Does this look like a Ford?
Discussion in 'The Hokey Ass Message Board' started by motormaniac, Mar 15, 2006.
  1. motormaniac
    motormaniac
    I ask because I’m having some ***ling issues. What you are looking at is a 1930 Willys-Overland cowl (and doors eventually) grafted to a 1930 extended back section from a Model A RPU. The frame is scratch built as are the wheels. The hood is from a Chevy and will be modified to line up the belt lines. The grill will be a 1930 Willys which looks like a Model A. Most or the suspension is early Ford.
    I can not for the life of me find a clean 1930 Willys ***le but I do have a 1930 Model A Roadster ***le.
    Do I call it a Ford and ***le it as a Model A Roadster?
    Thanks,
    Motor
  2. 50flathead
    50flathead
    from Iowa, USA
    Add the blue oval or the script logo and you are in business!
  3. Don't know how sharp the local gostaple is but around here you wouldn't have a problem. Just stamp your frame numbers on a run with it. that's what I would do.
  4. Bigcheese327
    Bigcheese327
    I realize that only you and the DMV will know that it's ***led as a Ford, but ***ling a Willys as a Ford just seems... wrong.
    Too bad you're not in Michigan, I've got a real nice method for getting a clean ***le here saved on my computer.
  5. alchemy
    alchemy
    Hey Bigcheese, why don't you get a ***le for "your" Willys and "sell" the car to him?
  6. Bigcheese327
    Bigcheese327
    It involves an in-person inspection by a law-enforcement official. Seems a mite pricey to ship the car back and forth.
  7. Dirty Dug
    Dirty Dug
    Use the ford ***le. First, you're never going to stopped by the cops around here, they're too busy chasing ricers, and second, they wouldn't know the difference. My T roadster doesn't say Ford on it anywhere nor do most other hotrods...
  8. muffman58
    muffman58
    I would think that its enough like a Ford to not have anyone h***le you. O.T. Are those wheel blanks? Also love the P1800! Tell me your roddin it!
  9. motormaniac
    motormaniac
    I'm trying to avoid having to get it inspected at the state police because thay will most likely want to call it a home built and I want to be able to use a 1930 Washington plate on it.
    Yes, those are forged aluminum wheel blanks. 18" all around. I plan to dull the fronts to look like the rears.
    Motor
  10. scootermcrad
    scootermcrad
    I LOVE IT!! Any build pics? Did you make that rear crossmember yourself or is that from something else? Very nice work!
  11. Wow ! That thing has THE LOOK ! :)
    I hope that ***le deal works out for you.
  12. Dirk35
    Dirk35
    Hmmmmm, Lets see, Ford Rear Section, Willys Cowl, Chevy Hood, Motormaniac Frame, ..........obivisouly, a Dodge Grille is in Order here to complete the Car.
    Call it a Forwiloletege. For=Ford, wil=Willys, olete=Chevrolete, ge=Dodge!
    ***le it was whatever is cheaper/easier as it really doesnt matter at this point.
    It looks good though!
  13. tjm73
    tjm73
    Yes and those wheels look awesome! Very cool.
    I would like to see build pics too
    I can't make out the engine, but that looks like a T5 ******. Is it a 2.3 Ford?
  14. Django
    Django
    from Chicago
    Call it a Ford, get it inspected, put on a Model A shell with a Ford emblem and call it a day. Put the other grille on when your paperwork is finalized.
  15. burger
    burger
    I'm no help... just wanted to tell you those rims are the bee's knees. The rear crossmember's pretty slick too.
    Hey, what are those rear tires?
  16. motormaniac
    motormaniac
    Thanks for the compliments. I came up with the wheel ibea a little while ago and from the company I purchased them from I could get some tall and skinny sizes. The fronts are 18" x 4.25" and the rears are 18" x 5.5"
    The rear tires are "atc something or others Transport bias plys from Coker" 33" tall!
    I drew up the rear cross member in CAD and had it laser cut from 1/4" material. The is rolled in three pieces and then welded inside and out.
    I look for some build pics. They seem to be saved all over the place at the moment.
    Here is a pic before I moved the front axle back. It looked too long.
  17. motormaniac
    motormaniac
    Oh yah, forgot to mention that the engine is a 240Z engine. Light, Fast, and Cheap!
  18. BlackFlag
    BlackFlag
    Those engines came stock with dual side draft webers right? looks pretty good and those have a decent aftermarket for them as well. *****in car, I hope everything works out for you.
  19. 50Fraud
    50Fraud
    Great proportions. I particularly like the wheel & tire sizes in proportion to the wheelbase.
    Will the doors actually be that long, or will you extend the quarters forward?
  20. plymouth_man
    plymouth_man
    from WI.
    Check you local D.M.V. Here you can get collector plates,but has to be origninal. Than they have a Hobbyist plate,which the car has to be 20 years old and vehicle is modified from orgn. manufacturers specs. vehical can still be recognized as the orgn. year and make. If you don't tell them that it's not a Ford body they won't know. They give you a tag for it. use your ford ***le.
  21. michael037
    michael037
    I agree with burger. Trick fabrication work. Looks good.
    Michael
  22. Tetanus Shot
    Tetanus Shot
    i have a 1934 willys-overland ***le if you are interested, i know its not a 1930 but you could at least have it registered as a willys
  23. Dick Steinkamp
    Dick Steinkamp
    Actually, it can't be done, and the car is probably worthless, so the best thing to do is to just sell it to me ;)
    BEAUTIFUL car!
    You might try Broadway ***le...
    http://www.broadway***le.com/
  24. burger
    burger
    I think I found the tire... is this it?
  25. LuckyBastardMiguel
    LuckyBastardMiguel
    I agree with porkn****** just go with it and good luck.
  26. brokenspoke
    brokenspoke
    looks like a 30 to me
  27. motormaniac
    motormaniac
    Burger, These are them, them are those, those are these!
  28. tjm73
    tjm73
    Inline 6!?!?! Sweet! This is one cool car IMO.
  29. motormaniac
    motormaniac
    Thanks for the compliments and the advice!
    Motor
  30. Skotz
    Skotz
    I'd call it real "COOL" and use whatever ***le you have....got a real neat look to it.
    Skot
