Technical Traditional-looking self-cancelling indicator idea
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, Aug 7, 2016.
  1. Ned Ludd
    Ned Ludd
    Here's something I've been mulling over.
    Modern control stalks certainly don't suit the look of many traditional interiors. Many early indicators had dash-mounted or under-dash switches, but they were as a rule non-self-cancelling. A simple chrome stalk with a small period knob on the end of it emerging from under the dash can look the part, but how to get it to self-cancel?
    I'd looked at linkages but they ended up being far too fiddly. But how about gearing the cancel-signalling function from the column? But what to use for gears? Industrial right-angle drives are either too heavy (and expensive) or the shaft bores are too small. Distributor drive gears looked promising, but a motorcycle front-hub speedometer cable drive fits the bill perfectly. Many have a ratio between 2:1 and 3:1, which would smooth out the self-cancelling, giving more than a turn before the indicators want to self-cancel, and a longer ramp in the opposite direction before triggering the mechanism.
    Here's what I have in mind: indicator idea edited_zpshhca90lf.jpg
    The exact action would depend on the choice of switch. An early VW switch would give down for left, up for right, and towards the column for beam dipping.
    There is an animation of the self-cancelling action here. Unfortunately the site doesn't want me to hotlink it.
    Any use?
    Stogy likes this.
  2. Ned Ludd
    Ned Ludd
    Here is a suitable speedometer drive:
    The axle hole will just fit a ¾" column.
    Stogy likes this.
  3. Rusty O'Toole
    Rusty O'Toole
    Did you know some English cars from the fifties had a clockwork switch on the instrument panel? Turn it and the trafficators engage, when the time runs out the switch turns itself off.
    It would also be possible to use an electronic pickup on the steering arm and make a self cancelling switch with no connection to the steering wheel.
    Stogy and VANDENPLAS like this.
  4. Ned Ludd
    Ned Ludd
    Early Series MM Morris Minors had the clockwork thing, if I remember correctly. The electronic version would be cheating, though!
    Stogy likes this.
  5. DDDenny
    Ned
    If my post is contrary to the intent of this thread; I will respectfully delete it.
    I know this isn't totally kosher for the "card carrying traditionalists, but I too never liked the looks of column mounted t/s switches in hot rods. I built this car with a minimalist POV but also thought the whole arm hanging outside, over the door deal looked a bit lame.
    I made an aluminum holder to mount two line/loc switches on my Hurst shifter handle.
    The rest is controlled by a hidden "little black box" that is an adjustable controller.
    hfh, Stogy, motoklas and 4 others like this.
  6. BJR
    BJR
    As kid in the 50's I remember some aftermarket turn signal switches that had a rubber wheel on the column side of the switch that would ride on the shaft in the steering column. You would have to cut a slot in the column jacket for the wheel to go through to reach the shaft. It would self cancel as the steering wheel was turned, just like the factory ones.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Why try to re-event the wheel?
    Autolite 9000 made a turn signal with a self canceling wheel,it rides on the edge of the steering wheel. HRP
    motoklas, winr, Stogy and 8 others like this.
  8. Marcosmadness
    Marcosmadness
    There use to be an aftermarket product sold to the British Car crowd that used a timing out relay to cancel a traditional turn signal. As I recall, the timing length was adjustable. Not sure if they are still being sold.
    Stogy likes this.
  9. Doc.
    Doc.
    There are aftermarket kits that have self cancelling turn signals. The have an adjustible timer that lets you choose how long before they go off. You can activate the turn signals however you like. I used this setup on an off topic vehicle a few years ago and used two push ****ons on the dash for left and right turn signals.
    Stogy likes this.
  10. mickeyc
    mickeyc
    Harley motorcycles use a small black box that controls the turn signals
    and will self cancel after a preset amount of time. I do not think it is adjustable but might be useful to adapt for the purpose you mention.
    gnichols, Stogy and Bob Lowry like this.
  11. wsdad
    wsdad
    I really like the clock work idea!
    Stogy likes this.
  12. If the Harley unit is the same as those on most bikes, there is a reed switch that counts speedometer cable revolutions, and cancels after so many revolutions. That way, the signal won't cancel if you're waiting for a light to change.
    Cosmo
  13. BuiltFerComfort
    BuiltFerComfort
    The rubber wheel that turns on the column gets hard and slips after a while. Maybe there's some way of refurbishing the rubber wheel? Or adding a stickier something to the column?
    I drove an old Chevy with broken cancel mech on one side. Took off the wheel, broke the other canceller trying to see how it worked - old brittle plastic. That's when I just found a louder solenoid to remind me, and remembered to cancel them myself.
    Stogy and lothiandon1940 like this.
  14. cretin
    cretin
    This box uses the concept he's talking about.
    http://www.speedwaymotors.com/Turn-Signal-Module-4-Bulb,2366.html
    I use these all the time. I hide stainless flush mount momentary ****ons that I get from McMaster Carr. You get self cancelling turn signals, and hazard flashers, with no ugly switch.
    winr and Stogy like this.
  15. Imwalkin
    Imwalkin
    from Tucson, Az
    I like to use early vw bug steering columns and turn signal switches. Nice and clean switches that cancel. I use vw steering wheels but a adapter is made so you can run a three bolt steering wheel.
    winr, Stogy, southerncad and 4 others like this.
