the spark plug hole while cranking the engine (by hand). #1 didn't seem too hopeful, but #2 and 3 had some action. 4 is kind of hard to reach. So, I added some more PB and some ATF, and cranked some more, then put the spark plugs back in, one at a time. And it acts like it's getting compression. # 1 seemed to come to life, then as I put the rest of the plugs in it got more difficult to crank. Now it gets hard to turn every 180 degrees, like it should.
    I ordered a set of NOS delco points on ebay, it helps to get a good deal if you know the part numbers better than the seller knows the application...$8 vs $25.
    els, BradinNC, Stogy and 3 others like this.
  15. bchctybob
    bchctybob
    Yer gettin' there.... It'll be started up before you know it. That was some heavy rodent **** in that clutch. Had your Hantavirus shot?
    Don't you just love getting a true eBay bargain! I did the same with Corvair spark plugs and oil filters - about 10 cents on the dollar when compared to what the Corvair parts places wanted.
  16. squirrel
    I discovered that there's an Autolite plug that is supposed to replace the old AC plugs in the early Chevys...fits Model As, so you can get them for a couple bucks apiece. Research pays off.
    els likes this.
  17. 36brothers
    36brothers
    Love it, just for fun.....
  18. Black Panther
    Black Panther
    from SoCal
    Following along....looks like a neat project. I did the research thing and got US made parts for cheap on Ebay...a NOS 50s made front wheel bearing for my Cadillac for $13..and a 60s NOS Standard iginition switch for my T Bird... $8. Beats buying Chinese **** for many times the money.....
    Good luck with your Chevy....the accident probably parked it years ago....not the motor/trans..
  19. RichFox
    RichFox
    I use adapters so that I can use 14 or 10 mm plugs. Think I got the 14s from Jim Bireliy and the 10 mm from ERC racing fuel. A lot of 10mm plugs around for motorcycles so I like them. Little cold for what you are doing I think.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I'm gonna sit on the sidelines and keep my mouth shut and just wait to see what direction this build takes.
    There's no doubt in my mind it will be a interesting thread. HRP
    enloe and kiwijeff like this.
  21. squirrel
    I hope it's interesting...I'm sure learning a lot, so far....
    els and HOTRODPRIMER like this.
  22. Binger
    Binger
    from wyoming
    I am not sure how interchangeable your '27 parts are with my '30 stocker sedan. I know things changed with the introduction of the six in 1929. I have a few parts including a front axle from a '30. Let me know if you are looking for something specific as you decide what direction you are going.
    kiwijeff and squirrel like this.
  23. squirrel
    Thanks! Looks like the axles is the same from 1927 to 1929, but 1930 is different (no brake lever mounting point is one difference)
    els likes this.
  24. Binger
    Binger
    from wyoming
    The one I have is complete with the brake drums and so on. I can take a few pics and see if it may work. However I don't think the Disc wheels will work with the '30 set up. they take 19" wires. I have some of those too.
  25. squirrel
    The disc wheels I have are trashed and incomplete, I was planning to use different wheels.
    els likes this.
  26. Binger
    Binger
    from wyoming
    The wheels on my car are 6 lug which makes them a little different than a lot of wheels you find. Keep us posted. I am interested to see what direction you are going to go.
  27. squirrel
    I poked around in the transmission today. When I got the car, the trans was full of water, and stuck in gear. I pulled off the top cover, and pried the gear into neutral, and the wheels were then free to turn. I also drained the water, and what little heavy oil there was in it. When I removed the transmission, I was able to turn the input shaft, which surprised me. Today, I took it apart, and cleaned the parts in solvent, and s****ed off the few chunks of rust on the gears. I put it back together, it seems to be in reasonably good condition. I expect it will make some noise, and it might want to jump out of 3rd, there is quite a bit of wear on the splines where it engages (inside of 2nd gear, and the input shaft gear, aka main drive gear).
    A few pictures.
    20160703_101051.jpg 20160710_100720.jpg 20160710_115603.jpg 20160710_124322.jpg
    and video...
    els, bct and 1-SHOT like this.
  28. bchctybob
    bchctybob
    Damn Jim, that first picture looks like a Koi pond, complete with clusterfish! Watch, it will probably work just fine!
  29. seb fontana
    seb fontana
    from ct
    Little bigger version of a Crosley trans, it will be fun shifting..
