Advantages of bearclaw latches?
Discussion in 'The Hokey Ass Message Board' started by 55chieftan, Sep 6, 2009.
  1. RICH B
    RICH B
    Try a quality latch and see how it goes; the mounting is the same, should be no paint problems.
    38Chevy454 on here sells good latches.
    BIG-JIM likes this.
  2. 3banjos
    3banjos
    from NZ
    Yep, thats the guy Rich. Terry. Good to deal with too. Give him a bell Jim.
  3. BIG-JIM
    BIG-JIM
    from CT
    Gonna see if it's just out of adjustment first before I go spending money. Thanks for the lead on the latches. I'm gonna need a set for my 34 so I may end up buying 2 sets.
  4. GasserTodd
    GasserTodd
    On my 48 Chev truck we installed the bearclaw latches (a pain in the **** for sure) and I had ongoing problems with the door locks. So to ensure my truck stayed locked up, we got some actuators and made a couple of metal pins and bought a $60 car alarm kit with central locking as the non alarm kit was $70!! Fitted the actuators into the door pillar and drilled a matching hole in the door frame. Hit the lock ****on on the key fob and the pin goes forward into the dor and locks it.
    I figure you could keep the original door latches and fit a keyless entry kit and then your doors would never flop open on the corners. Safety, and the original look if thats important to you.A win/win deal.
  5. X38
    X38
    I've bought from him also. Good latches.
  6. wsdad
    wsdad
    Don't have x-ray eyes to see exactly where the post is aligning with the latch? Here's a little Superman-free trick.
    Squish some playdough around the latch. Then you can see exactly where the post hits by the impression.
    You may have to lubricate (WD-40) the post so the playdough won't stick.
  7. BIG-JIM
    BIG-JIM
    from CT
    Thanks for all the great tips and info. It may be a few days till I get down the 3 flights of stairs to my garage. Seem like someone parked a house on my sciatic nerve and I am very limited in my ability to walk. Legs are numb and the pain is excruciating. The one thing I'm grateful for is that the doors aren't suicide like the 34 tudor. At 70 on the highway it would have been real bad. That has old style latches and they will be replaced with bearclaws. Just want to see if its out of adjustment or actually a bad latch. If it's a bad latch maybe see if I can buy just that one side and a pair for the tudor but till this back heals up, I'm kinda dead in the water. On a side note the tudor will have safety pins like the wife's 32.
  8. Canuck
    Canuck
    There is a solution for those that don't like the hair trigger action of the latches.
    When I was laying out the linkage for my latches, I added a slide area on each release arm that the handle has to travel through against the spring in the handle before the latch releases. The inside and outside handles are nearly at the end of their travel before the latch releases. In the attached picture you can see the slide area for the inside handle in the ugly looking brazed piece of metal. The outside handle slide area is in the bell-crank in the lower part of the picture.
    This install is on a Model A Ford, that necessitates the linkage going down under the window then back up to the latch. The inside release is a 48 Chevy. The latches are "Eberhart 9-400-R and 9-400-L" that feature dual arms so you can have inside and outside release handles.
    Canuck
