Projects 28 RPU "problem child" build thread "first try at a hotrod"
Discussion in 'The Hokey Ass Message Board' started by twenty8tudor, Jun 15, 2014.
  1. Tim_with_a_T
    Tim_with_a_T
    Can you take a closer picture of the texture of the top material? Looks pretty cool to me!! One thing I see- I would paint the snaps black. Everything else is right on!!
  2. twenty8tudor
    twenty8tudor
    from Ohio
    I did not think of painting the snaps.. That's a good idea! Since I painted the other clamp nut things black..
    The upholstery guy said its called cobra texture I guess... It's pretty close to what was on it when I got it and I believe it to be the original style texture
  3. Tim_with_a_T
    Tim_with_a_T
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Looks great. I agree on the snaps. That fellow did a great job. Nice and tight. Sides have a great shape to them.
    I'd like to see a slightly smaller back window.
    Your tire and wheel spacing is just perfect.
  5. twenty8tudor
    twenty8tudor
    from Ohio
    Yeah hope to get back up there soon and get another section made. Dropped off the wire wheels at the blasters this morning so I can get them powder coated.. The 700x18s fill the rear fender up a little better, but also need to get a new rear spring made so hopefully that doesn't change a lot
  6. twenty8tudor
    twenty8tudor
    from Ohio
    Small update for now..
    Finally found a rear piece for my 59a two piece oil pan. Was posted on a flathead group on Facebook when the guy got it in a bunch of parts not knowing what it was.. Was able to buy it and another guy said he had one also he wasn't using.. So now I have 2 :)
    Was having an issue with the truck starting.. Would start fine cold and seem to run down the road just fine also.. But once shut off it wouldn't start again till the motor cooled back down.. Goofed with it for a few evenings and with some help of some guys on that same flathead group on Facebook we got it figured out..
    Ended up being a bad coil. Must have been giving weak spark all along cause after swapping it the truck starts way easier cold and starts nice hot and seems to run smoother also.
    Had it mounted in the original upside down position on the firewall to test the fix.. But msd instructions said it was advised to mount upright.. So I moved it inside and mounted it to the firewall. Kinda nice to have almost everything off the firewall outside.
    Looked up a rear window on macs antique auto and cut out some vinyl to figure out if that size would work. I think it will be ok.
    Next I needed to attach the gravel pan I made awhile back... Figured while I was doing that I would mount a fog light back on since I put one on it when I first bought it and the guy i ran around with who passed away ran one on his 32 and I bought this one at Hershey when he took me along.
    Needed to weld in some bungs for the gravel pan.
    Next was cutting up and making the fog light mount work.. Funny how boxing a frame causes so much more work..
    Didn't like how high it set so took a little bit out of the stand
    Made a few more bungs and did the same thing for the light as I did for the gravel pan.. It put up a fight and broke a tap off inside after I had already welded it in. So had to redo one.. But got it mounted in the end.
    Went to a local show on Saturday for fun and to see if any issues came up.
    Always wanted to stop by this old library in town and take some pics.. Will go back again after I get it all finished up.
    Tim, waxhead, brad2v and 3 others like this.
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Two questions. Your planned window size the size of the piece of orange? If so
    I'd suggest alittle longer but the height looks great.
    Another, that's a long distance for your coil, are you running an Msd ignition?
    twenty8tudor likes this.
  8. twenty8tudor
    twenty8tudor
    from Ohio
    The orange is just what the measurements of a window from macs antique auto was.. So I'm guessing it would be stock height/width.. I
    ordered one this morning and have to see what it looks like when it shows up. Could always been cut and lengthened if need be
    Is a Mallory electronic distributor that's in it. I'm guessing from where I had it in the original position to where it is now lengthened it by about 3".. Seems to be doing ok and starting a lot better.
    I thought about putting it under the seat but kinda thought this far away would cause some issues
  9. 51box
    51box
    from MA
    You're doing a great job on this lil rpu, look forward to seeing it in paint.
  10. twenty8tudor
    twenty8tudor
    from Ohio
    Thanks!
    Had a buddy that is way more knowledgeable on painting stuff look at it on Saturday to get a game plan.. I'm not gonna do much but primer things till after the bonneville trip..
    Now I have to figure out if I want to go gloss, semi gloss, or satin finish..
  11. bengeltiger
    bengeltiger
  12. twenty8tudor
    twenty8tudor
    from Ohio
    The rain from when I had it out in the funeral was starting to really get on my nerves.. So planning on taking the truck to bonneville in August so I'm rushing to get things in order for that to make it look somewhat normal..
    Using a rust treatment/converter that is supposed to also help protect the metal.
    Spraying a lacquer primer on the fenders and parts so the fenders and running boards will look somewhat normal.. Will sand it off as a guide coat when I get back.
    Used a tip I overheard one of the guys in the group talking about when I tried to clean up the headlight rings.. Some metal polish and tin foil to scrub it with. Worked pretty good
    Took the truck up to the upholstery shop to have the center part and window redone... Was neat to stick around and watch the guy do it..
    And much better the second time around..
    Hope to have the rest of the stuff primered over this weekend so I can start putting it back together this week.. Bonneville will be here quick... Hope the weather holds out.
    brad2v, Dean Lowe and slv63 like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
  14. twenty8tudor
    twenty8tudor
    from Ohio
    Thanks! It's a lot better size.. But i think I'm gonna have to take it somewhere else and see if they can tighten it up.. It will work for now but it's kinda bunched up around the edge of the window..
