HUBBA HUBBA my 32-4 Tudor tribute to Gramps
Discussion in 'Traditional Hot Rods' started by Runnin shine, Jul 15, 2015.
  1. Chris
    Chris
    You cannot/should not end an original tie rod. They are thin wall and the female thread version is split seam. If you need to bend a tie rod, get a piece of decent wall tube and a local machine shop can bend and or thread it. Or a hot rod shop.
  2. Runnin shine
    Runnin shine
    The good news is I didn't bend one of my old style ball end tie rods. It was just a rusty F1 I believe that came with my PU's ch***is.
    PS, what's a Hot Rod Shop?[emoji6]
  3. Chris
    Chris
    If you look at the tie rod, it's probably split down the side. You could bend one over your knee...
  4. Something new. I didn't know that, thanks for the info!
  5. Tim
    Tim
    from KCMO
    Would a dropped tie rod end solve your issue? I seem to remember those existing
    Runnin shine likes this.
  6. Chris
    Chris
    Here you can see the tie rod a friend bent up and threaded for my roadster
    rkkoehler and Runnin shine like this.
  7. Runnin shine
    Runnin shine
    Thanks Chris, I thought about this and searched for tube most of yesterday and was bummed at the prices. I want to at least use the split clamp style for esthetics if I'm not using the early style from my late 40s build theme. Since I had this tired spilt one I thought I'd take a shot first. It would not bend easily by my knee, well not the way you would want it to drop sharply right after the threaded section. I left a old ball joint in it and the clamp on to keep it from distorting. But I just couldn't get it hot enough with map gas and no helper. I guessed this would happen but at least I tried. Side note I am already ashamed that a friend help me(shoddily at best) on my front bones and that was a waste of time so I most likely will not have a tie rod made for me. An example of this stubborn DYIness is I'm looking into building my own flow bench mostly for my PUs heads, if I can use it on this flatty all the better.
  8. Runnin shine
    Runnin shine
    NostalgiaSids has these 1.5" drop tie rod ball joints.
    This might be the way with a little chrome plating. $50 a pair.
    Thanks @Tim
    volvobrynk and Tim like this.
  9. dumprat
    dumprat
    from b.c.
    Willys tie rod ends are dropped and fit. I dont know what year but 30-40's rings a bell.
    Or any decent machine shop should be able to make you a dropped tie rod. I made mine out of 4140 HTSR bar and threaded it. I could use it to lift the truck up with a jack and not bend it.
  10. Runnin shine
    Runnin shine
    Matt, do you know if Willys used the 7 degree taper? I can get a sick pair of NOS 37-39 of the auction site at a great price. They would look awesome! I've read about this before, I immediately recognized them once I started searching.
  11. Runnin shine
    Runnin shine
    This is the type of Willys tie rod end I dig
    The ones I wanted to get were gone when I came in from the garage. NOS seem to pull a really healthy price normally. Re pops just aren't interesting.
    I'll p*** the depressing time by finally drilling the pointless holes in my rear spreader bar then I can paint it and my tail light brackets. I say "pointless" cause I'm running the gas tank in the stock location as apposed to a true "Lakes" build. I can't give up the back seat space in a car built to haul the fam.
    paintslinger805 likes this.
  12. Hey those are pretty cool. Iv never seen those. They look 40s to me with the shape of them.
  13. Tim
    Tim
    from KCMO
    I'd be more curious of the shaft size than the taper. You can play with the taper in your arms but if they are to short or to thin to whatever, it's harder to work with.
    Drill away ;)
  14. Tim
    Tim
    from KCMO
    And none of its pointless if it's helping you keep your sanity ;)
    volvobrynk and Runnin shine like this.
  15. Runnin shine
    Runnin shine
    That what she said[emoji23]
    I couldn't help myself
    volvobrynk likes this.
  16. dumprat
    dumprat
    from b.c.
    Not sure of the sizes on the willys ones. But anything is doable.
  17. Tim
    Tim
    from KCMO
    Holy **** that's all 100% funnier now. Lol playing with your willys lmao
  18. Runnin shine
    Runnin shine
  19. Tim
    Tim
    from KCMO
    Hell yes!
  20. Tim
    Tim
    from KCMO
  21. dumprat
    dumprat
    from b.c.
    Looks like progress.
    Gonna plunk the body on it today?
    slv63 likes this.
  22. Runnin shine
    Runnin shine
    I have to apologize to @CURSED GEARS I had promised him he could help me set the body on. I was outside when my neighbor came home from work. He said can you put the body on it yet? I said I guess but I told a HAMB friend he could help. Guess I'll have to make it up to'm
    This stuff is still way off and a long way to go. Although it looks like ***, this is a huge step in calculations.
    Insert condescending rips and boos here...
    Tim, kidcampbell71 and slv63 like this.
  23. Runnin shine
    Runnin shine
  24. slv63
    slv63
    Looks great! I feel encouraged looking at it and it's not even my car :)
  25. Tim
    Tim
    from KCMO
    **** id be on my way to the store for masking tape and news paper to make it look like a complete car from 30 foot lol
  26. Runnin shine
    Runnin shine
    I might cut the posts and roof a little tomorrow and set it on there. I shouldn't be messing with the car at all right now cause I'm supposed to be doing some house stuff. Some of you know how it is though.
  27. Corn Fed
    Corn Fed
    Just for the fun of it have Cursed Gears come over and help set the PU cab on there.....
  28. You can make it a tub, tudor phaeton, or even a Carson hard top now...
  29. Once you set that top on it's gonna make everyone realize your dream and what you have envisioned since the start of this thread. I'm happy for you Wyatt. Keep at it and soon enough you will be kicking on that starter shaft. Looks cool and I agree the back tires need to be bigger.
    bengeltiger and Runnin shine like this.
