My pal Dave,the owner of the 34-32 confused pickup,called me tonight asking me if I knew of a manufacture of a bolt on sway bar. In the test drive around the block the truck experienced some body roll and he cut up the right rear tire. The truck has a triangular 4 bar and coil over shocks,he's a little bummed out and really needs to find a bolt on sway bar if it exist,he sure doesn't want to start grinding and welding on all the fresh paint. I would appreciate any leads. HRP
Find an old 70's Ford Courier pickup. Their front sway bar is perfect for most pre-war cars. I put one on the rear of my '36 Willys & my '36 Pontiac Sedan. Bar is straight with splayed ends @ about 30deg but they can be bend in a press to straight back if necessary.
http://quickorgarage.com/custom.htm I know a few people that have used these guys, and have nothing but great things to say about them.
Thanks for the lead and I'll p*** it along but Dave is under the gun to finish the interior and correct this problem by next Saturday. HRP
Hellwig used to offer quite a lot of application specific, not sure about the early hot rods. http://www.hellwigproducts.com
I have the exact same rear suspension on a 9", so I used the anti-sway bar off a mid 80's F-250. I harvested the bar, axle mounts and frame mounts for only $25. I turned the frame mounts to bolt right on the '32 frame rails and then used some replacement short links with poly bushings from Auto-Zone. It fits perfect without modification. It used to change lanes when I stabbed it, but now it goes straight as an arrow. Handles like a go-kart around curves.
I bought a Ford rear sway bar for my 78' Ranchero and it corners like a go-kart , along with the 50 series TA radials
My black sedan has a torsion bar set up that I purchased from TCI years ago and it too handles like a slot car. HRP
Thanks for all the hints and advice,the urgency is a non issue now,Dave found water in the oil last night so taking the car to Kentucky ain't gonna happen this weekend. HRP
I have been to a gay bar, a lesbian bar even a cowboy bar but I have never even heard of a sway bar. That's just weird man.
Damn Beeno,you get stranger every day! I'm certain you have bellied up to the bar and frequented many a biker bar but what about a crow bar,piano bar or a sissy bar? HRP
A sway bar is another name for a Swisher Bar, and that is code for Gay Bar ~ If you're into that sort of thing. Now as for an Anti Sway Bar ~ I would go with TCI's set up.
Both Ch***is Engineering & Paul Horton sell universal anti-sway bars. http://www.ch***isengineeringinc.com/search.php?search_query=sway+bar http://welderseries.com/blog/#!/Sway-Bar-Kits/c/12921497/offset=0&sort=normal Also, don't rule out a front anti-sway bar. While the rear is critical, the front ones help also. If he has a dropped axle, Ch***is Engineering makes a bolt-on kit and I can attest it works well on my I-beam.
