Hot Rods Whinning noise from '57 Chevy
Discussion in 'The Hokey Ass Message Board' started by Bigstar, Jul 15, 2016.
  1. Bigstar
    Bigstar
    from Austin
    Ok so I have a 301 V8 engine with a Turbo 400 in my '57 Chevy truck. Lately when I get my truck up to 45 mph or faster I get a whining noise that gets loud the faster I go. I have checked the fluids and all good. Can't figure out where it is coming from. Any thoughts?? When I am driving and it's whining I put it in neutral and rev the engine and it gets louder. It's weird.
  2. pat59
    pat59
    Is you wife or girlfriend sitting next to you? :)
    56don, 1927graham, alchemy and 7 others like this.
  3. Mr48chev
    Two things come to mind an those are the alternator making noise or the power steering. Alternator is pretty easy to check as you can unplug the plug and fire the truck up and see if the noise went away or changed. A mechanics stethoscope from the tool display at the parts house helps run down noises too as you can put the probe in different spots and tell if a bearing is bad or somewhat isolate the noise. If you are cheap you can use a length of Old broom handle as a make shift stethoscope.
    Daniels Auto Repair likes this.
  4. Gene Boul
    Gene Boul
    Just take the belt off!
    bobss396 likes this.
  5. Lebowski
    Lebowski
  6. Daniels Auto Repair
    Daniels Auto Repair
    I like a piece of fuel line for hunting random noise....possible front pump in ******?
  7. D.N.D.
    D.N.D.
    Yep that is the gearheads steth0scope, works great for a few coins
  8. Probably the gear drive......
  9. bobss396
    bobss396
    Even a piece of broom handle works pretty well. I've used heater hose too.
  10. SmokinBill
    SmokinBill
    V-belt is slipping and screaming at high RPM
  11. low budget
    low budget
    from Central Ky
    Sounds like it could be the trans pump whining but I cant understand it not doing it till you get up to 45 or so but then it getting louder when you put in neutral and rev it??? another thought would be to unhook the speedo cable from the trans and see what it does, Ive had those speedometer gauges throw some awful whining or even screaming fits.
  12. Bigstar
    Bigstar
    from Austin
    Well I unhooked the speedo cable and I got it to whine while the truck was in park so I don't think it is transmission related. . I'm having a hard time pinpointing the noise but I will keep trying to figure it out. The truck doesn't have power steering.
  13. Deuces
    Deuces
    Rear end dope level maybe???
    It's worth a look..
  14. Jalopy Joker
    Jalopy Joker
    running a blower - Ha! - vacuum hoses all connected in good condition?
  15. Bigstar
    Bigstar
    from Austin
    I actually changed the gear oil in the rear end first thing this morning. All vacuum hoses hooked up. It sounds like it might be coming from the front of the engine. Maybe the belt, fan bearings, water pump, ???? It didn't sound like the alternator. I feel a little better now that I know it is coming from the engine when it's in park and not the transmission.
  16. Craig Owens
    Craig Owens
    Good one!
    1927graham likes this.
  17. low budget
    low budget
    from Central Ky
    Figured it out yet? As mentioned before take all the belts completely off and start it and see what it does.
  18. Bigstar
    Bigstar
    from Austin
    That is a good idea I will do that tomorrow. I missed that suggestion before
