Projects Unearthing a StAr DeStroyer! 1931 Coupe w/394 olds-
Discussion in 'Traditional Hot Rods' started by Tuck, Jul 20, 2015.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  2. falcongeorge
    falcongeorge
    from BC
    Thats that one that was in Car Craft in '65, with the y block with twin McCulloughs...
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Yes! Found it in the November '64 of car craft- on the cover as well!
  4. ynottayblock
    ynottayblock
  5. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I did a third version- this one came out more refined everywhere. All done with the hoop exercise. The other one had a wonky arm from the top. I welded in a tapered bung cut off from a spindle flush and burned it in with the tig and put a bolt on drag link ball on it.
    The more I work on the coupe the more I want to just go full out race car with spindle mounts and all... the force is pulling me to the dark side haha. I think what I'll do is lighten the **** out of the front brakes- and cross that bridge later. I lightened my axle so much I feel like the brakes will be a stress factor- but I have half cylinders up front and if I proportion the rears to kick in harder I think it'll be fine- just talking out loud.
    Can't wait to get the inserts in and everything welded up. It looks so cool on the jig table. I love hot rods!!!
    Anyone have nice straight 32 drag link? I tried to straighten mine but I think it just looks like a straightened out piece of wet spaghetti...
    So I'm Z'ing the frame in the front stacking it inside the firewall. Plan to run a F-1 crossmember and pedals... thinking about the rear and maybe... not altering the frame in back just running a reverse eyed T spring over the olds axle... OR I could extend the frame and run and A spring behind. I just need the rear tire to align with the top of the rear fender lip so I can run fender flares. again... just talking out loud.
    I also have a 36 rear crossmember I could run with a 36 front spring behind the axle.... hmmm...
    Vic Walter, kiwijeff, rust and 9 others like this.
  6. Runnin shine
    Runnin shine
    I hope Tuck doesn't mind if I bump a couple of his pics. These are just incase someone is dragging their feet to read back through or subscribe.
    I love Hot Rods and this build in particular.
    Outback, Vic Walter, kiwijeff and 4 others like this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  8. AHotRod
    AHotRod
    Nice work Tuck .... I too love your "inspirational" picture.
    Tuck likes this.
  9. falcongeorge
    falcongeorge
    from BC
    It would be a cold day in in hell before I would build a typical "traditional" Model A highboy coupe with a flathead, baby**** brown paint, '35 ford wires and big-*** headlights. But THIS^^ I would build in a HEARTBEAT!
    cactus1, mad mikey, Tuck and 4 others like this.
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Outback, Vic Walter, -Brent- and 8 others like this.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks man-! If you're taking about the inspirational pic that running shine posted that's the actual car back in 70 something...
  12. Runnin shine
    Runnin shine
    Awe man nobody is gonna have a set of those, nice!
    Consider Wyatt(me) inspired.
    Now I'm going to quit hoggin your thread for awhile sorry.
    Tuck likes this.
  13. mad mikey
    mad mikey
    Love this build as well. Great hot rod stuff going on right HERE!
    Tuck likes this.
  14. falcongeorge
    falcongeorge
    from BC
    This is SO sixties.:cool:
    Outback, hechtspeed, brad2v and 2 others like this.
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Man... This had a wedge channel before- feeling like doing the same thing and not zing the frame... No kick up either- t spring over and just kick the motor back in the firewall so it's nice and compact like a bulldog.
    Vic Walter, Tim, Stock Racer and 15 others like this.
  16. F&J
    F&J
    Just me, but I'd never Z the front frame. It will look too "Y2K rat" ...IMO :)
    damn the haters............ wedge channel it again. It would wake up the viewers here, to a real hotrod
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Totally agree- just seems more authentic to me- if I were to z it - it would be hidden behind the firewall- but I like the look of the kicked up floor and interior which just seems "right"
    mad mikey, cactus1, AHotRod and 2 others like this.
  18. falcongeorge
    falcongeorge
    from BC
    If you do z the frame, do it the way Spencer did it, at the front crossmember, it's much more subtle. I agree, wedge channel it.
    brad2v, loudbang and Runnin shine like this.
  19. falcongeorge
    falcongeorge
    from BC
    Man this is gonna be cool....
    Outback and loudbang like this.
  20. bowie
    bowie
    kiwijeff, brad2v, mad mikey and 4 others like this.
  21. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    You know what that wedge does is gives it a look of "perpetual motion" by leaning the cowl forward- Dig it a lot!! Its on!
    bowie and brad2v like this.
  22. bowie
    bowie
    The proportion actually looks better with the hood on it. Then again it's more "hot rod" without.
  23. AHotRod
    AHotRod
    What's the height and width of those old slicks Tuck?
    Glenn
    (P.S.-build it your way brother, as I know you will)
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I believe they're 30" tall and 8" across-
    AHotRod likes this.
  25. AmishMike
    AmishMike
    Love that picture #315 - the dusty car, the engine+trans, parts all over a table under the lights. Great shot.
  26. Oh hell yeah, those are some ingredients..
  27. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I found some 5.60 15 rollers for the front! Time to construct some wheels with the right offset.
    I'm gonna use 5" wide 50 ford hoops with 59 Cadillac centers- and wider 6" merc hoops in the back with the same Cadillac centers reversed. I want the Buick drums to show...
    The offset on the wheels I have is like 4" and totally engulfs the drum. It's really hard to find 5on5 wheels around here because they fit imperials and they use them in the demolition derby.
    gonzo, tomkelly88, volvobrynk and 3 others like this.
  28. AHotRod
    AHotRod
    What offset are you looking for Tuck?
  29. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Something like 3" or less- this will be fun to make them- I can center them on the brake lathe and weld them up.
  30. Paul
    Paul
    Editor
    Love that overhead shot
    Tuck likes this.