  16. The part that actually rotates to spin the cable is that outer flat washer with the tang on it; the axle doesn't turn. The tang engages a hole or slot on the wheel, and the wheel turns the washer which in turn spins the cable. It would be possible to use this, but the install wouldn't be as clean as you envision. You can get ratios from 1:1 on up to about 3:1, depending on the OEM manufacturer.
    It's not just Harley that uses these, they've been around in various designs since '78 on Japanese bikes. Some use a reed switch (generally with a mechanical speedo), some get a signal from electronic speedos. Most actually do a speed/distance 'calculation', varying 'on' time by how fast and far you've gone. The main problem (if you can get past the issue of a suitable input signal) is they're load-sensitive; use anything other than the 'factory' load and they can work poorly or not at all, so changing lamp types or number of lamps is usually out. They're also very touchy about poor connections.
    Stogy and Ned Ludd like this.
  17. And I forgot to mention that motorcycle speedo drives don't offer gear reduction, but multiplication, so a 1:1 ratio would be the 'slowest' ratio available. One turn of the input will result in one or more turns of the output.
  18. And while we're discussing using motorcycle turn signal bits, I'll throw out one more tip. Motorcycle turn lamps are both slightly brighter and more heavy-duty than 'standard' automotive lamps. While an incandescent automotive turn/brake type is usually rated at 23 watts, most motorcycles (Harleys, at least older ones in particular) use 27 watt lamps with reinforced filaments to resist vibration. Only available from motorcycle dealers (at least I've never found them anywhere else), but will fit in place of 'standard' lamps. Cost is used to be about double of an automotive lamp... it's been a while since I bought any.
    Stogy likes this.
  19. Ned Ludd
    Ned Ludd
    Thanks for the input, Steve. I tried to get an idea from photos of a dis***embled unit. The best photo I could find seemed to show something between a fast worm drive and a helical drive like a distributor gear, but I couldn't really tell. And the axle hole thing did seem a bit odd, though I took the tang to be some kind of locator on the fork or brake. Thanks for clearing that up.
    Stogy likes this.
  20. Kerrynzl
    Kerrynzl
    I've used the top outer half of an early Austin Mini 850 steering and spliced it into my Lotus Cortina Race Car steering column [it slipped tightly over the Cortina column and was spot welded]
    It was a neat little unit with a plastic casing that looked similar to bakelite, and had L&R , high and low beam, and the horn ****on on the same stalk.
    In my situation the self cancelling cam on the column was press on and also the same size
    Edit [ I found this photo below]
  21. Fabber McGee
    Fabber McGee
    Steve, I think the bulb number you were talking about is probably 198. The truck shops sell them and they are the same as 1157 but have the heavy duty filaments to resist shaking apart while bouncing down a rough gravel road going back for another load. They are brighter and last about forever. Of course now most of the trucks have gone to the rubber mounted sealed lights that also last about forever and can be changed out at the scales with no tools. I usually buy them by the box of 10 and I don't think they are significantly more expensive than 1157's when purchased that way.
  22. Fabber McGee
    Fabber McGee
    Also, now that I think about it, It seems like I decided that on my last Harley (2003 Road King, a retired cop bike) the self canceling turn signals must have had a lean sensor. As I recall, the signal would stay on for blocks or minutes or whatever unless I leaned the bike to make a turn. When I stood it back upright then they would cancel. Seems like I wondered about that for a week or two and it was sort of an epiphany when I finally figured out how it was deciding to turn off the damned blinker. Ha,ha.
    Hnstray likes this.
  23. upspirate
    upspirate
  24. BrandonB
    BrandonB
    from nor cal
    These are traditional and work really well.:D
    Stogy, Bob Lowry, flyin-t and 2 others like this.
  25. Ned Ludd
    Ned Ludd
    They're not internationally universal, though. I believe in the Commonwealth tradition - mostly right-hand drive - it's right hand extended for right turn, right hand raised for stop, and right hand downwards and "stirring the pot" counterclockwise for left turn. So few people nowadays know what the hand signals mean at all, never mind what they mean in the specific country they're in.
    Stogy likes this.
  26. gnichols
    gnichols
    from Tampa, FL
    Like this idea! Thanx, Gary
    Stogy likes this.
  27. Not so much these days... They don't teach these signals anymore (at least locally they don't), so under-30s just wonder why you're waving your arm around.
    Stogy, A Boner and hotrodharry2 like this.
  28. TagMan
    TagMan
    Last time I tried to use hand signals, several people signaled back.......with an extended middle finger - go figure????
    Crazy Steve, Stogy and deadbeat like this.
  29. upspirate
    upspirate
    True , but how many "modern" people have the interface to understand what you are doing???LOL:eek:o_O
    Stogy likes this.
  30. chrysler_imperial_crown_gauge-cluster_58.jpg The turn signal that I will be using in my 30' Chrysler coupe project is out of a 58' Chrysler Imperial, dash mount switch. You can see it in the lower left corner under the push ****on shift in the picture. I will also be using a push ****on shift pod from a Chrysler and incorporate it in a 1946 Chrysler dash that I will be using.
