Projects My 52-54 victoria build
Discussion in 'Traditional Customs' started by voodookustoms, Apr 3, 2015.
  1. voodookustoms
    voodookustoms
    After doing some research it sounds like adding a PCV valve on one of the valve covers might help some of the leaking issues.
  2. voodookustoms
    voodookustoms
    ImageUploadedByH.A.M.B.1465695911.166792.jpg ImageUploadedByH.A.M.B.1465695923.750857.jpg
    Out for a little spin. I ended up putting the second pair of valve covers on it so the breather would have a better fit until I can get the grommets posted earlier. Also installed a pcv. It may have helped somewhat with the backspray but I think this big finned breather is just too open and oil is dripping out of the bottom. The car is fast and loud though. Just how I like it. B
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Read both of these: http://www.fordmuscleforums.com/all-ford-techboard/475686-pcv-system-302-a.html And this: http://www.jalopyjournal.com/forum/threads/302-ford-eng-do-you-need-a-pcv-valve.623257/ Had problem with valve cover gaskets too,Fel-Pro and Mr. Gasket cork swapped to these and added baffles and problem solved http://www.ebay.com/itm/FORD-MUSTAN...ash=item35f1de95c9:g:aawAAOSwEetV-gm5&vxp=mtr Still get some oil around the breathers so will add a hose to the underside of the air filter to complete the system.
    voodookustoms likes this.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Check your connections to the Carb with this ;) carb.jpg http://www.laroke.com/larryk4674/2009/AFB_Rebuild_Guide.pdf
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. voodookustoms
    voodookustoms
    Jeff, thank you so much for all the info and links to everything. Im always impressed with your willingness to help others on here.
    With this info I'm confidant that i will solve my issues. I'll post up my results when its done.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Don just posted with swap to 3:31 rear gears and the AOD he got 24 MPG average on a 700 mile road trip. Also donor engine was a '93 Mustang 5.0.
  8. voodookustoms
    voodookustoms
    That's pretty impressive!
  9. voodookustoms
    voodookustoms
    ImageUploadedByH.A.M.B.1466296082.089558.jpg ImageUploadedByH.A.M.B.1466296104.026200.jpg
    I've got a flat spot in one of the tires that creates a bad shake at around 65mph so until I get a new one I've been staying off the freeways. Car runs good now. I took it to a local show and was greeted by everyone there with welcoming smiles. They all liked seeing a younger guy driving one of these.
    Asphalt Demon likes this.
  10. Tune_UP
    Tune_UP
    from colorado
    Beautiful car! Awesome shirt!
  11. voodookustoms
    voodookustoms
    Thanks Tune Up. We got another Deftones fan in the house!
    Knghtcadi likes this.
  12. jsshayes
    jsshayes
    I don't know if he is on here but pretty sure you follow 53cvictoria on IG. I keep seeing a similar color combo on your 52. I love a very mild custom like this. This and your's keeps pushing me every day to get my 54 Skyliner up and going.
  13. voodookustoms
    voodookustoms
    Ya I know that car! Definitely some inspiration for my build. That's what it's all about man, just keeping the motivation up and keeping these old cars on the road!
  14. flamingokid
    flamingokid
    Add me to that list,I've followed the Deftones for 20 years.
  15. voodookustoms
    voodookustoms
    Hell ya. They are definitely one of my favorite bands. I've seen them live twice now.
    flamingokid likes this.
  16. flamingokid
    flamingokid
    Shoeboxes,BMX,skateboards,and great music....great minds think alike. ;)
  17. voodookustoms
    voodookustoms
    Just a little update, I found out my rims were actually pretty out of round. I needed at least 2 new ones. Somehow I ended up with 4 rims and some 6.70-15 super cushions on my credit card statement. I blame it on my sickness.
  18. 56longroof
    56longroof
    Well,your not alone. I think we all have it! Those are going to look great on your car by the way.
    Sent from my SM-G900R4 using H.A.M.B. mobile app
  19. voodookustoms
    voodookustoms
    Thank you longroof.
  20. voodookustoms
    voodookustoms
    After and before.
    My turning radius is gone now, and I'm riding about 1/2" higher, but I like how they fill up the wheel wells better now. Anyone think the 4 1/4" whitewall is too big???
    Eric H and flamingokid like this.
  21. 56longroof
    56longroof
  22. flamingokid
    flamingokid
  23. Peanut 1959
    Peanut 1959
    I agree that the whitewall is a bit thick. But I wouldn't worry too much about it until it's time to replace...unless, of course, the driveability is seriously affected by the new tire size...
  24. greaser 35
    greaser 35
    from FRANCE
    Look good!!!! beautiful !!:cool:
  25. ericxx
    ericxx
    Sent from my Micromax AQ4501 using Tapatalk
  26. Dos Cincos
    Dos Cincos
    Looks great to me.
  27. jeffyg82
    jeffyg82
    I think the white walls look great the other hubcaps showed a little more wheel which is a nice touch with them being red imo. Nice build man keep it up
  28. dlandberg
    dlandberg
    from Sweden
    I would raise the front just a little higher if it was my car, i like the raked look and you can turn around little better and ride a little better, but in the end its your car enjoy it the way you like looks great!!! By the way Deftones is a great band [emoji6]
  29. bbhart
    bbhart
    You get my vote. Sweet!!!
  30. RockinRivi
    RockinRivi
    X2
    David