  15. twenty8tudor
    twenty8tudor
    from Ohio
    Goofing around and working late to try to get this thing ready for the trip out to bonneville.. unfortunately going to trailer it out but so many miles on something not quite finished does not sound fun.. Anyway progress in the last couple days..
    Wanted to get the cowl section to be somewhat the same color.. Scuff and spray bomb primer.. Hated to but it's going to get blasted anyway..
    Wanted to out the old motometer back on the shell, with the aluminum radiator that's an issue.. Have some round plastic from work that I run through the lathe so it would thread down into it.
    Turned it down to where it just had to be knocked in from the bottom and would stick.
    Drilled holes and welded some
    1/4" bolts to the shell to hold some screening. Also filled where the ford logo was at.
    Got busy and forgot to take pics but primed the shell, wheels and hood.. So I could start putting it back together.. Mostly finished up late last night.. Still some things to do and adjust but it looks like a truck again.
    The grey and black is kinda growing on me.. Planning on putting gas in it and welding up the bottom of the battery compartment just have tacked in place.
    Might start a different thread for the trip out and cover the event like I did in 2012.
    http://www.jalopyjournal.com/forum/threads/2012-bonneville-pic-thread-dial-up-beware.724836/
    Tim, waxhead, Dean Lowe and 1 other person like this.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    Man that looks great. Love the moto-meter. Looking forward to going along by watching your trip out.
    In my old age...
    Grant me the senility to forget the people I never liked.....
    the good fortune to run into the ones I do.....
    and the eyesight to tell the difference.
  17. twenty8tudor
    twenty8tudor
    from Ohio
    Thanks man! Looking forward to being out there.. The driving out and back not so much haha..
    Haha that's a pretty good saying! I'll have to remember that one.
    Petejoe likes this.
  18. twenty8tudor
    twenty8tudor
    from Ohio
    Finally nice to put some miles on it instead of just constantly working on it.. So far about 111 miles and no issues as of yet..
    Rear spring needs to be redone as it has no spring left to it. Hope to get that taken care of after bonneville..
    Finally last night got the lights wired back up.. One of the grease fittings won't take grease on the front so have to straighten that out and start packing clothes and stuff for the trip
  19. Petejoe
    Petejoe
    from Zoar, Ohio
    What great pictures. I really like the looks of the two tone. This Sunday in Zoar having a small car show along with the Harvest festival. Drive up. I'd love to see it and meet you.
    How's it running in this heat?
  20. twenty8tudor
    twenty8tudor
    from Ohio
    What time does it start sunday
    It seems to have went up about 3-4 degrees since putting the screen on but right around 200 degrees all the time
  21. Petejoe
    Petejoe
    from Zoar, Ohio
    Starts at 10 am. Sent you a message.
  22. bengeltiger
    bengeltiger
    Two tone does look good. Enjoy the Bonneville trip!
  23. twenty8tudor
    twenty8tudor
    from Ohio
    Thanks!! I'll try my best :)
    The colors are starting to grow in me more and more..
    Did get the wheels back from getting powder coated satin black.. So I wanted to toss them on.. Now after having the 40 wheels on for a good while I'm not sure which I like better the 40s or the wires
    1959Nomad, Dannerr and slv63 like this.
  24. Dean Lowe
    Dean Lowe
    The wires fit the build style. Either looks good. Change off as the mood strikes.
  25. I'm with Dean - I like the wires the best, but keep both, and change as you see fit (but I'm a wheel'oholic, counting sets of; 18" wires, 17" wires, 16" wires for restoration, 16" Willys (2x 4", 2x 4,5"), 16" '40 steelies (plus a spare) and 15" (2x stock, 2x reversed center)... most needs new tires!).
  26. twenty8tudor
    twenty8tudor
    from Ohio
    Okay well made the trip out and back.. Trailered the truck out and back which worked out pretty well.
    Installed the key chain with my buddies ashes in it..
    Took off around 8am.. Kansas sky sure looks a lot nicer the ohio
    This become a very normal sight
    And after a 14 a 12 then a 4 hour day we made it..
    Had a blast and posted a ton of pictures in the other thread.. Came home and went to a localish show that always has a great bunch of traditional hotrods.. Called the spinout in brimfield ohio.
    Didn't get a chance to get the salt cleaned off by then but it made it fun for people to see and some tasted the salt that was stuck to the under side of the fender..ended up getting the award for best pickup.. Which I was surprised cause there was a really really nice channeled 34 pickup.
    Anyway I have started cleaning the underside of the truck..
    Hopefully using that rust treatment will help keep the rust down from the salt.. Going to pop the front fenders and bed off tomorrow and really get them cleaned and treated again..
  27. falcongeorge
    falcongeorge
    from BC
    Nice! I must admit, I got to the end of the first page and thought " oh great, he's gonna trash the fenders. Ok, well, I'll just save time and go straight to the last page, check out the mess and move on."
    What a pleasant surprise to find a nice looking, well proportioned full fendered RP! Now I have to go back and check out the rest of the pages...;):)
  28. falcongeorge
    falcongeorge
    from BC
    I am going to buck the trend here, I like the solids better than the wires.
    62hotcat, slv63 and a boner like this.
  29. Binger
    Binger
    from wyoming
    Glad you made it back safely. It was nice to meet you. I will be excited to see you get this truck into paint.
  30. ratamahata
    ratamahata
    from Argentina
    Love your pickup!! Very inspiring for me!! Love to see the wires... Very traditional I think!!
    Enviado desde mi XT1068 mediante Tapatalk
    Superdangerdave and 62hotcat like this.
