1940 CONVERTIBLE PRICE LOWERED SOLD!
Discussion in 'Cars For Sale' started by 40fordconvt, May 2, 2015.
  1. 40fordconvt
    40fordconvt
    City: QUICKSBURG
    State: Virginia
    Price: 18,000
    I AM OFFERING MY 1940 FORD CONVERTIBLE PROJECT. IT WILL MAKE A VERY NICE 50S STYLE HOT ROD CONVERTIBLE BUT IT IS APART AND NEEDS WORK. WILL NOT SELL ANY PARTS SEPERATE, ALL AS ONE ONLY! I HAVE A RUST FREE ROLLING CONVERTIBLE FRAME WITH MATCHING NUMBER ***LE.
    NICE CONV DOORS WITH ALL PARTS , GOOD FENDERS, DECENT HOOD, TRUNK LID WITH SOME DENTS, TOP BOWS WITH WOOD HEADERS, DECENT USED TOP WITH REAR WINDOW, DECENT GRILLE, ALL TRIM, EMBLEMS, HOOD CHROME, TRUNK CHROME & HANDLE, CHROME BUMPER BRACES, NICE BUMPERS, GUARDS, & TIPS, REDONE SEATS, ROLLED & PLEATED UPHOLSTERY FOR THE SIDES, NICE FUEL TANK, ALL NEW GL***, ALL NEW RUBBER, WINDSHIELD OUTSIDE TRIM, INSDIE MOULDINGS ARE SEDAN AND NEED TO MODIFIED,3 DASH BOARDS,39 TRANSMISSION, COMPLETE COLUMBIA 2 SPEED REAR LESS CONTROLS (BULLET PROOFED) APART, RADIATOR, 1953 OLDS 303 ENGINE COMPLETELY REBUILT & BALANCED NEVER STARTED WITH 471 BLOWER SETUP, OLDS HEADER FLANGE KIT,55 OLDS DIST W? PERTRONICS MODULE, EXTRA 303 ENGINE FROM A RACE CAR, 1950 OLDS 3 SPEED TRANS, 2 FORD 4 SPEED TOP LOADER TRANSMISSIONS WITH JEEP FLOOR SHIFT TOP TO GO WITH THEM, ADAPTOR BELL HOUSINGS OLDS TO FLATHEAD & OLDS TO 49-64 FORD, KIT TO CONVERT TO OPEN DRIVESHAFT, DISC BRAKE SETUP TO FIT THE 40 SPINDLES. WITH THIS DEAL YOU DO NOT HAVE TO START HUNTING FOR PARTS AS I HAVE DONE THAT FOR THE LAST 20 YEARS. lOTS MORE EXTRA PARTS. I BOUGHT ANOTHER 40 CONV SO I HAVE TO SELL THIS ONE. IF INTERESTED GIVE ME A CALL. AS IS STEVE AT 540-331-1950 PRICE LOWERED $14,000
  2. 40fordconvt
    40fordconvt
    LOTS MORE PARTS THAN LISTED SUCH AS A COMPLETE DUAL QUAD SETUP FOR THE OLDS, ORG 4 BARREL INTAKE & CARB , WOOD KIT FOR THE REAR SEAT AREA AND MORE AS I REMEMBER THINGS I GOT FOR IT THANKS
  3. 40fordconvt
    40fordconvt
    btt Make Reasonable offer. Can you figure what it would cost to gather all these parts up? Thanks
  4. 40fordconvt
    40fordconvt
    PHOTOS OF THE BLOWER FINISHED & READY FOR THIS PROJECT wILL OT SELL SEPERATE OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg OLDS 303 471 BLOWER & INTAKE 1.jpg
  5. 40fordconvt
    40fordconvt
    Updated photo with the conv windshield & rear sheet metal installed. OPEN TO RESONABLE OFFERS AS ***EMBLY CONTINUES? 1940 conv cowl installed.jpg 1940 ford conv rear installed.jpg 1940 ford conv right side.jpg
    avachace and Nailhead Jason like this.
