Projects The Helmuth Brothers Coupe
Discussion in 'The Hokey Ass Message Board' started by HelmuthBrothers, Nov 19, 2013.
  1. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Yeah that brace is used to stiffen the body, mount the rear side of the gas tank, and split the trunk from the interior. I have a metal cover for the brace that we'll be insulating.
    Here are some old pics
  2. Fitnessguy
    Fitnessguy
    Cool I like what you have done. Mine is the same basic idea. I built a solid frame that the tank is bolted to then I welded tabs to that frame where the bulkhead attaches to. I used wood so I could shape it easily as a tight fit to the body contour sealing the cab from the trunk. Using rubber seal on the edge of the wood where it meets the body. It's one thing I really like is seeing different approaches to the same task. Great way to get ideas! [​IMG][​IMG][​IMG]
    D-Russ likes this.
  3. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Got some more updates. Today were tightened up the body bolts, mounted the tank and the Kaiser tails.
  4. Binger
    Binger
    from wyoming
    Looks great! I like the lettering on the gas tank.
  5. pat59
    pat59
    Lookin' good! Won't be long now. :)
  6. loudbang
    So is there going to be a family fistfight to see who gets to drive it on it's maiden voyage? :rolleyes:
    Hotdoggin DaddyO likes this.
  7. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Hahah I'm still debating if it's going to be me or my dad driving it first.
    Hotdoggin DaddyO and loudbang like this.
  8. Imwalkin
    Imwalkin
    from Tucson, Az
    I drove mine first, very carefully. My dad got in right after and started to driving like he stole it.
  9. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Boring updates. Little by little just knocking away at it. Cowl, dash, gauges, and steering all done.
  10. loudbang
    Jeeze who is going to be the brave soul to put fuel in this beauty? First brother to get drops of gas on there forfeits driving privileges for a month. :eek:
  11. Dino 64
    Dino 64
    from Virginia
  12. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
  13. El Hueso
    El Hueso
    What kind of column shift is that? Looking good!
  14. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Thanks a lot man. This is a limeworks safety shifter hooked up to a 700r4. It's a little tricky getting the linkage hooked up around the brake pedal under the floor, but we finally got it last night.
    Studebakermatt and loudbang like this.
  15. pat59
    pat59
    Nice it looks realy good. :)
  16. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Great day today. Put the face on, headlights and headlight bar, radiator rods, cowl and grille lacing, and some other small things like the battery box and trans dipstick. I painted the vintique insert gloss black this week. After about two hours of taping and another hour or so painting it came out great.
  17. AHotRod
    AHotRod
    Q-Jet for the WIN !!!
    What are your plans for the air cleaner?
  18. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Haha yeah man. Going to run an original style 58 corvette 4bbl air cleaner. The thin 14" round cleaner with the loiters around the side.
    AHotRod, loudbang and mad mikey like this.
  19. Rand Man
    Rand Man
    HelmuthBrothers likes this.
  20. mad mikey
    mad mikey
    Very nice hotrod. Pleasing to the eye.:D:D
  21. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
  22. Weedburner 40
    Weedburner 40
    Wow! I can't believe it's that far along and you haven't driven it yet. You're way more patient than I am.
  23. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Tell me about it. I'm losing my damn mind.
    Studebakermatt likes this.
  24. loudbang
    Really coming together, looking like a real Hot Rod now. The (Booooooooo) Chevy orange really pops.
  25. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Thanks man. Yeah I'm glad I finally put the front end on. Now you can see it. And yeah the orange works great as a contrasting color against the brown. Really happy with it.
  26. dan@larescorp
    dan@larescorp
    The car is looking great!
  27. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Nothing crazy but we're about the start wiring this weekend coming up. Lot of small stuff out of the way. Most not even picture worthy, but ran all the wiring from the battery to the starter and killswitch. Started to dynomat, mounted my new shiftknob courtesy of @44tooth on instagram, riveted the headlight / firewall / delcoremy gen tags, and since I have no gauge lights I decided to use a motorcycle license plate bolt light to replace the center bolt in the dash rail. Also mounted up the Ron Francis Bare Bonz fuse panel behind the dash, and mounted the ignition / headlight / turn signal panel. The turn signal is a Ron Francis 3 position toggle switch.
  28. Binger
    Binger
    from wyoming
    Looks great! I am enjoying seeing this car come together!
    loudbang and HelmuthBrothers like this.
  29. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
  30. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    More small updates as I had to order allllllll the little stuff for the inside of the car and the door parts. Ton of **** on backorder at first. Finally getting things in the mail on a daily basis. In the meantime we mounted the deck lid and finished the wiring 100%. Can't tell you how many hours we have into fitting the deck lid to the car. I was afraid after it was painted the gaps would shrink and might rub in areas but it clears on all sides perfectly. Hard work paid off. It's rare to see a model a decklid fit nice in the first place. So we're happy. This weekend we mount the doors. Also going to restore the tag I got for it. It reads 30A. Perfect for the car. Going to do it black with orange letters like earlier nj tags.
