Technical Why Old '35-'38 Packard 3-Spds. Don't Suck...Gear Porn
Discussion in 'The Hokey Ass Message Board' started by miller91, Jul 9, 2016.
  1. miller91
    miller91
    Refurbishing a topshift Packard...gears are off to Curtiss-Wright Aerospace/MIC for shot peen
    after cleaning and deburring. Beefy. Have had this kicking around for 38 years. Guess it's about time. What a masterpiece.
  2. tb33anda3rd
    tb33anda3rd
    hard to tell without something, of a known size, to compare it to.
  3. Truck64
    Truck64
    from Ioway
    Cool beans. What, or why do they need shot-peening? It's not a cosmetic thing. Something to do with case hardening or keeping them from chipping or something?
    Hnstray likes this.
  4. Used to run those in my '50 Olds. Good box.
  5. Gofannon
    Gofannon
    I've got one to go behind my GMC. I'll need to rebuild it, do you have a source for parts if I need them?
  6. miller91
    miller91
    Relatively cheap insurance, the gears had some pitting, if I am going to go as far as I am I want them to last. Also did some refacing and deburring, so want to eliminate stress risers. Going for a consult at Curtiss-Wright/MIC, they have a location half hour from me.
  7. miller91
    miller91
    If you have a 35-38 non-overdrive box the bearings (clutch shaft single roller, snap ring rear seal rear is Timken 209 SL, or SKF 6209 ZNR, etc and mainshaft rear single roller snap ring open is Timken 306 L, SKF 306 NR etc) cross reference to several manufacturers, hopefully the gears are good, pretty pricey but available. Kanter Auto and Max Merritt are sources for parts and some reconditioned/exchange. Get the manuals and parts lists off PackardInfo.com. Nice boxes.
    Gofannon likes this.
  8. Gofannon
    Gofannon
    Thanks! Great info.
  9. vtwhead
    vtwhead
    Had a nice 37 box that I put new bearings in and sold to another member with a Transdapt Olds to Packard adapter. It was a nice box and easy to work on. I believe that Northwest Transmission in Ohio has everything one could need for these trannies. I know they work on all the Lasalles and Olds boxes. They have an older fella there that makes the old std shift trannies his thing. He is good and has many reference manuals FWIW
    Stovebolt likes this.
  10. Stovebolt
    Stovebolt
    Thanks for the information - I have 2 1/2 transmissions here, and a Hildebrandt flathead to Packard adapter, as well as 2 GM to Packard adapter plates.
  11. miller91
    miller91
    Nice. I am probably putting it behind a flathead.
  12. miller91
    miller91
    Thanks for the info, so far so good on my end, working on it is pretty easy overall.
