HEMI Tech- Ignition
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 5, 2006.
  1. artful dodger
    artful dodger
    this is what I am using on my dodge 270
    72 318 dizzy as mentioned before just drops in,
    so far its the only mod that has worked without slight mods to
    stock 270 stuff…
    To set the dizzy up i took a page from Don Dulmage's book "Old Reliable"
    I used 1 spring from the mopar spring kit and the other spring is the lighter
    of the 2 stock springs from the 318 dizzy
    as per Don's book I will not be running the vacuum advance and
    I will be using the coil and electronic stuff from 4 seconds flat.
    However I could use the mopar electronics too.
    as far as wire 8mm from taylor
    I have not fired this engine up yet
    but i know al will be good.
    keep it simple mopar for a mopar!
  2. GMC BUBBA
    GMC BUBBA
    Guys you need to tear down one of the earlier hemi chrysler -units. Usually a good clean up and lube is all thats needed to make a really good unit.
    You dont need to change any springs as all the chrysler have either bendable spring tension or eccentric pins to hold the springs.
    I have a couple to do up and will write a post covering this adjustment. Actually it can be adjusted even installed on the engine thru a adjustment hole that provided.....
    stillrunners and 30dodgeboy like this.
  3. 73RR
    73RR
    That should help a lot of folks out. Hopefully they appreciate the effort.
  4. 94blackta
    94blackta
    Thanks Fellas!
  5. limp
    limp
    After reading multiple websites I am still confused regarding 392 vs 354 distributors. I believe the 392 distributer shaft is longer by a 1\4" then the 354 shaft. Is this correct? What is necessary to run a 392 unit in a 354? are any adapters available for this?
    Thanks
    Mike
  6. George
    George
    Yes, the 392 is a 1/4" longer , and obviously, you have to shorten it. Cut the 1/4" out & use tubing to connect the pieces. Probably better off getting an LA dizzy & extend the shaft on it. Hot Heads sells the kit with the tubing & screws/pins that is used for lengthening the shaft, could also be used to shorten the 392 shaft. Someone posted that either the B or RB shaft is the right length for use in a 331/354 dizzy ( note: the shaft only, BB dizzy rotates the wrong way).
  7. 73RR
    73RR
    I have heard 'reports' about the tubing deal causing m***ive amounts of shaft run out.......
    It might be easier to cut the end of the shaft down and shape the tang with a good file.
    IMHO, if you just gotta run a 392 dist, and if you have access to a lathe, then make a spacer for the dizzy to sit on...just like MaMopar used to offer for the B vs RB dist swap.
    30dodgeboy likes this.
  8. George
    George
    I ran the extended LA set up for many years on a 331 w/o problems. Forgot about the spacer, same when using a certain Brand X dizzy.
  9. Here is something a little different. I run a msd ready to run in the stock location hooked into a fast efi box for the street. On the track the super mag four and enderle 1100 pump runs off the cam for nitro. I can run both with different timing due to the different fuels. I just leave one turned off. 32 degrees for gas 40 plus for nitro. 20160406_155412.jpg
  10. Godspeed
    Godspeed
    1. Does anyone know if 8mm ignition wire will fit under the stock Chrysler spark plug wire covers (screwed on top of the valve covers)?
    2. I ***ume that the 7mm wire will fit, but maybe I am wrong?
    3. Has anyone had crossfire issues using the stock spark plug wire covers? Any advantage to the 8mm wire in this case?
    Thanks!
  11. I have run my Taylor 8 mm wires under the stock wire covers with no problems for the last 9 years.
    I route them very carefully and screw down the covers gently.
    Godspeed likes this.
  12. 73RR
    73RR
    As HemiDeuce notes, 8mm fits...but it is tight.
  13. George
    George
    I use the Accel black 8mm wires. They fit under the wire covers & are more than long enough.
  14. Anybody have experience making up a set of wires using solid/stranded Packard 440 wire, and the stock Autolite/Chrysler plug wire ends?
    edit--the porcelain ends
  15. Inland empire hot rods
    from so cal
    Bad*** Brian
    Sent from my SM-G973U using Tapatalk
  16. George
    George
    A bit late. I use strait boot generic Accel/Mallory wires. Really don't need the porcelain ends.
  17. hemihotrod66
    hemihotrod66
    Stock small block electronic distributor with a Hot Heads shaft adapter...6AL MSD box 8MM Taylor wires....
  18. George
    George
    You're better off with a longer int. shaft.
  19. X2 on how the factory units are good stuff, I went 9.02 at 147MPH without any hint of misfire - using stock dual points and condenser:
    stillrunners likes this.
  20. Inland empire hot rods
    from so cal
    Anybody ever mount a distributor off timing cover on 392?
  21. Inland empire hot rods
    from so cal
    Hopefully this combo will work[​IMG][​IMG]
  22. willys36
    willys36
    I run a factory LA electronic distributor with an extension tab I gas welded on. Also run an MSD 5 module. I modified stock steel tubes by hammering over the lip to squeeze the stock rubber seals. I use Toyota tube seals with the outer rim cut off. Finally I use Accel yellow wires with long silicone extenders. Works great.
    Hemi2.jpg MSD.jpg P8230084.JPG plug insulators.jpg Rubber shields.jpg tube and clamp.jpg tube and seal.jpg
    30dodgeboy and Brand Apart like this.
  23. George
    George
    I use the generic Accel/ Mallory straight boot wires also, but in black.
  24. willys36
    willys36
    My color scheme is yellow. Picked my sponsor decals to compliment the theme. In fact the whole world should be yellow!
    George likes this.
  25. Inland empire hot rods
    from so cal
    One step closer to front mounting distributor on my 392[​IMG][​IMG]
    High test 63, loudbang and slayer like this.
  26. Inland empire hot rods
    from so cal
    Waiting for distributor [​IMG]
  27. Inland empire hot rods
    from so cal
    One more piece of a big puzzle [​IMG][​IMG][​IMG]
    High test 63, willys36 and slayer like this.
  28. George
    George
    Dizzy on an air raid siren. [​IMG]
    30dodgeboy and slayer like this.
  29. Chrysler's shielded distributor and ignition wires
  30. willys36
    willys36
    That's pretty much the definitive poster child for an industrial setup!!
