Projects the '27 Roadster saga
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 20, 2010.
  1. mad mechanic
    mad mechanic
    Now that sir is just pure hot rod and pure ***! Your a very skilled man with the right eye to detail. [emoji106][emoji122][emoji122][emoji122]
    Paul likes this.
  2. F&J
    F&J
    Thanks for the info. Either I forgot that, or did not know. I do recall taking pics of all the inputs lined up when I had a 37 and a 50 from a local elder that ran at the old airport drags in the 50s. I think I recall a noticeable 45 degree chamfer of the front of splines.
    My 37 had a syncro cage that fell apart, and I think it's maybe one year only? I used a 50 synco but that forced me to use the mating 50 input, AND then the 50 syncro size made me need to use the 50 2nd gear...arrrg.
    I never developed a good vibe on LaSalles, and find them to harder to work on and source parts like the one-year candlestick, etc. But that skinny rounded main case top sure can make nice room for the heel of your foot on the gas pedal.
    all this info is getting lost to the ages it seems.
    Paul, falcongeorge and greaser like this.
  3. Paul
    Paul
    Editor
    just plain old Model A's with sealed beam conversions
  4. Paul
    Paul
    Editor
    Frank,
    I misspoke, the LaSalle input shaft is not longer
    but it needs about a quarter inch more room or a chamfer in the pilot bearing,
    the Olds input has a flat step at the end of the splines
    whereas the LaSalle is chamfered with a shorter bearing surface at the pilot.
  5. falcongeorge
    falcongeorge
    from BC
    They looked smaller than that in the photo, must be the angle I guess.
    dana barlow and Paul like this.
  6. Paul
    Paul
    Editor
    the projected 3 hour job turned out to be 4-1/2 hours.
    it shifts nice and moves under it's own power.
    only drove it about 50 feet and back at an idle, still no throttle pedal yet.
    but I do have a plan in my head for one now.
  7. falcongeorge
    falcongeorge
    from BC
    Paul, I thought you were using a disc from some International pu application?Was that someone else?
    Paul likes this.
  8. Paul
    Paul
    Editor
    I put that one behind the '58 J2
    it looks to be a perfect fit.
  9. falcongeorge
    falcongeorge
    from BC
    Ok. I can run a Ford pattern long pressure plate with an IH disc and a cad throw-out bearing with mine, right? I have a side-shift cad box with the steel flywheel and bell housing I got from you.
    Paul likes this.
  10. Paul
    Paul
    Editor
    Centerforce 381040 disc only through Summit
  11. falcongeorge
    falcongeorge
    from BC
    Summit lists it as "not available", is that a clutch and diaphragm pressure plate? A couple other websites list it, and a couple others list it as back ordered, looks like a good possibility they aren't making it anymore.
    The only other 1.25x10 spline 11" disc summit lists is a McLeod race disc with an unsprung hub and no marcel, that's a non-starter for a comfy street rod with tall tires and a 3.78 rear gear...:(
  12. Paul
    Paul
    Editor
    hmm..
    there must be a replacement..
  13. Paul
    Paul
    Editor
  14. Dragrace66
    Dragrace66
    Great sound and the Ford looks great. Love 27's Hot Rods.
    Paul likes this.
  15. Paul
    Paul
    Editor
    put a throttle pedal together today,
    laid it all out on poster board to check geometry,
    dug through my junk pile for rod ends and some bits of s**** metal,
    I wanted to use a regular gas pedal, I have a nice NOS piece
    but it wasn't to be.. so..
    I stole a s**** from the kitchen and chopped off the business end,
    to use for the business end,
    cut, grind, weld, drill and bolt,
    and now have a right foot to four carburetor connection.
    drove it around the block a couple times,
    action and ratio are just about ideal :)
  16. Paul
    Paul
    Editor
    also started to do something with the top of the steering column,
    I'm using a wheel made by our very own Kevin Lee.
    it mounts to a typical three bolt aftermarket adapter.
    my F1 column didn't have a top bell
    so I went to the grocery store and bought some measuring cups,
    the half cup size looked like the least amount of work to fit,
    so I removed the handle and used a hole saw to make a hole for the column to poke through.
