Projects 1932 3W Coupe Lakes Racer-Thrash for TROG West
Discussion in 'The Hokey Ass Message Board' started by So-cal Tex, Jul 26, 2016.
  1. So-cal Tex
    So-cal Tex
    I am not sure as this picture was stolen off the HAMB, but the guy building the car is in Tucson so it could be Chip the Louver Guy
  2. 383deuce
    383deuce
    big deuce I think there is a guy down your way in Wichita that does them. I have his card at the shop. Will look it up and get back to you.
  3. So-cal Tex
    So-cal Tex
    Well, I worked solo on Friday afternoon for a couple of hours finishing up a few little details:
    I also mounted the push bar after painting it brushed aluminum which will match the roof insert, eventually it will get nickel plated when the car gets gloss black paint.
    I made a gusset for the column mount 3/4 square tube that we ran behind the dash and then mounted the dash cluster to see what it looks like with the banjo wheel,
    Mike cut out the aluminum .063 3003 insert and once Nick shapes it with a nice crown and I am sending it over to Chip to punch some louvers in one and I am keeping another one flat in case I want to stay dry
  4. Perfect in my book. Start driving the wheels off it
  5. So-cal Tex
    So-cal Tex
    My first goal was TROG but I didn't get selected because they were already full so my second goal is to drive by my 40th birthday in February of 2017 which I think is doable if I keep at it.
    It seems when you build a tradition car it take twice as long because their no TCI mounts or 1-800-Speedway parts to make the OG Henry stuff work , it takes a lot of fabrication and patients.
  6. 383deuce
    383deuce
    I hear where you are coming from on the making the OG Henry stuff work. But you have done a great job to date.....I really like this build. Hope to make a run to Bville with it some day.
  7. Runnin shine
    Runnin shine
    You've inspired me so much that I'm going into the garage tonight to work on my rear spreader, thanks Man!
  8. rtsidejohnny
    rtsidejohnny
    Really nice build, sorry about TROG, a lot of us were too late. Hope I'll see the car driving around Pismo anyway!
    If I may ask, how are you planning to attach the roof inserts? Will it be weather sealed if removable? I would love to see photos from the inside when you get to that point because I was thinking the same thing for my 5 window.
    Thanks much, keep up the good work!
    Johnny
  9. So-cal Tex
    So-cal Tex
    My plan is to use a ****on head screws around the perimeter of the original insert hole so it looks like rivets on the aluminum but yet removable , then I plan to use some thin weather stripping around the underside of the insert so when the ****on head screws are tightened down it creates a weather tight seal, kinda hard to explain so once the insert is shaped and ready to be installed I will get some pictures.
  10. zombiecat
    zombiecat
    Great thread. It's given me a good deal of inspiration. I recently acquired a 32 3 window that was chopped and channeled a very, very long time ago. It's pretty rough and I've been trying to decide which direction to go with it. Maybe I should try to find out as much as I can about the cars history before I go any further. Good job on yours!
    Runnin shine and kidcampbell71 like this.
  11. Pete
    Pete
    TROG or no TROG .... Car looks fantastic!
    Think of it this way, trog was a great motivational tool for you to get it this far in a short amount of time.
    Pretty cool if you ask me.
  12. rtsidejohnny
    rtsidejohnny
    Thanks so-cal Tex, interesting idea. It would be great to see pics, thanks!
    Johnny
  13. Gary Addcox
    Gary Addcox
    I am glad to see you are keeping the top as it was done back when. Many cars on the HAMB resemble each other in one or more ways, yet yours is unique, a really fresh approach. Altering the chop would change what the original builder intended even though that style chop is not "accepted" today. Maybe "accepted" is not the right word, but you have a unique style, AND it is the only one on the block. I like what you are doing and hope to see you at TROG. RESIST THE NAYSAYERS, BUD ! !
    Runnin shine likes this.
  14. Gary Addcox
    Gary Addcox
    ALRIGHT ! ! I love a good duel.
  15. So-cal Tex
    So-cal Tex
    More updates today, so since Nick (the owner of Hubcap Hot Rods and Kustoms) is moving his shop back up to the Deer Valley area in October so he is dedicating most of his time to finishing up my car before he makes the move, which makes sense because it is one less car to move, right?
    Today's progress is he finished TIG welding the '39 Merc Steering box mounting bracket to the frame today, and tomorrow the plan is to get working on grafting '40 pedals into a CE X member , unfortunately I did not get any pictures today but I will grab some before the week ends. Stay Tuned........
  16. So-cal Tex
    So-cal Tex
    As promised, the cross steer bracket is TIG welded into place
    Nick and Mike put a nice crown in the aluminum roof insert before the louvers get punched into it
  17. adam401
    adam401
    Your coupe is stunning. The stance with the reverse chop is tough as nails. Excellent job
  18. So-cal Tex
    So-cal Tex
    Many people on this forum have asked how to put early Pedals in the Ch***is Engineering Cross member, well it can be done but requires cutting the pedal mount area on three sides and bending it out about an inch to get your pedals to face forward, if you don't do this your pedal point towards the front left tire, it also requires you to clearance the top side of the X-member some, the '40 pedals I used will work well with the '40 style cross-shaft clutch fork.
    Kevs56 likes this.
  19. chevydave1965
    chevydave1965
    from Iowa
    That's some VERY nice work !
  20. So-cal Tex
    So-cal Tex
    So I stopped by the shop today to check on the progress and the guys got the aluminum roof insert installed using ****on head allen head screws which look like a rivet but are removable, the plan is to make two inserts, one solid and the other louvered.
    Mike got the pedals all installed and the floor back in, here is how the column mount tri-bar bracket looks mounted to the floor, sorry for the ****py cell phone pictures, they are very dark now the roof insert is installed.
  21. Just checking in on the progress looks killer
  22. So-cal Tex
    So-cal Tex
    Thanks Ron, today is a big day for my coupe because it is headed back to my shop after 2 years and 2 months at Hubcap Hot Rods, good metal work takes time and you gotta be patient if you want quality. I will shoot some pictures tonight once I get it home.
    But here is where we started almost 10 years ago in Colorado.........
    To a very different look and late '40s Dry Lake racer look or should I say her roots.....
    brEad, Tim_with_a_T, chop job and 7 others like this.
  23. Mr48chev
    You captured the "look" pretty well.
  24. So-cal Tex
    So-cal Tex
    Well I got the coupe home last night and it is the first time in daylight for 2 years, wipped the dust off and got some pictures....
    I had to put my original Deluxe horn ****on on as well.......
  25. louisb
    louisb
    Perfection!
    --louis
  26. john dioli
    john dioli
    What a great build love the stance and whole thing
  27. Yep pretty much bad ***. Are you going to take it too deuce days?
  28. So-cal Tex
    So-cal Tex
    Its not a runner yet but I might, what are the dates?
  29. kidcampbell71
    kidcampbell71
    Wow. The yellow roadster looks killer too. San Diego origins, maybe already in print ? Hmmmm', hmmmm' ? Your garage loves you by the way. Hell, me too !
