Projects Picked up my first project! 56' Chevy 150
Discussion in 'Traditional Hot Rods' started by braydenh, May 25, 2016.
  1. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Congrats. I hope you can get it running and have some fun this Summer.
    braydenh likes this.
  2. Brayden,
    With TorkWrench's evaluation that you may very well have a 3.70 diff ratio, here's some numbers to give you an idea of what rpm's you will be turning when in third gear (1:1) on a TH350 using a 26" - 27" tall tire:
    120kph/75mph: 3586rpm (26") - 3453rpm (27")... less scientific answer: about 3500rpms
    100kph/62mph: 2965rpm (26") - 2855rpm (27")... less scientific answer: about 2900 rpms
    80kph/50mph: 2391rpm (26") - 2302rpm (27")... less scientific answer: about 2300 rpms
    Assuming a 3.08 rear diff:
    100kph/62mph: 2468rpm (26") - 2376rpm (27")... less scientific answer: about 2400 rpms
    You can see how a taller rear diff gear yields about 500 fewer rpm at highway speed.
    website used for calculations: http://www.csgnetwork.com/multirpmcalc.html
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Factor in 10% more on the RPM's for any automatic without lock-up. Your calculations are based on 1 to 1 without any slippage developing within the converter.
    gotta56forme and braydenh like this.
  4. Butch M
    Butch M
    cool car good luck
  5. jeffd1988
    jeffd1988
    Try to find and put Put a 3.08 rear gear if the motor has power you be good with that gear for sure
  6. braydenh
    braydenh
    [​IMG][​IMG]
    Quick update for ya! Ended up going towards a full disc setup. With dual diaphragms. And buying a totalled off 2001 Chevy 1500 truck. Gonna use the motor, trans and driveshaft off of it!
    Also fooled around with some lace paint too.
    IG : braydenh56
    benchseat4speed and jeffd1988 like this.
  7. jeffd1988
    jeffd1988
    Nice set up. But i believe this forum isnt friendly with vortecs. Only carbureted. Just a fyi. Im still subscribed to this page i wanna see how the car come out tho. [emoji106]
    braydenh and Johnny Gee like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ No one can stop you from doing it your way Braydenh56. What Jeffdl988 is saying. Select the wording you use here for a while longer and you'll fly under the radar. :)
    jeffd1988, volvobrynk and braydenh like this.
  9. braydenh
    braydenh
    ***UPDATE***
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Interior stripped out, door panels stripped, headliner yanked out, sanded floor. Also found one moderately sized hole underneath the rear seat on the driver side on the body mount. Underside sanded and painted with POR15.
    Frame sanded and painted. Engine bay sanded and painted.
    Found out I have 3.73 ratio in the rear end. Also found a 350SBC and TH350 to slap in!
    Was contemplating working on making the factory manual column shift work with the th350. But decided to go with a lokar 32" double bend floor shift.
    Still waiting to find a good hood latch (need the chrome trim along the nose of the hood) and to work on my trunk latch. And patch a few holes in the trunk.
    Also found my brake setup. I'm going with a right stuff kit off summit racing, 2 inch drop spindles in the front and an axle flip/ block in the rear.
    IG : braydenh56
    gotta56forme likes this.
  10. Don't be in a hurry to chuck the door panels, the stainless on 'em is specific and the cardboard is a pattern if nothing else.
    benchseat4speed likes this.
  11. Looking good. Glad you decided to go with a small-block.
  12. braydenh
    braydenh
    59chev - yeah. I figured it would be the better low budget route. After a couple sleepless nights and research. SBC is the better route to go either way.
    IG : braydenh56
    jeffd1988 likes this.
  13. Brayden,
    FWIW, I'm getting ready to pull the sbc & TH400 out of my '56 210 in order to do a cam, intake & head swap; and reseal the TH400 to buy me another year or two of use on it. Will clean up & paint my engine compartment during that time as well. Starting to get ready now, but will really get after it early August, when my time will be my own for awhile. All reasons why I'm enjoying following your thread, so keep after it. Here's my motley beast...
  14. ironman3452
    ironman3452
    20170310_092151.jpg so here is what I have done, if you remember the first pictures I had put on here, now slowly I have started to get some of the parts, and have done, rebuilt engine, put grill and head lights back on, added new wheels and tires, started to patch all the rust inside, and dropped the tank, cleaned it and getting ready to put it back in, next will be the front end, new ball joints, uppers and lowers, like I said, slow working.
  15. koolkemp
    koolkemp
    Canadian cars never had a tag on the A pillar, just the cowl tag.
