Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. Baron
    Baron
    My idea was to mount the tie rod ***embly on the rear bottom holes on the spindles and bolt the steering arm to the p***enger side spindle on the upper holes and mount the steering box up front, pitman arm facing to the rear. Did you find a Vega pitman arm yet ?
    HAMB mobile app
  2. swade41
    swade41
    from Buffalo,NY
    Motor, trans, radiator mounts all in and steering box mocked up. Body is mounted, outriggers to roll bars mocked up too. 20160719_133121.jpg 20160719_133211.jpg 20160719_133231.jpg 20160802_123618.jpg
  3. swade41
    swade41
    from Buffalo,NY
    All welding finished up
    Loaded up and heading for home
    Checking out the new shock mounts and eyeing up the engine and trans install
    Had my son helping me with dropping the 489 in there
    All in, only got a one inch suspension drop out of that
    After it settles I'll address the height, more than likely I will pull a leaf to get the height down a little and also soften the pack so it can actually work.
    I also tried out the new scoop, which I will definitely mount. Next step will be steering column and linkage mockup.
    20160719_133231_zpsvmtnvit8.jpg FB_IMG_1507329249928.jpg 20160824_115736_zpsth3hwlju.jpg 20160824_125820_zpsiaybcjuw.jpg 20180123_161304.jpg
  4. Baron
    Baron
    Looking real good Phil. Nice to see it back home in your garage.
  5. swade41
    swade41
    from Buffalo,NY
    Yes it is, even though it cuts down on work space, I like seeing it home.
  6. Dooley
    Dooley
    from Buffalo NY
  7. henryj1951
    henryj1951
    from USA
  8. fiat gasser
    fiat gasser
    The J looks great. New ch***is is a tremendous improvement. really have enjoyed watching your progress.
    Was just out in Buffalo last couple of days stayed over by the airport, was wondering if I was in your neighborhood.
  9. LOST ANGEL
    LOST ANGEL
    Hey, Phil. Is she going to be streetable with the new engine? ****er looks ***s, nice work.-MIKE:cool:
  10. loudbang
    Now you can go out and bark at the moon again. :rolleyes:
  11. ModelAPunk
    ModelAPunk
    from Buffalo NY
    Lookin' Good Phil!!!
  12. 550Coupe
    550Coupe
    The progress you've made unbelievable. Car looks fantastic!
  13. swade41
    swade41
    from Buffalo,NY
    Yes you were, about 10 minutes away
    fiat gasser likes this.
  14. swade41
    swade41
    from Buffalo,NY
    Yes sir, pump gas motor means street friendly, just like before.
    LOST ANGEL and Baron like this.
  15. swade41
    swade41
    from Buffalo,NY
    Thanks everyone, lots of changes and lots of room to grow still.
  16. Dooley
    Dooley
    from Buffalo NY
    got to see this bad boy in person, looks like its pulling a wheelie standing still
    great car
  17. swade41
    swade41
    from Buffalo,NY
    Here's a little better idea of how it would sit on level ground, my garage is 4 degrees down hill. I left the dollies under the rear which makes it 4 1/2 inches taller and level. 20160905_191103.jpg
  18. 37willysgasser
    37willysgasser
  19. swade41
    swade41
    from Buffalo,NY
    I POR 15'd the ch***is yesterday, no worries about surface rust now for the upcoming winter. hjf.jpg hjfr.jpg hjfra.jpg hjfram.jpg
    henryj1951 and loudbang like this.
  20. Dooley
    Dooley
    from Buffalo NY
    looks good....should be pulling wheelies in no time
  21. loudbang
    Just in time to put it away for the winter.
  22. swade41
    swade41
    from Buffalo,NY
    Ha, it's been "put away" ever since I took the small block out, seems like forever too. It'll be nice to get this one back up and running again as long as the new engine has the balls to back up the look.
  23. TagMan
    TagMan
    Looks great, Phil !
  24. Chucky
    Chucky
    Was just thinking about you and your J. How's it going? Progress?
  25. swade41
    swade41
    from Buffalo,NY
    Thanks for asking, not really much progress, I boogered up my knee back in Nov. and the VA is a slow process. I've just been laying on the couch most of the winter to not agrivate it, ortho appointment is Feb.27th.
    I did drop off the front axle and springs for powder coat today though.
    Chucky and loudbang like this.
  26. swade41
    swade41
    from Buffalo,NY
    Got the axle/springs back in, next step is to make a column and shafts down to the box. 20170216_161730.jpg
  27. Dooley
    Dooley
    from Buffalo NY
    Hot Damn that came out nice...
    swade41 and loudbang like this.
  28. daliant
    daliant
    Starting to look like a g***er again, lookin' good.
  29. swade41
    swade41
    from Buffalo,NY
    Up to this point I was running the stock Henry J column and box. I kinda like the stock column drop so I decided to keep it and the stock outer column and make up the rest.
    First step was to cut off the welded on gold metal flake wheel and dismantle the column/box combo. 20170219_131011(0).jpg 20170219_130904.jpg 20170219_144022.jpg
  30. swade41
    swade41
    from Buffalo,NY
    Then I got a discarded 70 Chevelle column and pulled the shaft out of it. It was the same 3/4 inch on the upper portion but larger on the lower collapsible portion, which I already had a borgeson joint for. 20170219_144213.jpg 20170219_171905.jpg
    Spoggie likes this.