    'need to figure a clean way to attach it
    but here it is taped in place..
  17. mad mechanic
    mad mechanic
    You'm a gert talented gent ain't ya?!
    Excellent ideas and well thought out from design through to construction...
    Not that you need it ideas but....how about sprung bent tabs to fit the column top the steering wheel?
    Jay
    Paul likes this.
  18. Paul
    Paul
    Editor
    I'll stew on it for a bit,
    not really high priority right yet.
    I did pull the valve covers to adjust the valves,
    saw evidence of at least four rockers touching the covers..
    I don't think any damage was done to the valve train
    and the chrome still looks good on the outside of the covers
    but definitely left marks on the underside of the covers.
    adjusted all the valves, they were fine, maybe a touch tight on a couple,
    .018 intake, .02 exhaust.
    swapped out the dimpled covers for the Holmes with breathers.
    I wanted to use the dimpled covers,
    thought it odd that the Isky rockers hit the (Isky) covers..
    but gotta do whatcha gotta do..
    tried my uni-syn carburetor tool,
    I don't know why I even keep that damn thing
    it's a piece of junk..
    so I adjusted the carbs by ear and eye.
    same with the timing,
    by how it sounds and feels.
  19. falcongeorge
    falcongeorge
    from BC
    If a couple were hitting the valve covers, that's what I was hearing in the video.
    Paul likes this.
  20. falcongeorge
    falcongeorge
    from BC
    Paul, do you have a shot bag or sand bag? Why don't you try hitting the underside of the valve covers where the witness marks are with a round nose punch on a bag? Use a punch or make one that is a good match for the radius on the backside of the clearance bumps. Go easy, and you can possibly gain enough clearance to run them without damaging the chrome? Or double up on the gaskets?
    Paul likes this.
  21. Paul
    Paul
    Editor
    Yeah, I thought about doubling up the gaskets, not going to beat on them though, tough to find them in this nice of shape,
    Even now with witness marks.
  22. vtwhead
    vtwhead
    ditto on that uni-syn! Never could get it to work like the video showed. It has sat on the shelf now for 5 years.........
    Paul likes this.
  23. Paul
    Paul
    Editor
    drove around a bunch today,
    making minor adjustments to carburetors and timing
    all by ear.
    'first time trying to tune four 97's naturally aspirated
    only other time I ran four Strombergs was on a blower,
    a little different here,
    but it's getting closer all the time.
  24. Paul
    Paul
    Editor
    behaving better all the time,
    starts easy, idles good,
    has never overheated,
    inside tailpipe is turning from black to grey
    second set of plugs looks very good,
    changed out the oil a tank ago and it looks good too,
    clutch behaving nicely.
    I tried to make a video of driving around town,
    but it was during rush hour, so it's far too boring to even upload.
    I'll try again tomorrow on a back road or two
    Jeff34, mad mechanic, greaser and 4 others like this.
  25. Awesome! I love your driving videos. Great motivation.
    Paul and greaser like this.
  26. atch
    atch
    nice; very nice. excellent vision and workmanship. congrats.
    Paul likes this.
  27. Paul
    Paul
    Editor
    here's that video, 'bout as long and boring as one might expect
    Blue One, Drewfus, AHotRod and 6 others like this.
  28. Paul
    Paul
    Editor
    just watched it for the first time,
    seventeen and a half minutes of quick-change whine and sheet metal rattle..
    If that's not enough incentive to put a few screws and sound deadener in then I don't know what is..
  29. Thommyknocker
    Thommyknocker
    from Colorado
    Paul likes this.
  30. greaser
    greaser
    Paul, I only heard one gear change to bring it up to cruising speed. Were you starting out in second gear, or maybe the speed shift was undetectable? HA! Thanks for the ride!
    Paul likes this.
