Hot Rods My 32 roadster project
Discussion in 'The Hokey Ass Message Board' started by Hutch built, May 15, 2016.
  1. ronzmtrwrx
    ronzmtrwrx
  2. Hutch built
    Hutch built
    Here's a few shots of the steering column going together.
    1468973979235.jpg I used a coupler with splines on one end and the other side for weld on applications. I machined a flat spot for the lock nut to seat better and so the column tub would clear it.
    1468974357322.jpg I will weld the shaft to the coupler once the final length is determined (after the seat is installed ).
    1468974657190.jpg I machined a taper on the inside of a piece aluminum tubing to match the steering box which makes for a super tight fit. I will drill a tap on the under side for bolts later.
    1468974858151.jpg I machined a step in the tube end for a roller bearing, again this might be redone if I shorten the column.
    1468975013310.jpg I made a hub that I welded another splined coupler to, and which the steering wheel bolts to. 1468975157848.jpg Modified the horn ****on cover so I could use ARP bolts and put a 1932 quarter in.
    Sent from my SPH-L720T using The H.A.M.B. mobile app
  3. Hutch built
    Hutch built
    Stearate by welding a piece of 1/8 x 1 1/4 steel strap to the bottom to use as an attachment point. 1469906188801.jpg 1469906200344.jpg
    Did some work on the ends and the body so it fits nice in this area and filled the lower screw hole as its not needed now since I added the lower mounting point, and it was such a pain trying to get that screw started into the captured nut anyway. 1469906545590.jpg 1469906551249.jpg
    Mounted the gauges and made a stainless spear to add some flare. 1469906645041.jpg 1469906655514.jpg 1469906668400.jpg
    I then added the ignition switch, horn ****on, power plugs, and place for toggle switches for various needs.
  4. Hutch built
    Hutch built
    For some reason this picture didn't come through on the last series.
  5. Thanks again for your lesson. I really enjoy "looking over your shoulder". Amazing workmanship with an eye for detail. You already must have spent hundreds of hours on your roadster, but definitely worth it.
    lothiandon1940 likes this.
  6. loudbang
    Man that is a VERY "Clean" dash design the gauge placement is exemplary.
  7. dirt t
    dirt t
    Hutch on your engine, Are you using a PCV system ? I like the clean rocker covers.
    I wish I was a kid next door and could hang out in your shop. Your son is very lucky.
    lothiandon1940 and loudbang like this.
  8. Hutch built
    Hutch built
    Mr T, I'm using the stock setup which is a breather tube from the back of the block to the air cleaner and a line from the oil filler tube in front to the carb base which has a inline PVC valve.
    lothiandon1940, loudbang and Baron like this.
  9. El Hueso
    El Hueso
    Beautiful, beautiful work!
  10. Hutch built
    Hutch built
    Today I had my son Kyle cut out some circular pieces of sheet metal to use to fill the holes in the inner skin of the trunk. 1470348460107.jpg 1470348470592.jpg 1470348484022.jpg 1470348492970.jpg 1470348498162.jpg 1470348503366.jpg
    loudbang, lothiandon1940 and grumpy32 like this.
  11. grumpy32
    grumpy32
    from Australia
    This is great, love the attention to detail. Can't wait for more.....
  12. lothiandon1940
    lothiandon1940
    It was hurting my neck looking at it before.:D;) 1470348484022.jpg
    OLSKOOL32 and buck 32 like this.
  13. Hutch built
    Hutch built
  14. kdart
    kdart
    I intended on getting a lot done at work today, and then I started browsing this thread...
    Thank you for setting an impossibly high standard of craftsmanship that I will now endlessly try to match! (but most likely fail to meet)
    loudbang and lothiandon1940 like this.
  15. Just Gary
    Just Gary
    This is one of those threads that makes the HAMB truly great.
    Thank *you*, Hutch!
    Baron, lothiandon1940 and loudbang like this.
  16. RoddyB34
    RoddyB34
    Looks great with the Vette covers ,,what brand are the roller rockers to clear the valve covers,(no spacers)
  17. Hutch built
    Hutch built
    They are Comp Cams Pro Magnum roller rockers, the engine builder machines down the threaded ends of the poly locks to shorten them up a bit to fit under the stock valve covers.
  18. nailhead terry
    nailhead terry
  19. chop job
    chop job
    from Wisconsin
    SO What do you do in your spare time?
  20. ronzmtrwrx
    ronzmtrwrx
    Good to see your son getting in on the action. And by the way, that 4 jaw chuck sure is a unique stand base for the shear. Lol.
  21. Super Streak
    Super Streak
    from Florida
    Awesome craftsmanship, it's great to see your son is learning skills. Today most kids would rather waste time with computers games. It one hope that there will be skilled people in the future.
  22. HRK-hotrods
    HRK-hotrods
    @Hutch built, beautiful fabrication work. One of my favorite thing's about the board here. I have a question concerning your hidden roll cage setup. Are you going to tie that into the frame at some point? Reason I'm asking is I've been quietly researching doing something very similar on my roadster but have seen a few people mentioning that they offer zero side impact protection unless welded to the frame and the seats attached to the cage instead of the floor. A few guys made mention of people being pinned inside a wreck or even killed from the cage because of it being bolted to the body. Just wondering what your plans are as everything on your car is top notch.
    Looking forward to updates and now I have a reason to drive out to York next year. Hope to see it there...
    Jackson67 and loudbang like this.
  23. Hutch built
    Hutch built
    Thanks for the positive remarks. I didn't really put the roll bar in for impact protection, though I think it would help, as much as for structure rigidity and connection points for things such as the batteries, gas tank, etc. The bars are welded to a 10 gauge subrail which bolts to the top of the frame and attached to the body itself in various places.
  24. HRK-hotrods
    HRK-hotrods
    Makes sense... Thanks :)
  25. Hutch built
    Hutch built
    Been spending some time on the trunk. I primered both the inner and outer skins leaving an inch of bare metal on each side of where it will be welded. I then tacked it in with my MIG and then finished with my TIG. Then I realized that the bottom hole in the inner skin is there for a reason, to put the latch in, well duh! So I made a removable plate to gain access. Then I reinstalled the trunk and put the tail lights in. 1471094119815.jpg 1471094135421.jpg 1471094150980.jpg 1471094170102.jpg 1471094205692.jpg 1471094220751.jpg 1471094232576.jpg 1471094240811.jpg
  26. kidcampbell71
    kidcampbell71
    ^^^^.... Hutch, I am such an *** man, and your's sir is perfect. That is a stellar car.
    ls1yj, lothiandon1940, cptn60 and 2 others like this.
  27. Hutch built
    Hutch built
    I'm excited to say I'm going to have the roadster in the Jalopyrama show in Westminster Maryland this October. Should be in full mock up and be ready to be blown apart for paint after the show. I rolled outside today and took some pictures. It was nice to see from more the 6 feet away. I think I'm going to raise the back up about an inch to give it a bit more rake, other then that I'm happy with the overall look.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  28. DDDenny
    Stellar work Hutch
    That trunk lid really is nice, really like how you go the extra mile on every part of this car.
    Curious about the e-brake cables and the changes between the two photos.
    I agree on the rear ride height, at least one more inch higher would really look great.
  29. Pewsplace
    Pewsplace
    A stunning example of a Deuce hiboy roadster built with detail and style. Congratulations on you build.
    nunattax and lothiandon1940 like this.
  30. Hutch built
    Hutch built
    The set up is a single cable from a early ford brake handle and then connects to two cables going to each rear drum brake.
