Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. falconsprint63
    falconsprint63
    from Mayberry
    ages ago (probably 15 years) I missed and aluminum 4bbl of unknown origin (although it was from a boat) on the auction site. still regret not grabbing it.
    I've got some good tech on performance from an Allard group on my desktop. I'll try and remember to post it up tomorrow. Short story is 4bbl stock performs better than 2 x4 and 3x2 options.
    but more carbs just look cooler :)
    Sent from my SM-G920R4 using The H.A.M.B. mobile app
    winduptoy likes this.
  2. Roothawg
    Roothawg
    I don't know much about the old Rochesters. Do they seal up decent (throttle shaft wise) ? Can I still get OH kits etc? Any idea on the cfm range? Are we talking 4GC series?
  3. 2 more doors
    2 more doors
    Will this intake also bolt on to a 63 390? I know the intake gaskets are the same but the head gasket changed that year.
    Sent from my SM-G935V using The H.A.M.B. mobile app
  4. Roothawg
    Roothawg
    I think 63 was the change year. Didn't the distributor move to the front?
  5. clunker
    clunker
    from Boston MA
    Nope. 63 is a one year only experiment, block is 4" narrower than earlier 390. 64 whole new deal, (although I think 63/64 may share intake manifold)
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    rod1, winduptoy, ls1yj and 5 others like this.
  7. Roothawg
    Roothawg
    You're teasing me Mark.
    Moriarity likes this.
  8. clunker
    clunker
    from Boston MA
    A lot of haters for these old carbs, but I'm a fan. Even on ebay you can buy cheap cores, (most have frozen throttle shafts so just make sure you get cores where the shafts aren't seized) kits are all over and cheap. I bought boxes of cores so I could have lots of spare parts. A frozen clapped out core might be $30, but have good floats, which are like $90 for a set, etc.
    Modern CFM standards are a bit different, but short answer is 4gc's came in 500, 600 and 700 cfms, based on their bores which varied.
    Take minute to read this:
    http://wildaboutcarsonline.com/memb...ine_Modification_and_Tuning_Rochester_4GC.pdf
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    I think you really need the manifold that takes AFB's don"t you? these small WCFB's may not be large enough for you...
  10. carbking
    carbking
    At my age, trying to get out from under my inventory, not buy more; but at that price, probably should think about buying that unit. Clean it up a little, do some detailing (there are some minor corrections needed), hold it for a buyer, and TRIPLE my investment!
    Surprised it hasn't sold.
    Jon.
    winduptoy and clunker like this.
  11. carbking
    carbking
    Quote:
    "I think you really need the manifold that takes AFB's don"t you? these small WCFB's may not be large enough for you... "
    End quote.
    The 1957 factory intake will take early, small AFB's, and is the only one of the factory intakes that will.
    The throttle center-lines on the larger AFB's was moved apart from the early small AFB's, so larger AFB's on a factory manifold would require either adapters or milling the intake, even though they will bolt on (the throttle plates will hit the manifold).
    Jon.
    TERPU and AHotRod like this.
  12. clunker
    clunker
    from Boston MA
    Good info. I think moriarity is just taking the piss out of roothawg, he's taunting him with that sick Weiand intake.
  13. Roothawg
    Roothawg
    I think they would be enough.
  14. I have a Smoljan 3-2 for my 331. Guy up in Maine still making them
    from BangShift.com Nov.26,2012
    Last week we showed you an interesting looking intake manifold and challenged you to tell us what engine families it fit. In true fashion several of you nailed it. The intake is a reproduction of a cl***ic Smoljan intake that was made in California during the 1960s. Dave Thibeault of Studebaker Parts and Services in Maynard, M***achusetts now reproduced these intakes and has them available for sale. Call him up at 978-897-3158 if you want one!
