Technical 1961 ford a matic trans
Discussion in 'The Hokey Ass Message Board' started by cvs, Aug 6, 2016.
  1. cvs
    cvs
    wont shift into 2nd gear until driven approx. 5-7 miles. after warm up shifts normal. Any opinions?
  2. BJR
    BJR
    Have you changed the filter?
  3. Old2New
    Old2New
    Mine wont shift into reverse when its cold either. I have to put it in reverse and sit there for about 20 seconds before it will shift. Only at initial start up though.
  4. greybeard360
    greybeard360
    Lip seals are probably hard as a rock and need to be warmed up a little so they will relax a bit. Some times a conditioner can help a bit but I would budget a freshen up in its future.
    Sent from my LG-H343 using The H.A.M.B. mobile app
  5. Old2New
    Old2New
    I keep reading that the slow cold shifts are due to hardened seals. hope it will last until tax season...
  6. clunker
    clunker
    from Boston MA
    It is actually inexpensive to rebuild it yourself. If you've never rebuilt an automatic ******, give it a try! You will be able to do it no problem. You just need some very basic tools and your (kitchen) table. Either Autotran.us or Fatsco will have the parts for just a couple hundred dollars. If it runs after it warms up, your internal seals are probably shot. Since it does eventually work properly then it indicates nothing else is catastrophically wrong. ImageUploadedByH.A.M.B.1470864204.260178.jpg
