Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. 1lucky1
    1lucky1
    from Morgan NJ
    VeryNice, Can't wait to see the video of you smokin them Tires!
  2. hot rod pro
    hot rod pro
    from spring tx.
    Me too. [emoji2]
  3. hot rod pro
    hot rod pro
    from spring tx.
    image.jpeg image.jpeg image.jpeg image.jpeg What do you do when nobody makes what you want? You make it yourself! Brake and fuel line nuts that match the AC and heater line nuts. #32mafia #brucesrodshop
    63fdsnr, loudbang and kidcampbell71 like this.
  4. hot rod pro
    hot rod pro
    from spring tx.
    image.jpeg image.jpeg image.jpeg image.jpeg Brake lines are coming along nicely. #32mafia #brucesrodshop
    Ron Funkhouser, Drewfus and 63fdsnr like this.
  5. loudbang
    You mean you couldn't have bent them to spell out your name or something :rolleyes: Just kidding a great job as usual.
    1947knuck and hot rod pro like this.
  6. hot rod pro
    hot rod pro
    from spring tx.
    image.jpeg image.jpeg image.jpeg image.jpeg Brake lines on the frame are done. #32mafia #brucesrodshop
  7. hot rod pro
    hot rod pro
    from spring tx.
    image.jpeg image.jpeg image.jpeg image.jpeg Line clamps are on.
  8. hot rod pro
    hot rod pro
    from spring tx.
    image.jpeg Starting on the fuel line.
    loudbang, Drewfus and 63fdsnr like this.
  9. hot rod pro
    hot rod pro
    from spring tx.
    63fdsnr likes this.
  10. hot rod pro
    hot rod pro
    from spring tx.
  11. hot rod pro
    hot rod pro
    from spring tx.
    Fuel lines on the frame are finished. I'm pleased. #32mafia #brucesrodshop IMG_1471958156.393869.jpg IMG_1471958170.975707.jpg IMG_1471958178.878145.jpg
    HEMI32, Tim_with_a_T, Drewfus and 3 others like this.
  12. ratamahata
    ratamahata
    from Argentina
    Impressive work! I love the frame! Want to join our Mafia!! Saw in FB!! Greetings from Argentina!!
    ratamahata
  13. hot rod pro
    hot rod pro
    from spring tx.
    I like your truck.
  14. bengeltiger
    bengeltiger
    Beautifully executed!
  15. hot rod pro
    hot rod pro
    from spring tx.
  16. dirt t
    dirt t
    Craftsmanship at it's best.
  17. hot rod pro
    hot rod pro
    from spring tx.
    Starting the paintwork. Sheet metal is blasted, and the body is partially in primer. IMG_1473557636.103726.jpg IMG_1473557647.151381.jpg IMG_1473557661.202970.jpg IMG_1473557670.771609.jpg
    HEMI32, bengeltiger, greaser and 8 others like this.
  18. TexasSpeed
    TexasSpeed
    from Texas
    Great to meet you in Lafayette! I love how your coupe is coming along.
  19. hot rod pro
    hot rod pro
    from spring tx.
    Made some progress on the coupe. Machined some custom line nuts for my final brake line, and clutch line. Then bent the lines on the firewall. #brucesrodshop #32mafia IMG_1479696016.152931.jpg IMG_1479696026.321522.jpg IMG_1479696035.506629.jpg IMG_1479696044.937979.jpg IMG_1479696062.197663.jpg IMG_1479696073.117831.jpg
    63fdsnr, bengeltiger, bct and 5 others like this.
  20. Tim
    Tim
    from KCMO
  21. fourtogo
    fourtogo
    from long beach
  22. loudbang
    You know if you spent less time machining ALL your own parts this car would be finished by NOW. :rolleyes:
    But then it wouldn't be as AWESOME as this is. :p
    1947knuck likes this.
  23. hot rod pro
    hot rod pro
    from spring tx.
    Tell me something I don't know. [emoji2]
  24. dan@larescorp
    dan@larescorp
    I've been watching this thread a long time. Every update you post is impressive work. I'm excited to see what great ideas you come up with next for this one.
  25. ratamahata
    ratamahata
    from Argentina
    "You're building a hot rod" and Thanks for take it you time for sharing!!
    I appreciate when a skilled man put all the p***ion and knowledge in a project!!!
    I got a Hot rod Ford and two dollars bill!
  26. hot rod pro
    hot rod pro
    from spring tx.
    Thank you very much
  27. hot rod pro
    hot rod pro
    from spring tx.
  28. hot rod pro
    hot rod pro
    from spring tx.
    Thank you very much
  29. Pewsplace
    Pewsplace
    First Cl*** all the way! Pure Hot Rod! Congrats to your ability with the machinery you have in your shop.
