1952-59 Ford 1955 Ford Fairlane parts for sale
Discussion in 'Off Topic Hot Rods & Customs' started by Goldchainer$$$, Aug 27, 2016.
  1. Goldchainer$$$
    Goldchainer$$$
    from L.A.
    **** Read..... I will not answer Text or Emails asking if parts are still for sale. If ad is up, stuff is still for Sale.
    1955 Ford Fairlane, 55 Ford, Y-Block, Ford-O-Matic.
    Some parts have been blasted with gl*** bead.
    Parts are off a 1955 Ford Fairlane, 272 Ford Y-Block
    Pick-Up in Santa Clarita, Valencia
    call 818-266-3540
    **1955 Ford V8 272 Y-Block what you see is whats for sale, car was not running when i bought it.
    I have an engine hoist to help you load it....$100.00
    *** Stand is not for sale....
    **Ford 272 Y-block exhaust manifold headers...$100.00
    **1955 Ford Parking Light Housing (Left & Right)...$50.00
    These are originals taken off of a 1955 Ford. The insides of the housings has some surface rust and they have a few dings and minor scuffs.
    **Ford steel wheel 15" has K-H stamped on wheel. (only 1) $25.00
    **1955 Ford Ford-o-Matic, from a 1955 Ford Fairlane w/V8 272 what you see is whats for sale, car was not running when i bought it...$100.00
    **1955 Ford Ford-o-Matic, rebuilt Torque Converter from a 1955 Ford Fairlane w/V8 272...$100.00
    **1955 Ford p***enger car front splash pan, Surface rust only, good shape...$200.00
    **1955 272 y block timing pointer...$20.00
    **1955 272 y block Oil Vent, Draft Tube...$20.00
    **1955 272 Y Block Ford oil pan front sump...$75.00
    **1955 272 y block Original Used Steel Vintage Valve Covers, no dents, surface rust only...$20.00
    **1955 FORD Y-BLOCK 2V CARBURETOR INTAKE THROTTLE BELLCRANK...$20.00
    **1955 Original accelerator linkage rod used on 1955 with a 272, Y block V8 engine and automatic transmission...$20.00
    **1955 272 Ford Y block front mount plate...$40.00
    **1955 grill center piece, small ding, Straight, No pitting, Good chrome...$20.00
    **1955 FORD Y BLOCK 272 V8 GENERATOR BRACKETS...$20.00
    **1955 Ford Fordomatic Air Vent cover...$20.00
    **1955 272 Ford Y Block Valley Pan Valley Cover...$20.00
    **1955 Y Block Flex Plate, ford-o-matic...$20.00
    **1955 Ford 272 y block crankshaft balancer...$40.00
    **1955 FORD 272 y block V8 TIMING CHAIN COVER...$40.00
    **1955 Ford original accelerator shaft to engine support hanger, 272 V8 auto...$20.00
    **1955 Ford 272 Y-Block Cast Iron Oil Pump, (needs gaskets)...$40.00
    **1955 Ford 272 Y BLOCK INTAKE MANIFOLD...$40.00
    **1955 Ford 272 y block sump and pick-up tube (some small pin holes.)...$40.00
    **1955 Ford 272 y block oil cap original, (some small pin holes.)...$20.00
    **1955 Ford 272 Y-Block Water Pump Pulley...$20.00
    **1955 Ford 272 y block Fuel Lines to carb...$20.00
    **1955 Ford 272 Y-Block Fan Blade...$20.00
    **1955 Ford 272 y block Engine Motor Mount Support Front Steady Rest...$20.00
    **1955 Ford 6v battery tray...$20.00
    **1955 Ford-O-Matic dipstick and tube...$30.00
    **1955 FORDOMATIC FLEX PLATE starter gear to torque converter Needs new gear, has wear...$20.00
    **1955 Ford-o-matic small cover to converter housing...$10.00
    **1955 Ford-o-matic cover to converter housing...$10.00
    **1955 2 barrel carburetor Ford 272 y block, Original Ford part EBU-1...$20.00
    Clink on link to view photos, they're not in order so if you have any questions please send me a PM
    http://s1250.photobucket.com/user/55fordtownsedan/library/
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    REMEMBER the rules. Put the word SALE in your heading that makes it EZ to find by search. DO NOT respond to the ad in the forum do that by using the "Conversations" feature the sale is between the seller and buyer,as items are sold use "edit" delete them.Thanks.
    Goldchainer$$$ likes this.
  3. Goldchainer$$$
    Goldchainer$$$
    from L.A.
