Technical What drum brakes are these and how to adjust
Discussion in 'The Hokey Ass Message Board' started by mod, Aug 26, 2016.
  1. mod
    mod
    Yes I've looked but am unable to find the same brakes as I have. Any idea what years front and rear brakes on my pics? And how to adjust both? Is the top just simply tightening the two top bolts till the brakes grab then back off?
    Thanks.
  2. A couple of photos of the front with the drums off would help.
  3. HOTRODPRIMER
    HOTRODPRIMER
    These are the adjustments for the front. HRP
  4. HOTRODPRIMER
    HOTRODPRIMER
    The rear adjust like most other cars & trucks with the slot at the bottom. HRP
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    The fronts are 42-48 Ford brakes, I think.
    The rears are later.
  6. verde742
    verde742
    top ones are 46-48 ford, bottom ones have a metal or rubber plug hiding the slot where you will put a flat adjusting tool in.
    No reason to take off drums for us to guide you..
    Rear brake line is dangerously low, IMO
  7. mod
    mod
    Ok i understand the rear adjustment but the front do i tighten one bolt till it just starts to grap then do the next bolt and done?
  8. rustrodder
    rustrodder
    The bolts have an eccentric on the inside of the backing plate. You turn the bolt to move the brakes out to contact the drum. I forget which direction moves to extends or retract the brake shoes against the drums. You may have to pull the drums and check it out. alex
  9. rustrodder
    rustrodder
    You only have to turn the bolt a half turn or so.
  10. Fortunateson
    Fortunateson
    You seem to be missing a bolt below the brake line.
  11. gimpyshotrods
    gimpyshotrods
    Actually no.
    There is and extra hole in the backing plate that should not be there.
    There are only three holes, so you are forced to put the wheel cylinders, which have two different sized pistons, in the correct direction.
  12. gimpyshotrods
    gimpyshotrods
    If your wrench is pointed straight up, swing it away from the axle, to move the shoes toward the drums. The opposite direction for away. The adjusters are mirror images of each other.
    51 BIRD likes this.
  13. Mr48chev
    They shouldn't move very far either. I'd pull the drums/hubs and check the lining, pack the wheel bearings and scope out the adjusters so I had a good idea of how they work. Gimpy's suggestion works well.
  14. gimpyshotrods
    gimpyshotrods
    Yeah, I think that the entire adjustment range is maybe 3/16", or less.