  6. 40fordconvt
    40fordconvt
    UPDATED Photo 8/22/16.
    Nice conv doors not rotted need normal repair at lower hinges with ALL hardware, latches, window regs, gl*** frames and vent gl*** ***emblies with hardware and rare garnish mouldings door handles etc
    Complete top frame with org rear wooden bow and org (rough) and have a nice one used and one new blank front wooden bow. Nice top (tan) with rear gl*** used (they changed color) all latches
    Top vac cylinders and control valve
    All new gl*** channels & rubber and weatherstripping
    Windshield outer trim with clips, inner w/s garnish from a sedan needs modified new interior screw kit
    Nice org fuel tank & filler neck
    Front and rear seats redone in a close to org pattern & color & rolled & pleated Also interior door panes ready for upholstery, also 1 roll of rolled & pleated upholstery for the door panels , side panels and kick panels, and the side panels that go beside the rear seat.
    3 dash boards (not sure all are conv) speaker trim & glove box door
    Useable/repairable fenders, hood & trunk lid and running boards and new rubber covers for on them new fender bolts & clips also used coupe trunk floor
    New rear under trunk lid panel & l & r front floor board replacement panels
    New headlight doors & good headlight ***emblies and good complete tail light ***emblies
    Nice trunk handle ***embly both front and rear tag brackets
    New trunk lid emblem, Nice front & rear bumpers with bumper guards & bumper tips, chrome braces
    All side trim with clips
    1953 OLDS 303 engine completely rebuilt and balanced. Bored .040 Ross pistons sealed power plasma rings, sealed power rod & main brgs, std crank polished, heads rebuilt and exhaust ports opened up, new timing chain & gears, WOLVERINE 3/4 race cam (sent to comp cams and had it profiled to see if it work with the blower), solid lifters and adjustable 1.5 rocker arms. oil pump rebuilt & kit to run screw on filter, new water pump, 56 olds dist with pertronix kit to install in it. Chrome org Olds valve covers,2 flywheels & mics used starter, used chrome gm 1 wire alt, gear reduction starter (small) needs a little machining to finish
    Cragar 471 blower intake manifold with pop off valve, rebuilt 471 blower completely gone thru to convert to gas , relief valve and sight gl***, and drive snout with cogged belt pulleys & belt (sm block chevy) and an org olds balance pulley for the side supercharger belt.
    adaptor housings to run olds to 49-64 ford trans and olds to flathead trans & pilot brg adaptor
    1940 Pu floor shift trans
    50s Olds 3 speed trans with housing &floor shift linkage
    2- 60s ford top loader 4 speed trans & 2 t170 jeep shifters & tops to convert these trans to make the toploader floor shift
    Columbia 2 speed rear end (apart can see or I will put back together with option for open or closed drive) bullet proofed by Johnny Stokesburg new bearings etc, with clutch valve , vacuum canister, some speed adaptors
    1 kit to convert closed to op drive shaft to open with torque rod
    2-46-47 pu center rear end sections
    Olds & 40 ford radiators
    Kit to install ford p/u rotors & gm calipers complete with rotors & brake hoses
    Org steering column with key & a Gm column with all wiring harness from a Nova. Complete extra 51 303 olds engine with Howards F6 full race cam, domed pistons, adj. rockers etc.
    Org olds 4brl carb on cast intake
    A two 4 brl set up on alum intake w/org type carbs
    Single 4 brl carb adaptor plate for the 471 w/org type carb
    Alum starter change over lower starter housing to move starter to right side & oil filter adaptor.
    Body is coming together as I get time. Lots & Lots of extra parts, rears,front axle, drums. CASH OFFERS? Thanks!
  7. 40fordconvt
    40fordconvt
  8. 40fordconvt
    40fordconvt
  9. 40fordconvt
    40fordconvt
    303 olds with 471 blower setting on it.jpg 303 Olds with the 471 blower setup setting on it.
  10. 40fordconvt
    40fordconvt
  11. 40fordconvt
    40fordconvt
  12. 40fordconvt
    40fordconvt
    SOLD!
