Customs Merc chop progress with compiled project pics
Discussion in 'The Hokey Ass Message Board' started by Verbal Kint, Jun 1, 2009.
  1. Coming along nicely. I haven't seen those mufflers since I was a kid.
    And that was a long time ago! !
    Kustomkid likes this.
  2. Kustomkid
    Kustomkid
    from Montana
    Not sure if the mufflers will improve a 265 performance.
    ImageUploadedByH.A.M.B.1468550058.441715.jpg ImageUploadedByH.A.M.B.1468550068.074073.jpg
  3. Kustomkid
    Kustomkid
    from Montana
    Got the exhaust cutout installed on the rear driver side k-member and got the hanger installed for the muffler. ImageUploadedByH.A.M.B.1468787847.336331.jpg ImageUploadedByH.A.M.B.1468787876.035738.jpg ImageUploadedByH.A.M.B.1468787887.503377.jpg
    This stuff came off the original frame for the merc. So the muffler is hanging is I can bend up the other tail pipe. ImageUploadedByH.A.M.B.1468787992.495014.jpg
  4. Kustomkid
    Kustomkid
    from Montana
    Got to finish tweaking the tail pipes to get them in the right spot. ImageUploadedByH.A.M.B.1469065442.609146.jpg ImageUploadedByH.A.M.B.1469065454.257818.jpg
    And I got holes cut in the bumper for the exhaust tips. Found this car on kustomrama.com that was done in 1953. Philip Sauers merc has round tips thru the bumper.
    ImageUploadedByH.A.M.B.1469065904.376096.jpg ImageUploadedByH.A.M.B.1469065913.262755.jpg
    So mine will too.
    ImageUploadedByH.A.M.B.1469066007.516895.jpg ImageUploadedByH.A.M.B.1469066018.834837.jpg
    drdave likes this.
  5. Kustomkid
    Kustomkid
    from Montana
  6. Kustomkid
    Kustomkid
    from Montana
  7. Verbal Kint
    Verbal Kint
    from Washington
    Nice work, the Pontiac won't be that complicated...
  8. Kustomkid
    Kustomkid
    from Montana
    Tail pipes are in. ImageUploadedByH.A.M.B.1470015691.310189.jpg ImageUploadedByH.A.M.B.1470015703.158264.jpg
    tomkelly88, drdave and jalopykid like this.
  9. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    looking good Ryan!
  10. Kustomkid
    Kustomkid
    from Montana
    Mercs ready to come off the lift tomorrow. Now to fire up the engine!!! ImageUploadedByH.A.M.B.1470457109.331198.jpg
    robber grin, Ol Deuce and drdave like this.
  11. Peanut 1959
    Peanut 1959
    I like the exhaust through the bumper.
    robber grin likes this.
  12. Kustomkid
    Kustomkid
    from Montana
    Mercs back out, next I got to remove the front clip to fix the bent frame horn and get the motor running!!! ImageUploadedByH.A.M.B.1470589485.953892.jpg ImageUploadedByH.A.M.B.1470589504.200848.jpg ImageUploadedByH.A.M.B.1470589519.953890.jpg ImageUploadedByH.A.M.B.1470589534.514740.jpg ImageUploadedByH.A.M.B.1470589545.436077.jpg ImageUploadedByH.A.M.B.1470589555.988390.jpg ImageUploadedByH.A.M.B.1470589577.991269.jpg ImageUploadedByH.A.M.B.1470589586.575291.jpg ImageUploadedByH.A.M.B.1470589596.373470.jpg ImageUploadedByH.A.M.B.1470589605.458314.jpg
    robber grin, Stogy, cretin and 6 others like this.
  13. Kustomkid
    Kustomkid
    from Montana
    So if anyone was wondering about a replacement master cylinder for the merc that will bolt on, well I found one. Dorman m2796 for a 66 jeep. 1 inch bore and mounts thru the side. [​IMG]
    New master along with the Mercs master cylinder [​IMG]
    And bolted on the car with spacers for the automatic pedal. [​IMG]
    And the automatic brace. [​IMG][​IMG]
    tomkelly88, Ol Deuce and drdave like this.
  14. Kustomkid
    Kustomkid
    from Montana
    End up getting the new gas pedal hooked up so that works. Found my overdrive cable so I'm going to see if I can make it work for the choke. Slowly getting some of the little things done....[​IMG]
    Stogy, drdave and Ol Deuce like this.
  15. Kustomkid
    Kustomkid
    from Montana
    Anyone out there have a pair of Appleton 552s they don't need? Got to locate a set. The merc is looking alittle naked with out them.[emoji6]
  16. drdave
    drdave
    I'm sure you know this, but I see them come up on eBay pretty regular. That's where I got both my sets.
  17. Kustomkid
    Kustomkid
    from Montana
    Yeah, i was looking on there. They are expensive![emoji15] Did you find your hirohata rear view mirror? I'm going to a junk yard in the middle of September that has a few 54-56 Cadillacs.
  18. drdave
    drdave
    Sure enough, they are not cheap. I can encourage you in this though....I have looked at lots and lots and lots of 552's and 112's on "nice" customs and lots of historical ones, and very few have I ever seen that were "brand new" perfect chrome with no pit or scratches. So, what most folks consider "driver" quality is plenty good enough....no sense paying top dollar for perfect ones. ;)
    Yes, I did finally find a Caddy mirror. I have a dream though of cutting and shortening it a little though so it's higher up on the windshield and not taking up so much of the field of view. Not sure how I can do that to pot metal though and get it to stick back together well and be able to be rechromed.
  19. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Nice work on the updates.
    FYI; regarding the exhaust tips-the Phil Saures Merc was found and owned by HAMB member 51 mercules.
  20. Kustomkid
    Kustomkid
    from Montana
    I got the correct spacers for the master cylinder. So those are installed. [​IMG][​IMG]
    To chop,or not to chop. That is the question.
    Stogy likes this.
  21. Kustomkid
    Kustomkid
    from Montana
    The exhaust is finally done! Got a hole though he frame and driver side head pipe is in. Next to fire her up![​IMG][​IMG]
    And got these coming...[​IMG][​IMG][​IMG]
    Stogy likes this.
  22. Kustomkid
    Kustomkid
    from Montana
    Is there anybody out there that would have a extra set of the L999 and L997 or L990 and L991 mounting brackets for the appletons?
  23. drdave
    drdave
    I got lucky and one of the brackets that came with the set of spots I got was the 997. I ended up getting a 999 from Bob Birch at Accessory Land. He might have another one left. Super great guy and very helpful, give him a shout.
  24. Kustomkid
    Kustomkid
    from Montana
    I searched the online and can't find accessory land?[emoji20]
  25. Atomic Kustom
    Atomic Kustom
    Bob at accessory land has the L-999 that are NOS. Give him a call 563-556-5482
  26. drdave
    drdave
    Beat me to the punch with the number. [emoji846]
  27. Kustomkid
    Kustomkid
    from Montana
    Here is what I got, a pair of rechromed 112's. One light has most of the marking gone but the other is good. Has sealed beams in them but the wiring is gone so they need some work.
    [​IMG][​IMG][​IMG]
    drdave likes this.
  28. drdave
    drdave
    Nice! Dunno what to suggest about the stampings. Maybe an engraver? Most folks would never notice, though. ;)
  29. Kustomkid
    Kustomkid
    from Montana
    Yeah I'm not to worried about it. But they sure look good. Can't wait to get them mounted!
  30. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
