Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    Well, there she sits with the fenders on and done for the time being.
    Going to take them off and move on to the next few tasks before I can take it all apart and get parts off to the chrome shop etc.
  2. 26 T Ford RPU
    26 T Ford RPU
    They sit real nice, Larry.:cool::cool: JW
  3. Looks great Larry.
    Nice to see that light at the end of the tunnel.
    Don't you want to drive it before you tear it apart? :p
  4. brad2v
    brad2v
    Looks fantastic Larry
  5. Blue One
    Blue One
    from Alberta
    Thanks everyone. As far as driving it goes, as much as I'd like to do so I know enough about myself to know that if I put it together and start driving it, it might never come apart for paint and end up looking ratty :eek::D
    Heaven forbid :D:D
  6. 26 T Ford RPU
    26 T Ford RPU
    Can't have ratty. Im about to pull my RPU apart and im finding it very hard. JW
  7. Blue One
    Blue One
    from Alberta
    It's in the details so they say :)
    Heres a small one to prove that I have been doing something :D
    The dilemma was a way to cover the removable steering wheel hub.
    If you cover it then you can't get at the collar to remove the steering wheel :confused:
    The solution I came up with is a cut down cup from a Stanley thermos.
    It ends up being a tiny bit larger than the Ididit steering column but still fits the hub and looks good.
    A ring welded to the bottom edge of the cut down cup and a couple of finger holes added to release the wheel.
    A skin of filler and a bunch of sanding for paint. :D
    20160731_113139.jpg 20160731_113245.jpg 20160731_113828.jpg 20160731_113838.jpg
    BradinNC, loudbang, brad2v and 3 others like this.
  8. 26 T Ford RPU
    26 T Ford RPU
    Nicely done.:cool: JW
    The 39 guy likes this.
  9. Blue One
    Blue One
    from Alberta
    And :D the fenders have found a home for the foreseeable future :D
    Until I decide to finish and mount them if that day ever comes ;) :D :cool:
    Building them was a fun exercise,
    and they are available if I want to use them. :cool:
    Paul, loudbang and AndersF like this.
  10. Blue One
    Blue One
    from Alberta
    Spent some time today fabricating a rather complicated little device. :D
    There will be 2 of them and they will mount behind the kick panels down by my feet.
    Can you tell me what they will be? :D
  11. rusty rocket
    rusty rocket
    A place to hide your weed when you drive back from Colorado?
  12. DDDenny
    Anti-Theft device.
  13. Tim_with_a_T
    Tim_with_a_T
    I did something very similar with an exhaust reducer. I think yours looks more refined- nice job!
    Blue One likes this.
  14. Blue One
    Blue One
    from Alberta
    Poor guesses so far. :D Think keeping the doors from hitting the lakes headers :D
  15. 26 T Ford RPU
    26 T Ford RPU
    Door checks strap type of thingie. JW
    whiplash1923T and loudbang like this.
  16. rusty rocket
    rusty rocket
    Im telling you its your weed holder!
  17. Blue One
    Blue One
    from Alberta
    Right you are, and they will be self retractable too. :)
    Too small, wouldn't hold near enough :D
  18. rusty rocket
    rusty rocket
    Ha. I know a few people That would have a pickup box full and it wouldnt be enough!
  19. Blue One
    Blue One
    from Alberta
    The only leafy greens I partake of are in my salad or on my burgers :)
    Bugguts, loudbang and 26 T Ford RPU like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    Good answer:cool::cool: JW
  21. rusty rocket
    rusty rocket
    I hear ya. I'm already dumb enough without the help of THC!
  22. Blue One
    Blue One
    from Alberta
    Well, back at it. I finished the passenger side door check strap.
    A small modification to the spring retractor****embly I had built was needed.
    I had allowed for 3" of travel and had to reduce it to 2".
    I got some nice smooth and strong thick weight 1" nylon webbing from the outdoor supply.
    The retractor mounts to the framework I built to hold the ABS kick panel.
    It works well. Nice and clean and the door will not hit the header now.
    That will help once it's painted.
    Another thing that pleased me was the way the door functions.
    I wasn't sure how the strength of the springs I used would work out.
    As it turned out, they work nice and smoothly, the strength of the spring is enough to retract the strap properly but not enough to actually pull the door away from any position from partially to fully open.
    Having a flat strap barely visible when the interior panels are in place will be nice.
    Now for the drivers side :)
    20160806_184502.jpg 20160806_184528.jpg 20160806_184741.jpg 20160806_184905.jpg
  23. Absolutely brilliant idea sir, great ideas like that should be patented quickly before the rodding world sees it.:):)
  24. Dick Stevens
    Dick Stevens
    Well done, that is a great solution for potential problems and it looks good too!
  25. Blue One
    Blue One
    from Alberta
    Finished the drivers side, and now I will move on to cutting and fitting the ABS plastic kick panels and door panels.
    I also have to figure out side panels with arm rests beside the seats and the wrap around panel behind the seats.
    Should be fun.
    After that unless I come up with something else, it's take her apart time :)
  26. Blue One
    Blue One
    from Alberta
    The first interior panel is made and snapped into place.
    1/8" abs plastic and you can see the cutout and glued on cover for the door check strap to operate freely.
    Works good and is ready for upholtery later. :cool:
    Larry.
    AndersF and loudbang like this.
  27. K13
    K13
    Nice work Larry. Where did you pick up your abs sheet from?
    Sent from my HTC One_M8 using The H.A.M.B. mobile app
  28. Blue One
    Blue One
    from Alberta
    Thanks
    I buy it at Johnston industrial plastics here in Edmonton.
    They sell a 4x8 sheet for a reasonable price unlike some other places that ask about twice as much.
    http://www.johnstonplastics.com/
    K13 likes this.
  29. Bugguts
    Bugguts
    I just finished the whole thread. Great job on the project. Really enjoyed all you documented and like the way it's turning out. Thanks for sharing the good and the bad. Going to be lots of fun when finished.
  30. Blue One
    Blue One
    from Alberta
    One door panel made and snapped into place. :cool:
    And an edit, I finished the driver's door panel too. :)
