Technical Help
Discussion in 'Traditional Customs' started by Brian Fahey, Aug 25, 2016.
  1. Brian Fahey
    Brian Fahey
    Can anyone tell me about these carbs? 20160819_204932.jpg 20160819_204826.jpg 20160819_205005.jpg
    Petejoe likes this.
  2. southerncad
    southerncad
    Well, I'm not a Ford guy, but I can tell you for sure they are SWEET, and made by Ford:)
  3. Brian Fahey
    Brian Fahey
    I'm looking mainly for three CFM of them, but any info would be great. They came with a project I pick up.
  4. flatout51
    flatout51
  5. Brian Fahey
    Brian Fahey
    Thank you. There isn't many people left that know the older motors and sub systems
  6. 51504bat
    51504bat
    Over on the Ford Barn there is a member "Charlie NY" who is a go to guy about all things 94's. There are some others over there as well.
  7. Brian Fahey
    Brian Fahey
    Thank you.At 170 CFM they aren't big enough for me. I love the look, but not even close for a 383 stroker chevy stroker.
  8. mike bowling
    mike bowling
    You need a serious set up for that baby! ( I don't have it anymore, but they're out there)
  9. 'Mo
    'Mo
    Well, how 'bout a six pack on a cross ram?
    mike bowling likes this.
  10. mgtstumpy
    mgtstumpy
  11. Atwater Mike
    Atwater Mike
    How'd they do that, Stumpy? Bore the ****erfly bores and venturii? Old hot rod methodology sometimes beleaguers the mind...
  12. steinauge
    steinauge
    from 1960
    Stumpy did you actually see the flow bench chart for those? Reason I am asking is I ran a few 94s and 97s on the little flowbench we had where I used to work and I got numbers like 150-160 cfm pretty consistently.That was a superflow 110 with the "upgrades" (think computer digital readout pack). I realize that a flowbench is a comparative tool and numbers from one will not necessarily be the same as another,but that is a big difference.I am not trying to start an argument here.
  13. Brian Fahey
    Brian Fahey
    That 6 pack setup is great. That cost more then my motor. I do need something to go with this. I know a chevy in a ford, but I have the motor and I think this is my last build for a while . It's going to take a lot of motor to spin those tires 20160502_140006.jpg
  14. mgtstumpy
    mgtstumpy
    upload_2016-8-26_10-35-14.png upload_2016-8-26_10-36-15.png Only
    what I read, haven't seen the flow bench results but the new:-
    Big97 requires manifold modifications as per Stromberg 2016 Tech Bulletin. They apparently each flow 250cfm, 55% more airflow than regular 97s. 1.175in venturi with 20 degree entry angles. The accelerator pump discharge jets are smaller and well out of the booster airflow. Flared exit cones build power by slowing the mixture down to reduce turbulence into the manifold plenum.
    A new, oval cut-out, just under the throttle plates, allows any cylinder to draw from both barrels, combining the easy drivability of a dual plane intake with a boost in top end horsepower more usually ***ociated with a single plane intake.
    I'm sure there are other more knowledgeable than me that can attest to or refute their claims. It sure keeps things looking traditional with definite improvements over base Strombergs if they can keep the fuel up to a motor
