Projects Project 27 chop top coupe
Discussion in 'Traditional Hot Rods' started by Piedmont, Aug 28, 2016.
  1. Piedmont
    Piedmont
    Picked this little fella up yesterday and will be sharing the details of the build as it progresses. It is solid as a rock with an ok chop that I will need to tweek a bit. It is going on an model A frame with a Z in the back. More pics to come.
  2. manyolcars
    manyolcars
    beautiful!
    Piedmont likes this.
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. The37Kid
    The37Kid
    Nice find! With the cowl cut up you may want to look for a 28-29 cowl and mess with everyone. Bob
  5. Piedmont
    Piedmont
    I got a cowl with the car. Need to find the cowl vent cover but other than that she's cherry
  6. AHotRod
    AHotRod
    Will it have a OHV Hot Rod engine?
  7. Piedmont
    Piedmont
    Searching the junk piles everyday. Love to find a nailhead or something cool. Flathead out of the budget at the moment
  8. AHotRod
    AHotRod
    Contact Quain Stott (here on the HAMB) who runs the Southeast G***ers over there, I'd bet he can give you some help.
  9. Piedmont
    Piedmont
    Well been collecting parts and have a pair of split bones and I beam axle.My buddy Dave at Hot rods 101 in Woodruff SC has been cool and is letting me use his frame table to build a frame. Got the new cowl cut up and ready to go on and she will look like a 27 again.Not a ton of progress up till now but it takes time.The door tops will be next. I have a mint drivers side top but the p***enger side will need to be made from nothing.More pics to come unless you want to see a pile of parts.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    That'll make it a 1927-1/2.
    Sent from my SM-G930T using The H.A.M.B. mobile app
  11. Piedmont
    Piedmont
    Been a slow run but I got the cowl welded on today.Cut the belt line off the top to give it a cleaner look.Got access to a frame table in 2 weeks so more progress to come.
    AndersF likes this.
  12. Cool, I'm building a 27 drag coupe. So I'm not planning on using my cowl vent. So if you need one, PM me, and you can have it. Ron...
  13. Piedmont
    Piedmont
    Cut the header panel out tonight.It works well with a 3 foot tall roof but not so good with a 1 foot tall roof. Need to brace it up but overall a huge impact as far as vision out of the cabin.
  14. Rand Man
    Rand Man
    I can't agree more. I have a pretty good idea of how I want to to it on my '29, but always interested in seeing another approach.
  15. Even on As the header panel is not to clever.
    The top of the windscreen,because of the frame,is about 1" lower than the top of the gl*** on the doors.
    I took 4" out of the roof,3" out of the windscreen frame and knocked up a new header panel 1" shallower than the original.Once glued back together the line of the gl*** was level all round.I think it looks sharper this way,IMHO.
  16. Rand Man
    Rand Man
    I'm more interested in how you're going to reinforce that area and reinstall the windshield. I'll have to do mine differently, because my visor is already welded in and stuff. Also, I like Model T's.
  17. Piedmont
    Piedmont
    Got the windsheild frame tacked up. Going to have to use the shrinker/strecher for the curve on the bottom.I used 1/2 angle for the frame top and sides.The angle gives the header stability for the top.Once it's all fitted I am going to tack it in permanent.It will be a fixed window and installed with window strip calk adhesive.It is kind of a strange way to do it but hey it works
    kidcampbell71 and Ron Funkhouser like this.
  18. Rand Man
    Rand Man
  19. Piedmont
    Piedmont
    Been a while progress has been a little slow. Got the back half of the frame mocked up and tacked up.Going to pinch the front from the firewall forward.Motor and trans mocked up for ****s and giggles.I will also be taking out that trans tunnel 20161215_190554.jpg 20161215_192535.jpg
    Ron Funkhouser and AndersF like this.
  20. Pete
    Pete
    Oh god, please HAMMER the roof!
  21. Pete
    Pete
    Chop it hard. Aka hammer
  22. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Very very very cool so far!!!!! Great build.
  23. Piedmont
    Piedmont
    Got a lot done over the long weekend. The frame is about complete and motor mounts in place.Put some Brookville frame horns on for looks.Scored a 9" cheap and will be cutting it down and respline the axles when I get the lenth dialed in on them.Going to locate the wishbone bracket next.
  24. Piedmont
    Piedmont
    A little more progress.Got the body located and started cutting up that goofy trans tunnel someone put in likely in the 70s.More parts rolling in every day. Its going to set much lower than in the pics.Time to get to work on the cowl bottoms next
    AndersF, Jet96 and Ron Funkhouser like this.
  25. Piedmont
    Piedmont
    Some progress for tonight.For the 4 bar haters i;m sorry but I work at a hot rod parts house so I got this stuff much cheaper than an original spring.For the rest of you enjoy.
  26. Piedmont
    Piedmont
    OK got the body on for the first time and adjusted the ride height.Very happy with the way the *** end sits but need to come down a good bit in the front.Started on the steering but still have more work to get that the way I want.Enjoy
  27. 39 Aaron NZ
    39 Aaron NZ
    Well done it looking great. I really like your frame, as it has a hell of a kick in it going over that 9" and the way the body lines up with the rear tire.
    Cheers Aaron.
    Sent from my SM-G360G using The H.A.M.B. mobile app
    J53 and Piedmont like this.
  28. 39 Aaron NZ
    39 Aaron NZ
    Yeah came out ****** nice! This is a great build to watch. Cheers for sharing, Aaron.
  29. Piedmont
    Piedmont
    Thanks it is coming along nicely.Getting a lot of love from you guys across the pond.
  30. AndersF
    AndersF
    Cool to follow another 27 coupe build.
    The stance seems to be about same as mine.
