Projects Oh no not another Willys Gasser build, this time a Willys shop truck
Discussion in 'The Hokey Ass Message Board' started by langy, Dec 8, 2013.
  1. langy
    langy
    Appreciate the positives mike, thank you [emoji106]
  2. langy
    langy
    I got the new legs folded up but the only had black steel so had to sand them clean before doing anything !!!
    One done.
    for some reason I didn't get the rear shocks fitted so I got that done too, they are MGA levers off a friends race car that went telescopic, they are re valved so much stiffer.
    Also enlarged some of the existing ch***is holes and cleaned them up
  3. greaser
    greaser
    Looking good Steve. You're gonna beat me thru the paint booth with this one.
  4. langy
    langy
    I'm trying buddy [emoji106]
  5. langy
    langy
    Had a couple of hours at the bench tonight and the seat vapour blasting came back so put my seat together, it can now go off to my mate Tom for t*******, diamond tufted is the order of the day
    i Ali made up some shock mounts studs
    AHotRod, volvobrynk and tomkelly88 like this.
  6. japchris
    japchris
    from England
    I always enjoy looking at the details on your rods - they're so 'anti-belly-****on'!
    Great work as usual.
    langy likes this.
  7. langy
    langy
    Glad you find them interesting bud, I try not be boring with my builds but most things have been done these days. Thanks
    Kroombit likes this.
  8. langy
    langy
    Progress not so good Saturday but I got the valve cover nuts polished
    volvobrynk and loudbang like this.
  9. DDDenny
    It's the little things!
    Always a pleasure Steve to open your postings.
    Kroombit, langy and greaser like this.
  10. langy
    langy
    Made up shock axle brackets, just need to clean case and tig them in place.
    Been thinking about axle location, a pan hard won't work correctly with a transverse spring in my opinion so been looking at alternatives, thought about a Mumford set up but it's a bit to complicated for the space I have so decided on a Watts linkage.
    First job was to make the centre pivot out of a lump of aluminium bar.
    Next some tube was found and threaded inserts made up
    A simple bracket was made to start with and then added to as I went
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Wow! What a nice Watts link bracket. These usually wind up looking like an afterthought This appears to have been planned and made from a blueprint with an eye to style.
    langy likes this.
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    Oh yeah, just "whip up a little center pivot out of a lump of aluminum bar ". Easy for you to say, Steve ! :D
    Glad to see you back on it, mate. We're stocking up on Cider for your next visit.
    Don
    langy likes this.
  13. langy
    langy
    Thanks buddy [emoji106]
  14. langy
    langy
    Hi Don, I was hoping to get over in September but my chemotherapy goes right through to february I'm afraid but as soon as it's done we will be on a plane to diminish your cider stocks [emoji106]
    Hope you are all well and dandy
  15. Chucky
    Chucky
    Nice work! Glad to see the progress, happy that you're up to it.
    langy likes this.
  16. langy
    langy
    Thanks bud, me too [emoji3]
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    Can't wait to see you and Sue again, Steve. Just take it easy and let the Dr's do their thing.
    Don
    langy likes this.
  18. loudbang
    wow real nice work as usual your medical problems have not affected your skills at all.
    langy likes this.
  19. langy
    langy
    I'm ok buddy, just a lot slower [emoji107]
  20. langy
    langy
    Got the ch***is brackets made up and welded on
    Welded some some nuts onto the bars to help with any adjustments
    All done
    Tim_with_a_T, loudbang and greaser like this.
  21. Legendlives
    Legendlives
    Very, very cool. Love the axle bracket, that is pure cl***.
    Keep it coming mate!
    langy likes this.
  22. loudbang
    Looks so much better than "store bought"
    langy likes this.
  23. langy
    langy
    There's no 0800 on my phone [emoji106]
  24. TomT
    TomT
    Glad to see you are getting back in the groove, Steve - your work, if anything, has gotten even better if that is possible! You are amazing - yeah, I know - you are in the amazing business!
    langy and Kroombit like this.
  25. langy
    langy
    Thanks Tom although I'm not sure your praise is so warranted on this build, I'm not being so precious with this build [emoji106]
  26. langy
    langy
    Got the other leg cleaned off and welded in at last, also made up the shock link sleeves, after that popped over to see how brad was getting on with the cab and it's nearly ready for primer.
    AHotRod, greaser, tomkelly88 and 2 others like this.
  27. RockinRivi
    RockinRivi
    Insanely talented…
    awesome work…
    Subscribed…thx for sharing
    David
    greaser and langy like this.
  28. langy
    langy
    Not much to post as got ch***is in epoxy primer and it's taking a while to flat back ready for paint but I've done a few bits
    first made up a br*** adjuster for generator/alternator
    Got my column back from powder coater, it's all stainless with Torrington races, originally had polished it but decided satin black was more suited and cl***y
    RockinRivi, AHotRod and Drewfus like this.
  29. loudbang
    Everything you touch has a touch of cl***.
  30. langy
    langy
    Ch***is now covered in epoxy primer, had to roller it on as got told by spe******t no spraying 2K at the moment, next hi build primer and smooth out a few bits and then some satin black 2K
    Drewfus, RockinRivi, AHotRod and 3 others like this.
