some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. Barn Find
    Barn Find
    from Missouri
  2. 34toddster
    34toddster
    from Missouri
    You could make a good living by making Model T and 35-40 deck lids for coupes, NICE Work Cornfield
  3. rsluggoboy
    rsluggoboy
    from SALINAS CA
    Some very nice work
  4. cornfieldcustoms
    cornfieldcustoms
    thanks for the positive comments
    here is the 37 getting ready to head back to indy this morning
    Stogy, AHotRod, wedjim and 3 others like this.
  5. oldsjoe
    oldsjoe
    Mouth watering eye candy Mike SWEET, SWEET, SWEET!
  6. cornfieldcustoms
    cornfieldcustoms
    got the land speed cage all done, here it is out of the car for finish welding. going to ECTA in Wilmington this weekend to have some tech inspectors look over it
    Stogy, 54reno, AHotRod and 1 other person like this.
  7. oldsjoe
    oldsjoe
    That is one GNARLY looking cage Mike! Hope all goes well with the inspection. Joe
  8. wedjim
    wedjim
    from Kissimmee
    Awesome cage! What stood out also, for me, was the steering spear, I mean column, sticking up towards the drivers chest. :) Good thing it all looks so beefy!
  9. cornfieldcustoms
    cornfieldcustoms
    got this 50' ford in a couple weeks ago. has been chopped and a section started. like a lot of crazy sheet metal modified cars, there is a lot of metal work that needs to be redone. so right now i am focusing on the roof area and working my way down.
    making new sail panels. left them long and turned the edges so i can spot weld the inner window channel in place at factory spot welds to cut down on long weld seams
    shape roughed in
    ready for final planish and fitment
    now onto the area above the door. they welded the door tops in the car to make it hard top, the seam was low, and needed some attention. so i decided to make a new skin to replace the seam. again left it long to get the edge turned to spot weld in at factory spots.
    roughed in
    ready for final fit and finish planish
    wedjim, Rich B., Stogy and 3 others like this.
  10. oldsjoe
    oldsjoe
    Been a bit since I've seen ya on here Mike! But this post was worth the wait! WOW! Joe
  11. choptop40
    choptop40
    Can we digitize these contours...
  12. xpletiv
    xpletiv
    from chiburbs
    That's some fine hocus pocus you got going on there!
    I know it can be tough and intimidating to most, but it sure seems like you know exactly what the hell you're doing.
    Always nice work!
  13. loudbang
  14. cornfieldcustoms
    cornfieldcustoms
  15. wedjim
    wedjim
    from Kissimmee
    No worries, your work shows thru, won't matter imo.
  16. cornfieldcustoms
    cornfieldcustoms
    moving around on other projects in the shop. today i worked on a custom 40' ford pick up that was dropped off the other day. lots to do on this one, but today i focused on the head light bucket area on the p*** front fender. the fenders were widened in the past and cut through the head light area. so that needed addressed. instead of taking another fender and cutting that part out and trying to re shape it to work, it is just easier to make the new panel.
    here is the first test fit on the car after putting some rough shape in
    the shape was a little off so had to address that. then moved on to making sure the trim ring would fit right. so i m***ages the panel to fit the trim
    second test fit was much better, still needs a little tuning but it is close
    Stogy, wedjim, pcbart and 1 other person like this.
  17. Rand Man
    Rand Man
    You do good work man.
  18. cornfieldcustoms
    cornfieldcustoms
    thank you
  19. woodbutcher
    woodbutcher
    :D Very nice sir.
    Good luck.Have fun.Be safe.
    Leo
  20. cornfieldcustoms
    cornfieldcustoms
    a little more progress on the head light piece. ended up re making the first one, made some dies for the hammer to put the recess that the head light can sits in. hammered that in the panel and intalled the can and trim. at this point the panel is just sitting there, still needs some fine tuning but turned out nice
  21. woodbutcher
    woodbutcher
    :D Very nice sir.
    Leo
  22. 34toddster
    34toddster
    from Missouri
    Cornfield, cool truck, but WTH do those tires go on?
  23. Champscotty58
    Champscotty58
    Ok, looking at the driver side fender, was this an aborted plan to use Mercedes headlights?
  24. cornfieldcustoms
    cornfieldcustoms
    its a ford truck i am building for a guy, not super hamb appropriate, will have a 429 cammer the Ohio George put together for it
    [​IMG]'
    yea, glad we are going back with the more correct lights
    wedjim, 34toddster and Champscotty58 like this.
  25. nmpontiac
    nmpontiac
    from Taos, NM
    Back on post 229, what did you use for the mesh on that VW/Bugatti hood sides and grille?
  26. nmpontiac
    nmpontiac
    from Taos, NM
    Mike, I'm almost 70 now, and have been messing with cars since I was around 3, but not as a job, more as a hobby. I find these days I have the best times fabbing stuff for my '31 coupe, or for one of the restoration projects I have in my shop now - and wishing I had started doing that kind of stuff much earlier. In my opinion, you've got a great start on becoming one of the best fabricators in this business, just stick with it and I'm sure you could end up like Foose, Boyd, and others of the legends of the hobby. What could be better than doing what you love to make a living?
    loudbang and 34toddster like this.
  27. 34toddster
    34toddster
    from Missouri
    That big meat ***** is too cool I love Horsepower!
  28. cornfieldcustoms
    cornfieldcustoms
    had a really good weekend with our summer metal shaping cl***. here are some pics
    wedjim, loudbang, Stogy and 1 other person like this.
  29. cornfieldcustoms
    cornfieldcustoms
    Stogy likes this.
  30. Dino 64
    Dino 64
    from Virginia
    Fantastic work ! Subscribed.
