Technical 331ci Chrysler hemi, anyone put a T700 / 4L60 behind it?
Discussion in 'Traditional Hot Rods' started by HemiIn34, Jun 6, 2016.
  1. HemiIn34
    HemiIn34
    If so what adapter have you used? I want to run this trans for overdrive. Cheers
    Sent from my SM-G900I using H.A.M.B. mobile app
  2. Turnaround
    Turnaround
    Brentsen is capable of making one off's if he doesnt already make your kit.
    Bendtsen’s Speed Gems Inc. 763 767 4480
    13603 Johnson St NE, Ham Lake, MN. 55304
    bob@transmissionadapters.com
    SuperBuick55 likes this.
  3. Hnstray
    Hnstray
    from Quincy, IL
  4. 97
    97
  5. FrozenMerc
    FrozenMerc
    I put an A518 behind a '58 325 ci Dodge Hemi using a Hot Heads adapter. Good quality adapter, everything fit well, and the transmission was still a MOPAR unit.
  6. d2_willys
    d2_willys
    from Kansas
    what year hemi? If 51-53, you are dealing with extended bell housing. Even some 54's came with extended bell. Both transadapter and wilcap have the adapters, but the crankshaft spacer is awfully long.
  7. da dodge brother
    da dodge brother
    from wisconsin
    Same here. Put that A518 behind the '55 270 Hemi. Works great. Got my adaptor from Wilcap. Getting about 22mpg. at 70 down the highway. Turning about 1800 ....
  8. A Regular old GM (Chevy) trans adapter
  9. I don't see an imperial ? Or pictures? Or mention of a year or extended bell. Just mention of 331.
  10. Hnstray
    Hnstray
    from Quincy, IL
    OOPS! My apologies.......got this thread confused with one in which a '51/'52 Impetial was pictured and........well......I ......I.........aww.....you get it. :oops:
    I'll delete my post.....hoo boy! Gotta look closer :(
    Edit: the thread I confused with this one is ***led "Imperial Hemi"
    Ray
  11. d2_willys
    d2_willys
    from Kansas
    Doesn't work on extended bell 331's. And I believe the vendor stopped carrying the extended bell adapter
  12. HemiIn34
    HemiIn34
    Not an extended bell housing. I emailed Wilcap (I'm in Oz so that's easier) and didn't get a response. Hot Heads have one though it seems to cover a range of Hemi's so I'm guessing it may need mods?
  13. gimpyshotrods
    gimpyshotrods
    Ahh, the extended block.
    I have only seen this done one of two ways:
    1. Bellhousing sawn off of the transmission and an adapter put on the front pump bolts.
    2. The whole block extension milled off of the block, and new mounting holes drilled.
  14. Yeah, but it's not an extended bell housing .
    It is just me then, ok:p
    I like to be by myself
  15. sunbeam
    sunbeam
    You will spend another $600+ for a stand alone computer but you won't have to fight a TV cable
  16. Carly, Standard Hot heads chevy adapter is all you need. Same bolt pattern as 350/400/p0werglide.
  17. I didn't see 4L60E and not the same as a 4L60
  18. Yeah, I only saw T700.
  19. Fullblast
    Fullblast
    I have the Hot Heads Adptr on my 354 with a th350, and is true that the 4l60 will bolt to a early small block, so this adptr should work. Email Hot Heads.
  20. Just Gary
    Just Gary
  21. T700r4 and 4l60 are the same, it was renamed from T700r4 to 4L60 for GM rename campaign. 1992 93 and 94 are the weird transition years when GM was doing the change over so the car could have a 4l60 or 4l60E. 1995 on its a 4l60E . You'll have to look at the Trans- a 700 and 4l60 have a TV cable and 4 prong plug in the drivers side, (US left had drive) the 4L60E has no TV cable and a 13-22 pin round connector on the p***enger side. 4L60E is the later computer controlled version & needs one to shift.
    Also all ( all means ALL) are the same bolt pattern as the TH350 and TH400.
    If you have a RH drive vehicle, watch or ask what side you want the starter on because drivers side in US is Left.
    270dodge and Just Gary like this.
  22. sunbeam
    sunbeam
    I was supprised that Hot Heads adapter comes in at $435.
  23. HemiIn34
    HemiIn34
    Not extended [emoji5]
    Sent from my SM-G900I using The H.A.M.B. mobile app
  24. HemiIn34
    HemiIn34
    Yeah that's what I'm thinking from my research. The TV cable looks to be a nightmare. That said I dunno if I'm keen on adding an ECU to my jalopy. Darn decisions, ha ha
  25. HemiIn34
    HemiIn34
    Are you running TV cable or ECU?
  26. HemiIn34
    HemiIn34
    I'm now a little concerned about the set-up. Might be a little too high-tech for the type of rod i'm building. That said if I can hide it all away and it works well them I'm on it! :)
  27. gimpyshotrods
    gimpyshotrods
    It is not a nightmare.
    It takes just a few minutes to set one up properly, provided you have obtained the correct parts.
  28. I wouldn't rely on your research at all.
  29. Just Gary
    Just Gary
    TV cable, 700r4 & Edelbrock 650, but it's not on the road yet.
