Technical ***September 2016 Banger Meet - Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 3, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list (finally):
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Felipe Toltecatl likes this.
  2. ratamahata
    ratamahata
    from Argentina
    Ok! Very excited!! Ch***is sandblasted![emoji2]
    Ain't a Rat lover!
    cactus1 likes this.
  3. I'm back !! 110 days in therapy ! I can almost walk.
    Artiki, Bigcheese327, Dannerr and 6 others like this.
  4. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    I lingered around on last months board, feel a bit humbled in front of you banger gurus but would mind getting in on things.
    I'm building a T with a Chev '28 on the T pan and box which is proving an interesting challenge
    If you cut me in half I'm running on 4 cylinders so it seems the place to be.
    Andy
    cactus1 likes this.
  5. denis4x4
    denis4x4
    from Colorado
    Long been a proponent of friction shocks...however, switched to Armstrong lever shocks from a Sprite ala Limeykid. This is the mockup pattern. image.jpeg
  6. ratamahata
    ratamahata
    from Argentina
    Wow!! In my town the 4 cylinder Chev was called "Chevroletin"
    Ain't a Rat lover!
  7. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    I don't know if that's good or bad.....
  8. ratamahata
    ratamahata
    from Argentina
    It's a good thing!! It's a diminutive only! It's for identifying the 4 cylinder cars of the later 6 cylinder Chevrolet's!
    Ain't a Rat lover!
  9. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Ahh I see. It's my way of getting OHV. Can't be doing with spending 2k on an accessory T head. Also think it's way cooler. More rod than speedster
    It's been a long ambition to run a traditional on Pendine sands
    ratamahata likes this.
  10. 62pan
    62pan
    Welcome back Bill, was wondering where you were.
  11. blgitn
    blgitn
    110 days?!
    Dang Bill, what're you getting over?
  12. waxhead
    waxhead
    from West Oz
    Any pics Andy, we love photos :)
  13. Bluto
    Bluto
    Bill It's good to see you back
    This is what I was doing yesterday
    More tiny 4 bangers.......
    lbcd, fur biscuit and MJW like this.
  14. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Here's a couple of shots. The engine is apart waiting for me to get at the rear casting with a grinder. The heads having new valves and blocks having A piston and rods fitted.
    The zenith carbs are going on a manifold hopefully being supplied by a fellow HAMBer
    And the proposed siting of an A 3 speed behind the T Trans. Haven't decided weather to run the 2 T speeds or leave the bands out and use the straight through gear.
    Andy
    cactus1 likes this.
  15. Bluto
    Bluto
    Please strip and inspect the carbs making sure the every details are the same between them. Chevy carbs sometime have differences that make a non-matched pair almost un-tuneable sometimes
    Dannerr likes this.
  16. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Yeah will do. Pretty sure they have different jets in there so will have to be totally gone through
  17. Bluto
    Bluto
    Not just jets throat dia as well. I use a pair of Carter YF's and it took a long time to get two carbs that made a set
  18. bent garage
    bent garage
  19. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    These carbs are British built. The housings are bob on.
  20. Bluto
    Bluto
    British built....... How bad do they leak?;)
    Artiki likes this.
  21. Binger
    Binger
    from wyoming
    Checking in for the month. Test drove my coupe yesterday! It ran and drove beautifully. Ended up driving it maybe 10 or 15 miles. Need to drive it much more to find any bugs before the Hill Climb in less than 2 weeks. Only some details left now. Who is going to the Colorado Hill Climb this year?
  22. V4F
    V4F
    from middle ca.
    jimski , how many are yours ?
  23. Bluto
    Bluto
    None..... all my 30's BMWs have six cylinder motors.
  24. V4F
    V4F
    from middle ca.
    thanks . nice collection !
  25. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    2nd white one I've seen in as many days. Can't believe how good it looks !
  26. Binger
    Binger
    from wyoming
    The car is a grey, a very light grey and the maroon looks almost red. The lighting at the drive in and in my shop make it look lighter than it actually is. Thank you for the compliment!
  27. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Feel a bit stupid now... Fact still remains, she looks sweet
  28. Binger
    Binger
    from wyoming
    No need to feel bad about it. Colors always look strange in pictures. I about freaked out when I started spraying the grey and was worried how light it was. The maroon also looked almost red too. hard to determine colors from small paint chips in a book at the paint store.
  29. winduptoy
    winduptoy
    Binger
    Looks good, real good
    I'm still in for the Colorado hill climb. I'm staying at the KOA in Central City
  30. Dustyp489
    Dustyp489
    Just checking in , want to keep up with what is going on . Coupe looks great ,love the build
    Binger likes this.
