Who makes a GOOD brake line tubing bender and flaring tool?
Discussion in 'The Hokey Ass Message Board' started by Wowcars, Mar 16, 2006.
  1. Wowcars
    Wowcars
    Looking at buying a new line bender and I know that there are some out there that have a much tighter and nicer bend, also ones that allow bends close to flares. Also want a new flaring tool. If I remember right you can get kits that do inverted, single flair and A/N flares, does anyone know who makes/sells these? Thanks.
  2. Mule Farmer
    Mule Farmer
    from Holland MI
    Ive got a ridged flare and double flare set that works great. still looking for a tube bender that I like.
  3. LongT
    LongT
    I have a Rigid Tool AN flaring tool. Worked good for me. The Speedway one that I had was difficult to use and broke. I think the Rigid was about $100 from Inline Tube. Probably have local suppliers too.
    Bill
  4. Kurt
    Kurt
    My bender for larger tubing is the plier type with the round dies that you can change. I also have a 3/16" bender for brake lines that grabs it right by the flare nut for tight bends. It came from the MAC Tool man. NAPA for the flaring kit. Had it all for years.
  5. 392_hemi
    392_hemi
    I got the double lever Imperial benders that are sold by Rigid. They're the nicest I've found. Only real down side is that they're single size, so if you want to do different size tubes, you have to buy multiple benders. And they're not cheap, so cost might be an issue too. For flare tools, the Mastercool hydraulic flare tool is the way to go, but they're about $300 (check thetoolwarehouse.net).
  6. Deuce Roadster
    Deuce Roadster
  7. Deuce Roadster
    Deuce Roadster
  8. willowbilly3
    willowbilly3
    from Sturgis
    My double flare tool is a K-D and uses an insert to set the first stage. It works weel but doesn't fit in the tool box very well
  9. man-a-fre
    man-a-fre
    My rigid flaringtool and bender has served its purpose well.
  10. Sam F.
    Sam F.
    my dad has a Snap-on double flaring set that is about as old as i am and i have used it on every car ive ever flared any line on,,still works perfect,,,not sure about "new" snap-on stuff though,,,
  11. diggermike
    diggermike
    from sachse,tx
    At our shop we use a bender made by "Imperial" it's called the "little imp".. It is the smallest bender they make, that I know of. There are three different sizes one the one bender - 3 1/16", 1/4", & 5/16" with about a 1" to a 1 1/4" radius. Imperial also makes flaring tools. The nicest one i've seen, belong to a guy that did work for us. It did single 37degree AN flares, and standard double flares all in one nice plastic storage case. Might check out there website.:cool:
  12. chopolds
    chopolds
    from howell, nj
    Agree with most of the others. Rigid for a double flaring tool, they are great, if doing fouble flares, the cheap ones won't cut it!
    Imperial Eastman for benders. Both available from McMaster Carr.
  13. long island vic
    long island vic
    master power makes a double flare that does ac lines also ,works great its about 3 bills
