Projects 1934 Ford PU Build
Discussion in 'Traditional Hot Rods' started by Jeff34, Jul 27, 2015.
  1. Jeff34
    Jeff34
    Grrrrr. Nope. Applied heat and still can't get it. Since I'm replacing the perches anyway can I just drill through the bolt? Stop just shy of the larger section where it p***es into the bone?
  2. dumprat
    dumprat
    from b.c.
    Carefully grind the side of the nut with a small cut off wheel as far down as you dare. Then jam a cold chisel into the slot made by the grinder and give it a mighty whack! Should break the last of the nut loose and let you get the perch out. That is exactly how I did mine. They were pretty stuck.
  3. steinauge
    steinauge
    from 1960
    What Dumprat said.I actually ground a small cold chisel just for that job on my A front end.Expect trouble getting the perch out of the axle.I got mine out using a lot of heat (OA) and a drift that just would slide through the hole in the axle and a 4 lb hammer.
  4. nunattax
    nunattax
  5. Jeff34
    Jeff34
    Got it! David DiFalco walked by this AM with his dog and we talked about his story on the HAMB and my stubborn perch nut. I applied more heat until it was cherry red and put the long bar and 6 pt socket on it. I thought I might just round over the nut, but it came off.
    Now on to the perch, which seems to be stuck in the axle pretty good.
  6. Jeff34
    Jeff34
    David recommend this too. Split the nut. I just wanted to try with more heat first.
  7. Jeff34
    Jeff34
    No luck with the left spring perch bolt. Modified a prop puller to press it out. Heated the **** out of the axle (glowing) and still couldn't get it to budge. I don't want to damage the axle or the wishbone so it's going to DiFalco's shop next week to see if he can get it out unless there are any other suggestions???? ImageUploadedByH.A.M.B.1469912044.824874.jpg
  8. Jeff34
    Jeff34
    On a positive note, I got the front spring pack cleaned up and ready to put back in! Removed 4 leaves and reverse eyed the main ImageUploadedByH.A.M.B.1469919131.656822.jpg
    kidcampbell71 and bengeltiger like this.
  9. Jeff34
    Jeff34
    Really want to get this back on the ground so I can start terrorizing the neighborhood again [emoji1] ImageUploadedByH.A.M.B.1469920401.601338.jpg
  10. dirt t
    dirt t
    Great pick up. Keep posting.
  11. Mart
    Mart
  12. Jeff34
    Jeff34
    So, stupid questions ... I've taken the flap wheel to my leaves, and now I want to put this all back together again. Do I paint them individually or as an ***embly?
    Second question; do I need the rubber spacers for the tie rod and drag link ends?
    Help me Obi-Wan!
  13. Jeff34
    Jeff34
    Oh, and David DiFalco was able to separate the perch bolt from the axle and wishbone with some effort. I'm grateful for that.
    Runnin shine likes this.
  14. I painted my spring leaves individually, just a thin coat though.
    I believe the rubber spacers of which you speak are the grease seals?
    also has a tin shield to hold their shape. In which case, yes, you need them.
    Jeff34 likes this.
  15. waxhead
    waxhead
    from West Oz
    As Flowmeister said, paint them individually
  16. Jeff34
    Jeff34
    Thank you both for the advice.
    I think the rubber parts are grease seals...mine were gone, and replaced with years of built up dirt and grime...
  17. Jeff34
    Jeff34
    Here's a couple of pictures of the removed perch bolt. He had to put the axle/wishbone in the mill and plunge through the perch bolt without damaging the axle or wishbone. You can see how much he hogged out before he got it to break free...Now I'm back on track for re-***embly (well, after I get my kingpin bushings replaced) of the front end.
    20160805_211118687_iOS.jpg 20160805_211051438_iOS.jpg 20160805_211104012_iOS.jpg
    AHotRod likes this.
  18. Jeff34
    Jeff34
    One more pic for a Sunday afternoon ImageUploadedByH.A.M.B.1470608723.502218.jpg
    AHotRod and jerseyboy like this.
  19. dumprat
    dumprat
    from b.c.
    What is the spring for?
  20. Runnin shine
    Runnin shine
    So the hook doesn't bounce out.
    AHotRod likes this.
  21. dumprat
    dumprat
    from b.c.
  22. Jeff34
    Jeff34
    Yup. Bumpy trails on the ranch...
  23. Jeff34
    Jeff34
    I removed my king pins from the spindle housings, and had intended to replace the bushings and king pins. Before I did that, I measured the play in the kingpin to see if it was really necessary. Problem is, I don't know what an acceptable amount of play is for a kingpin. There is some wear on the kingpins where they contact the bearing surfaces, but not too bad.
    I measured the movement of the kingpin in the bushing with a dial indicator. The top of the kingpin is tight, and there is very little movement. The bottom of the kingpin has about .012" play total.
    I didn't really have problems with steering or any front end wobble, etc. So, do I need to replace these, or just re-***emble and run them?
    The pic below is not my truck, just used to point to the area in question.
  24. Jeff34
    Jeff34
    Here's a short video.
    Good? Bad? Ugly????
  25. dumprat
    dumprat
    from b.c.
    New bushing time!
    greaser likes this.
  26. Jeff34
    Jeff34
  27. dumprat
    dumprat
    from b.c.
    Not a bad idea.
  28. brokenspoke
    brokenspoke
    Napa sells slip plate paint in a spray can
    AHotRod likes this.
  29. Jeff34
    Jeff34
  30. Jeff34
    Jeff34
    Got the front end in. King pins and bushing should arrive tomorrow. Hope to have this back on the growing next weekend. I may need to put a leaf back in. Seems awful low. We'll see how it sits soon. [​IMG][​IMG]
    kidcampbell71 likes this.
