Technical 1963 727 Push button
Discussion in 'The Hokey Ass Message Board' started by PA-Sweptliner, Jul 26, 2016.
  1. PA-Sweptliner
    PA-Sweptliner
    Hello everyone, I have found a lot of information about the 64-65 push ****ons buy not much about the 1963 transmission out a Chrysler 300 that I put into my 61 Dodge D100.
    The parking cable is very much out of adjustment and I need some advice to get it back in line.
    Also, does anyone have the schematics if the push****ons?
    Here is a picture of the custom floor mount I made for it.
  2. swifty
    swifty
    I've got a couple of Service Manuals for 1960 Dodge and -I think 1962 Chrysler which have details on adjusting the cables etc on 727's if they are what you are looking for.
  3. PA-Sweptliner
    PA-Sweptliner
    Yeah any factory literature would help. You're in Australia? I found one small tidbit on the parking cable I'm going to try tonight.
  4. JOECOOL
    JOECOOL
    All I remember was the cable was fully extended in reverse, hope that helps.
  5. As far as I know all of the shifter boxes from '62-'65 are the same. Only the ****ons and park levers are different. I used parts from a '63 Dodge, '63 & '64 Chrysler to make mine work. What end seems to be too long? Did the trans end of the park brake cable snap in to the end connected to the park paw? I just did mine a few years ago. But just not remembering an adjustment. Will check tonight and try to report back. Gene.
  6. PA-Sweptliner
    PA-Sweptliner
    Everything was "working" just not as nice as it was before I removed the powertrain. I even left the cables attached to the transmission while I was cleaning the engine up and painting it. So, I got underneath, had my lovely ***istant hold down on the park lever and adjusted the ferrule in and out, trying it each time until it worked. The park lever still does not sit all the way up but it doesn't drop and the pawl actually engages Park so that's much better than it was. Now I can safely install the driveshaft.
  7. PA-Sweptliner
    PA-Sweptliner
    Im glad this worked for now because those cables are saaalty!
