My 1949 Mercury project
Discussion in 'Traditional Customs' started by 1949 mercury, Mar 20, 2016.
  1. ImageUploadedByH.A.M.B.1469437713.308603.jpg ImageUploadedByH.A.M.B.1469437729.013392.jpg ImageUploadedByH.A.M.B.1469437745.671672.jpg ImageUploadedByH.A.M.B.1469437797.698211.jpg ImageUploadedByH.A.M.B.1469437858.663178.jpg ImageUploadedByH.A.M.B.1469437889.311771.jpg ImageUploadedByH.A.M.B.1469437906.069446.jpg
    Rear quarters are coming along & had fun taking the dash apart lol, now need to clean it up and put it back together.
  2. If you guys had a choice what transmission would you use behind your flathead. Stock 3 speed with OD, C4 or a T5?
  3. Squablow
    Squablow
    The factory overdrive trans is a good one, and everything is already engineered to fit, including the column shift. I'd run that.
  4. Baron
    Baron
    I agree 100%. Ran the stock OD trans in my 51 Merc for a number of years. Worked great.
    Surfcityrocker and 1949 mercury like this.
  5. Thanks Guys. I have the stock 3 speed OD all rebuilt ready to go but I also have a C4 I could put in it. Can't really decide witch way to go.
  6. FlatJan
    FlatJan
    holy **** those 49 Mercs are one of the beautifullest cars I ever have seen. I will never have one but like to see yours come together.
    keep up the good work
    Spooky and 1949 mercury like this.
  7. Surfcityrocker
    Surfcityrocker
    from Austria
    I thought the same, but they must be prone to breaking because i had a really hard time finding a usable pair. And they are not cheap either.
    Cool mercury, by the way. I would go without handles, but keep them in storage.
    I have a tuned flathead with the original 3 Sp. with OD in my Mercury and i like it. It's nice to drive even in today's traffic.
    A friend has the same transmission but without OD in his merc and he has a hard time keeping up with modern traffic.
    Sent from my ALE-L21 using The H.A.M.B. mobile app
    1949 mercury likes this.
  8. Slopok
    Slopok
    The C4 may require trans tunnel modification, first year for automatics was 51. An operating Overdrive will be no problem keeping up with todays traffic as stated above. I'm quite happy with mine.
  9. I would go with the OEM OD ****** its the Best
    I had one & it was Great, I regreat the Day I took it Out
    but thats Life
    Car is Looking Good
    Just My 3.5 cents
    or when the Cows
    Come Home
  10. 52lomofo
    52lomofo
    you gonna keep the chrome or shave it?
  11. Ok that is great information thanks guys. I will keep the stock OD.
    I'm going to get rid of the chrome except the strip just under the Windows and I'm going to keep the Mercury on the hood.
    'Mo and Surfcityrocker like this.
  12. desotot
    desotot
    It's coming along real good. I'll be watching for more pics.
  13. Spooky and Squablow like this.
    Got the frame back, going to put motor, trans, fuel tank in then put body back on after undercoating is done.
  15. donno
    donno
    Looks great, pitch the door handles, but keep the side trim.
  16. Stock 1949 Mercury 3 speed OD transmission going in. Flywheel, pilot bearing, new clutch, pressure plate & throw out bearing. IMG_1484122075.742555.jpg IMG_1484122100.880977.jpg IMG_1484122117.622221.jpg
  17. Spooky likes this.
  18. [​IMG][​IMG]
    Converting car over to 12v and started putting the dash together still looking for a few parts for the dash.
    Looking for the Starter emblem......Thanks
    brEad, Aussiepete., Spooky and 5 others like this.
  19. Anyone have pictures or a book that shows how the radiator support mounts to the frame ?
    Thanks
  20. TheFrenZ
    TheFrenZ
    from Germany
    Maybe this helps you a bit.Not my car.The side of the radiator support mounts to the wheel housings.3 screws on each side.There is some rubber between the lower radiator support and the frame.Thickness may vary to due height alinement.
    chryslerfan55 and 1949 mercury like this.
  21. Thanks a lot that's what I was looking for. Mine has three holes so I was wondering if you used the two like it is. That's how I have it now with a body mount cut in half under the support. Thanks
    hoppedup46 and koolkemp like this.
  22. brEad, Spooky and Ford52PU like this.
  23. Ford52PU
    Ford52PU
    from PA
    Nice work its looking really good.
  24. 2bubbas
    2bubbas
    My father always said .15 cents and hour- either way not much pay for ones labor-
  25. Thanks it's coming along
  26. [​IMG]
    Trying to start my motor up but it's not getting fuel, any ideas ?
    Spooky likes this.
  27. Spooky
    Spooky
    Of all of the cars ever made, this is my dream car. Congrats, sir!
