Technical How to attach acorn nut covers for flathead head bolts?
Discussion in 'Traditional Hot Rods' started by djmahle, Aug 1, 2016.
  1. djmahle
    djmahle
    from Minnesota
    I am finishing up a Model A roadster that has an 8BA flathead from a 50 Ford. The engine came with some die cast chrome acorn nut covers for the head bolts that were never installed. . They are a rather loose slip fit so I was wondering what others have done to keep them in place. A dab of silicone? Liquid Nails? Any suggestions appreciated. Thanks
  2. 19Fordy
    19Fordy
    Just a dab of silicone works fine. These have been on 20 years.
    dan c likes this.
  3. Yep that's what I have done in the past. Works like a champ. ^^^^^
  4. Kan Kustom
    Kan Kustom
    Always wondered this myself , knowing you have to remove them some time for repairs, paint ,etc.
  5. jcmarz
    jcmarz
    from Chino, Ca
    Liquid Nails:rolleyes:
    falcongeorge likes this.
  6. 4dFord/SC
    4dFord/SC
    RTV works too.
  7. cs39ford
    cs39ford
    That's the fix
  8. 19Fordy
    19Fordy
    Remember, Just a little dab will do ya. Don't go nuts.
  9. Kiwi 4d
    Kiwi 4d
    Even the plastic covers you can give a little squeeze in your vice and it doesn't seem to mark them and they hold the new shape. Or as said silicone.
  10. CME1
    CME1
    I too have used a little dab of clear silicone on the Acorn Nut Covers, works like a champ! Cleans up easy when you need to remove them. Cool thing is we all have a tube of silicone in our tool chest!
  11. i.rant
    i.rant
    I used to tap one edge with a center punch after they were installed.
  12. Mike51Merc
    Mike51Merc
    Some dum-dum, ribbon caulk, or electrician's putty works great, is reusable and doesn't harden like glue or silicone.
    I used to peen one side with a center punch before I discovered the putty method.
  13. Gene Boul
    Gene Boul
    I tried RTV on my nut covers, big mistake. Burned like a *****....dam-it!
    1927graham likes this.
  14. elmitcheristo
    elmitcheristo
    I use a paper match. Slide it on with the match and rip off the remainder.
  15. 3340
    3340
    Compressed with soft jaws slightest pressure in vise.
  16. Jeff34
    Jeff34
    Pun intended?
    Atwater Mike likes this.
  17. Bearing Burner
    Bearing Burner
    from W. MA
    It's a lot easier to use acorn nuts.
  18. ct1932ford
    ct1932ford
    Hi temp silicone! Just a dab!!
  19. HOTRODPRIMER
    HOTRODPRIMER
    Strange but the ones I had were so tight I used a rubber mallet and tapped them in place. HRP
  20. LOWDUG37
    LOWDUG37
    same here
  21. Atwater Mike
    Atwater Mike
    The pre-'48 nuts are larger than the '49-'53 bolt heads by a few thousandths.
    Acorns usually fit the nuts tight, were loose on the bolts.
    As Pocono Region Mike said above, I used plumbers' dope. (it was in 1956!)
  22. Mike51Merc
    Mike51Merc
    Yeah, but plumber's putty hardens like a rock. Electrician's putty stays pliable.
