History Newbie Big and Littles education
Discussion in 'Traditional Hot Rods' started by jim1932, Jul 20, 2016.
  1. jim1932
    jim1932
    On a traditional 30's 40's rod, what would be a typical big and littles combination. Is this only the with and sidewall of the tire? or different rim sizes as well?
    Thanks
    lothiandon1940 likes this.
  2. RainierHooker
    RainierHooker
    from Tacoma, WA
    It really depends on the car and the year you are trying to replicate.
    As a general rule, rods in the '30s used a matched size tire front and rear. 600-16 or 650-16 tires all the way around seem to predominate.
    It wasn't until the immediate prewar period (very late '30s and early '40s) that guys on the dry lakes started using a taller rear tire than the front to gain the advantage of speed on the big end of the land speed courses. 600-16 or 650-16 up front and 700-16 or the occasional 700-17 in the back seems to be common.
    In the postwar period of the late '40s is when the exaggerated "big n' little" combinations took hold on the streets, the 'look' bleeding over from the lakes. This is when you commonly see 500-16, 550-16, or 600-16 tires up front with big 700-16, or 750-16 tires out back.
    16" wheels predominated throughout the '30s and '40s, 17" wheels were sorta old fashioned, and the 15" wheel was only offered in any quan***y when Mercury started offering them in 1940.
    lothiandon1940 and F&J like this.
  3. RainierHooker
    RainierHooker
    from Tacoma, WA
    1936 - Note same size front and rear...
    1939 - big (probably 650-16) tires on all four corners...
    1942 - Bigger tires in the rear, but not exaggerated...
    1949 - Definitely big n' littles, probably 600-16 in front and 700-16 in back...
  4. Just Gary
    Just Gary
    X2 what Rainer****** said, then read this:
    http://www.jalopyjournal.com/forum/threads/wheels-tires-stance.272403/#post-2892163
    In my opinion, on a highboy, you should shoot for about 5"-6" difference in tire height between the fronts and rears. Less if you're building a '40's themed car and a little more if you're building a '60's drag-themed car.
    Cars with fenders usually look best with a slightly smaller height difference.
    Hope this helps.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I was kinda leaning toward the late 40's style with my Deuce pickup,bias ply front tires 5.60 x 15" with 5" wheels,the rear tires were L78 x 15" with 7" wheels. HRP
    lothiandon1940 and Just Gary like this.
  6. We run old Ford 16" rims with 600's in front and 750's out back. Firestone WWW.
    Don't really like the bias tires because of road manners but they sure look the part.......
  7. F&J
    F&J
    Rainer****** posts are gospel in that precise time era.
    super early cars were go-faster more than looks. Take parts off for wind resistance, work on engine, and go faster.
    early 1950's-up, things started to change a lot in many areas of the States.... "go faster" mixed with more emphasis on "looks". Cars were not just for the tracks, and many built just for street use.
  8. just remember to put the big tires in the back and the little ones in front....don't mix that up
  9. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Did the introduction of the VW Bug, have anything to do with the availability of the 5.60-15 and further the big/littles ratio difference? Isn't that the tire size for the Bug?
  10. F&J
    F&J
    The OP said 30s to 40s rod. The VW bug first appeared in 1938 with 16" and had that 16"rim size until 1953.
  11. jim1932
    jim1932
    this answers my question. Working on a 32 tudor banger. For some reason my eyes had me convinced is was the diameter of the wheels that was different.
  12. F&J
    F&J
    Some pics really do look like two different rim OD on front vs rears, if the tire diameters are very different. Optical illusion.
  13. RainierHooker
    RainierHooker
    from Tacoma, WA
    The differently sized wheels do come up, if only infrequently, in pictures of cars at the dry lakes from the late '30s on. This car, the "McClair Phaeton" ran at Harper Dry lake in 1940, and is a major source of inspiration for my war-time period-correct Model A build:
    It appears to be running a 17-700 tires on either Ford, Lincoln, or aftermarket wheels in the rear and either 650-16 or 600-16 tires on 1935 Ford wheels in front. My car duplicates this with 700-16s on 1935 Lincoln wire wheels and 650-16s on 1935 Ford wire wheels.
    This phenomenon seems to be fairly limited to guys running for speed on the lakes, and is especially well do***ented with high-clearance wheels (i.e. the mis-named "Divco" wheels) on post-war and 1950's cars at Bonneville. I have yet to find any compelling evidence that this trend actually caught on for street-driven rods until recently.
  14. Fogger
    Fogger
    My '32 Roadster has 5.00x16 front and 7.50x16 rear on bent spoke Kelseys. It looks right to me. EP1120539_JPG.jpg
  15. F&J
    F&J
    I agree, it looks the era...and the headlight type and placement, and the lower than "normal" back of the roof. (the roof cloth on the side slopes down as it heads to the rear) Neato
  16. Fogger
    Fogger
  17. Gary Addcox
    Gary Addcox
    Your truck had "the look".
    This Gary likes it, too!
  18. Gary Addcox
    Gary Addcox
    Why, yes indeed! ALWAYS put both big tires in back, then the two 'lil tires HAVE to go up front. Wanted to clear this up.
  19. jim1932
    jim1932
    I thought the little ones go on the drivers side for going around the track. LOL
    GearHead614 and lothiandon1940 like this.
  20. Jet96
    Jet96
    from WY
    image.jpeg Firestones 7.50/16 rear 5.50/16 front. Trim rings from a '39 Dodge, original v8 caps
  21. jim1932
    jim1932
    I found my "Big"....
    believe it or not this is NOT photo shopped. Saw a set of four, in four separate trucks, on route 26 outside Charleston, SC IMG_2667.JPG
  22. Barn Find
    Barn Find
    from Missouri
    So, besides the fact that it looks photo shopped, are we supposed to ***ume that they cut the top out of four shipping containers to move these tires down a stretch of road that had no overp***es?
  23. Mr48chev
    Those look to be tires for a Cat 797 dump truck.
    Each 797 wheel is attached to the axle using 54 - 36-mm nuts that are torqued to 2,300 lb·ft (3,118 N·m).[17] A size 55/80R63 radial tire was developed by Michelin in conjunction with Caterpillar specifically for the first generation 797.[18] The Caterpillar 797B and 797F run 4.028 m (13.22 ft) tall, 5,300 kg (11,680 lb) Michelin 59/80R63 XDR. Most first generation 797s have been retrofitted to use the 59/80R63 tires as well.[19] Six tires are required per truck at a cost in 2009 of approximately US$42,500 per tire.[20]
    13.22 ft tall and the tread pattern is an exact match.
  24. I want to put a set of those on the back of my 29! lol Ron...
  25. 54stude
    54stude
    You can rent containers with tarp tops, for use when you want to unload a container with a crane.
  26. jim1932
    jim1932
    the photo is real through the windshield of my pickup. I do agree that for some reason it has that photoshop look. maybe the tint on the windshield. Wonder where they are running trucks that big near Charleston.... but then again that is Way off topic.
    how big a tire can you put on a stock 1932 ford rim? I am running the original size right now.
  27. indyjps
    indyjps
    Yokahama has a big plant outside Greenville SC. They do make Caterpillar tires but I'm not sure if they make those tires at that facility. Inventory gets run ahead and shifted around, never seen them ship like that, typically rail.
    On an export machine, everything has to get to port somehow.
  28. Bader2
    Bader2
  29. Bader2
    Bader2
  30. Nailhead Jason
    Nailhead Jason
