I have a friend that is looking for info on how to convert/upgrade the stock wiper system of his 55 Caddy to electric possibly removing the cable operated system as well. Thanks Vinnie
http://www.thenightprowlers.com/ look under "door stuff" they sell electric motor replacements for most cars. i bought one for my 53 buick, fit perfect, used stock linkage.
Newport engineering has a pretty good product. I have had one in my 57 buick for 3 years now and never had a problem. -Nick
Thanks Jab and Nick, He is considering Newport engineering but his wiper transmission need rebuild, plus one of the wheelbox is broken so he is considering either rebuild and replace the broken one or trying to find out if someone has replaced all the system for this car with something different. On my 54 chevy I replaced everything with a lucas motor and wheelboxes but unlikely the wheel boxes shaft of the lucas system are not long enough to go trough the cowl of his caddy. Thanks again Vinnie
Specialty Power Windows, wipers will replace all the stock linkage, and can be set up any way you want.
The kit of SPW looks like the one I used. I'll contact this company to check how long is the shaft going through the cowl as the lucas one is not long enough. In case is not long enough, Newport is the only alternative. Thanks again Vinnie