    These intakes were designed and intended for Studebaker engines but according to Dave they can be adapted without much trouble for use on old Caddy engines in the same family as the 390. Thibeault said that the Studebaker V8 shared many similarities with the Cadillac engine and the Caddy design strongly influenced Studebaker engineers. The Stude engines are legendary for their robust built quality. Dave said he sets these intakes up with Stromberg WW carbs of Rochester 2CG pieces.
    bonesy, Torkwrench and Moriarity like this.
  15. Roothawg
    Roothawg
    Wow. I like that a lot. I had no idea that anyone was reproducing those.
  16. I ordered a raw casting from Dave Thibeault. I trying to determine what carbs to machine it for. Thought also crossed my mind of making a blower plate to bolt on to it. The design reminds me of the Detroit Speed ones.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    If those are really Studebaker intakes it would be interesting to see it with a caddy intake gasket set on it. just how close do these match up? some people say they match up well and others say they do not. I have an offy stude manifold. I am going to dig that out tomorrow and post pics here with a gasket set on it for comparison.....
    winduptoy, falcongeorge and Dan Hay like this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok, I looked and did not have a caddy intake gasket so I set the offy stude manifold next to a weiand caddy manifold and it looks way off to me.
    The first pic will show that the front of the ports are lined up[​IMG]
    The next pic is overall showing the mismatch[​IMG]
    The next one is the closeup of the mismatch [​IMG]
    Then I measured the length of ports front to back, the stude is 11 1/4"[​IMG]
    The caddy is 12"[​IMG]
    I don't think this would work very well. Has anyone here actually done it??
  19. Roothawg
    Roothawg
  20. falconsprint63
    falconsprint63
    from Mayberry
  21. Moriarity
    Moriarity
    SUPER MODERATOR
  22. F&J
    F&J
    Just a heads up. A recent ad still on page one of AACA "buy/sell" forum:
    Quote:
    Two 1950 caddy 331 ci engines. One completely apart, other is short block. Have NOS headers for one. No intakes. $400 each. Waukesha, Wisc.
    If you search there, look for ad ***le: "Engines for sale"
  23. v8shadow
    v8shadow
    I have been reading this thread intently lately. I am looking to improve my 54 331 4v w/hydramatic since it was time to rebuild. Can I simply just machine this thing to the same bore as the 390, give it the same or hotter cam spec, buy a rebuild kit for a 390, then have a 390 when its all done? I mean, what all can I use from the existing 331?
  24. warbird1
    warbird1
    Take a look at this thread... http://www.jalopyjournal.com/forum/threads/new-skool-331-caddy-build.803459/
  25. falconsprint63
    falconsprint63
    from Mayberry
  26. falcongeorge
    falcongeorge
    from BC
    I thought the later heads had bigger intake ports??
  27. clunker
    clunker
    from Boston MA
    The heads are bolt on, even though the ports are much larger on the later heads. When 390 heads are used on a 331, the 390 push rods must be used because the height differs. Usually someone boring the 331 out and using hot cams will be using Studs adjustable rockers and custom valve covers, and will already be having a geometry project to work out with the rods anyway.
    Here's a pretty quick thread where an engine builder simplifies it for the OP.
    http://www.cadillacpower.com/forum/viewtopic.php?t=8853
    The stock 331 had 160 HP and 312 lbs of torque, the stock 390 with tri-power had 345 HP and 435 lbs of torque, so there's a significant difference. Neither is a light motor, the 331 is around 700lbs, and the 390 20lbs more.
  28. falcongeorge
    falcongeorge
    from BC
    Well, I didn't say they wouldn't bolt on, the point I was attempting to make was that just boring it out and adding the pistons isn't the whole deal,if you want to make your 331 into a "390", you have to swap the heads as well.
    ls1yj and falconsprint63 like this.
  29. clunker
    clunker
    from Boston MA
    Oh right, exactly. You were just explaining to post 174 that there's more to transforming a 331 into a 390 than the bore. Got it.
    falcongeorge likes this.
