Technical DRAG LINK HITTING OIL PAN IN FULL TURN OF WHEEL
Discussion in 'The Hokey Ass Message Board' started by tonyimpala, Jul 16, 2016.
  1. I have a 40 Ford with a 53 Flathead. When I 1st bought the car it had a straight pitman arm as shown in the photos. I could only get 14 degrees turn angle LH and Rh on the steering wheel. The drag link was rubbing on the front of the oil pan. I soon changed to a 3/4" dropped pitman arm and increase the wheel turn angle to 21 degrees. If my memory serves me correctly it s/b 25 degrees.
    I wish to increase the steering wheel turn angle to 25 degrees. I thinking of notching the oil pan or offsetting the drag link at the center.
  2. gimpyshotrods
    gimpyshotrods
  3. fordor41
    fordor41
    Install a drag link with a bend to clear the pan, as long as it also clears the axle as it moves up and down.. easier than modifying the pan
    scrap metal 48 likes this.
  4. Last edited: Jul 16, 2016
  5. I did think about lifting the engine. Then the motor mounts will require some attention. Thx, I see if there are offset tie rod ends.
  6. 53 ford
    53 ford
    Find a rear sump pan. You may have to change oil pump pick up too. Early 50s merc would work well.
  7. gimpyshotrods
    gimpyshotrods
    A bend in the drag link at the tie rod that is on the pitman arm will provide the necessary clearance.
    Be aware that putting a bend in shortens the effective length, so you might have to make a longer one.
  8. Phil1934
    Phil1934
  9. 53 ford
    53 ford
    '51 Mercury oil pan.
  10. Thx guys, some good ideas here. Looks like the offset rod end is on the top of the list for now. I'll just one, on the pitman arm side 1st.
  11. RichFox
    RichFox
