Projects What happens in my garage
Discussion in 'Traditional Customs' started by dlandberg, Jan 25, 2015.
  1. 56 Dodge Pickup
    56 Dodge Pickup
    I agree the build is the most fun! looking good just remember the bracing for the body. I have been working on a bomber bench seat for my Plymouth build coming out nice. Looking forward to following your build. Hobo Jim
    dlandberg likes this.
  2. Finnrodder
    Finnrodder
    from Finland
    Wow!
    Really fast moves again!
    I dont know is there any other reinforcements on the convertible or Victoria frames than the X,but i think making one could do the trick.Keep it up!
  3. dlandberg
    dlandberg
    from Sweden
    Thanks guys! Yes im going to build an X on the frame what i can find that is the only reinforcments on the convertible frames? For the body theres going to be an form of X above the rear wheelhouses and it will go inside the backpanels to the former B pillors, in the front fenders will be welded to the body to smooth out things and i belive that will do some too atleast when doors are open.... If anybody knows exactley what reinforcements the original convertibles have please enlight me i find nothing in the green bible or google just frames.
    Eric H likes this.
  4. ThatSteveGuy
    ThatSteveGuy
    Wow, that does look good! This car will be a blast to drive! Nice job.
  5. Copper Top
    Copper Top
    Did you see the thread " The Black Cavendish" by Eric H.? He has done some nice work on his shoebox. Great work on yours.
  6. Rui
    Rui
    Looking good. Subscribed.
  7. dlandberg
    dlandberg
    from Sweden
    Thanks! Yes The Black Cavendish is a big inspiration for me the work he does is amazing! Also like Yarils kustom shoebox that now Billy gibbons in zz top owns, if i can do just 1% of that great work on mine im very pleased! Both Eric and Yaril have some serius skills!
    Copper Top likes this.
  8. dlandberg
    dlandberg
    from Sweden
    Little update, have welded all day long, made a support bar between the rear wheelhouse that both stabilise the body and attetches to the catwalk area, made brackets on both sides where the carson top/convertible top is going to rest and made a lip on the catwalk.
    The first pictures is when i stretched out the body before i made the support some things did not line up so i welded a big twing to the catwalk and spread the body some.
    mad mikey, Rui, wizkid and 1 other person like this.
  9. dlandberg
    dlandberg
    from Sweden
    Welded some more and made some templates to see if rear windows and the roof flow is ok.
  10. mad mikey
    mad mikey
    Killer! Nice work brother.:D
  11. dlandberg
    dlandberg
    from Sweden
    Thanks man [emoji3]
  12. dlandberg
    dlandberg
    from Sweden
    Have talked about my grill earlier and today i did find this on eBay and this looks exactly like mine so i think i solved it, it is a cal custom pice.
  13. dlandberg
    dlandberg
    from Sweden
    Did something today that i should have done about 1.5 year ago when i dropped the F1 truck, did heat and bend the steering arm and made a z on the draglink so now no more bumpsteer when everything is in line!
    biggeorge likes this.
  14. steinauge
    steinauge
    from 1960
    Ambitious project! Looks really good,fine work!
  15. dlandberg
    dlandberg
    from Sweden
    Thanks for kind words man!
  16. cmarcus
    cmarcus
    Nice work! I will definitely by following along. Love carson tops!!
  17. dlandberg
    dlandberg
    from Sweden
    Thanks! Yes they sure are cool [emoji3]
  18. dlandberg
    dlandberg
    from Sweden
    Hard to find time to work on the shoebox with other bike and car projects and a new born daughter but did some today and took it outside to see the look and a little test drive to!
  19. dlandberg
    dlandberg
    from Sweden
    And here are some pictures where i removed the templates and the last pic is my wife taking it for a testdrive.
  20. Eric H
    Eric H
    The convertible frame started life as a sedan frame with the X added. The other thing that most people don't realize is that the bottom of each rail had a length of plate stock welded to it. It's prob 1/4". My cars at the shop so I can't measure it right now.
  21. Eric H
    Eric H
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg This is the windshield frame of Octavio's Tudor turned vert that he and Rob Radcliffe have been building. Reshaping and squaring the A pillars makes a major difference in the end. I like what your doing!
  22. dlandberg
    dlandberg
    from Sweden
    Thanks Eric for solid info and great pics of the window frame, i have been thinking of reshaping it, its only spot welded togheter now so i think i take it apart again looks better in the end like you said when the a pillars are leaning slight inwards. About the frame i think i will do more like a K on the frame and when i do a kickup on the rear frame i will weld it togheter in the top for added support too. The frames feels pretty strong when driving around a little with just my temporary support inside the body there is no flex in the body or movement now.
    Eric H likes this.
  23. dlandberg
    dlandberg
    from Sweden
    Did stripp all paint on the window frame and did small relief cuts in the corners to get it a little tighter and welded up think the base shape is good, now i just got to get it to look like a convertible window frame....
    tomkelly88 and Eric H like this.
  24. 56 Dodge Pickup
    56 Dodge Pickup
    Nice look keep going its really going to be cool!! Hobo Jim
  25. Finnrodder
    Finnrodder
    from Finland
    Nice work!
  26. jnaki
    jnaki
    Hello FINN and DL,
    Here is an article I did on Carson Tops back in the early days.
    You might like the ideas and build process.
    Jnaki
    upload_2016-9-17_5-11-2.png upload_2016-9-17_5-11-30.png upload_2016-9-17_5-12-10.png upload_2016-9-17_5-12-43.png
  27. dlandberg
    dlandberg
    from Sweden
    Thanks man! I hope so!
  28. dlandberg
    dlandberg
    from Sweden
    Thanks! Any progress on your shoebox?
  29. dlandberg
    dlandberg
    from Sweden
  30. Finnrodder
    Finnrodder
    from Finland
    I am not building a carson top,but that article is interesting.Thanks for sharing it!
    Nope,i havent touch it for awhile.I got frustrated because of the ****ty weather,it always rained when i was off the work.I've been building bike parts instead.Well,i am back on the day shift,so i think there's good chance to get something done for the shoebox soon.
