Projects 1930 model a
Discussion in 'Traditional Hot Rods' started by jt1949, Feb 15, 2016.
  1. jt1949
    jt1949
    Engine and trans mounts roughed in... next rear triangulated 4 link.
    Jeff34, waxhead and patmanta like this.
  2. 1931fordtruck
    1931fordtruck
    It would have been nice if i could have done that style trans mount, but a power glide is a wee bit bigger then a T5.
  3. Barnmiester
    Barnmiester
    from wyoming
    Looks like neat build, keep the updates coming!
    jt1949 likes this.
  4. jt1949
    jt1949
    Working on triangulated four link now
  5. jt1949
    jt1949
    Finally fitted the body back on last night. Looks like it will be plenty low enough. Might even raise it up a smidge in the back.
  6. jt1949
    jt1949
  7. raven
    raven
    Naw, just lower it a little more up front.
    Then you'll be good.
    r
    jt1949 likes this.
  8. jt1949
    jt1949
    Difference
  9. jt1949
    jt1949
    Ride hight set!
    brEad and waxhead like this.
  10. jt1949
    jt1949
    Starting to mock up the pedal ***embly
  11. jt1949
    jt1949
    Finally got the frame modifications done and back frome sand blast.
    brEad likes this.
  12. jt1949
    jt1949
    Frame painted and front suspension back on today
    brEad and kiwijeff like this.
  13. very nice work, excuse me for not rereadind the complete thread, but it does not look like you cut the firewall, how the hell is that 6 cyl fitting? did you streach the frame?
  14. jt1949
    jt1949
    I am using a 153 inline 4cyl chev engine. Fits great.
  15. jt1949
    jt1949
    Got the rearend cleaned up today... put the together
  16. jt1949
    jt1949
    Fitting the 153 back in for good today. Modified the input shaft of the t5 to fit with the older motor flywheel
    kiwijeff likes this.
  17. jt1949
    jt1949
    120mm and CoolYourJets like this.
  18. jt1949
    jt1949
    Ordered up intake manifold carb and header from clifford performance today. Should make a huge difference in the old inline 4
  19. jt1949
    jt1949
    153 ci chev
  20. Make sure the header clears your wishbone. I ended up returning (arranged in advance) the one I got from them years ago for my AVATAR. If it doesn't fit return it before you scratch it up trying to make it work.
    Charlie Stephens
    Frank Balsama likes this.
  21. Following along, looks great so far!
  22. jt1949
    jt1949
    Good to know... thank you
  23. jt1949
    jt1949
    Hoping that wont be a problem with the hairpins that i have. But good to know. Thank you.
  24. jt1949
    jt1949
    Got the body back on last night
    CoolYourJets likes this.
  25. CoolYourJets
    CoolYourJets
    I like how you did that motor mount. My setup is much like yours, but there isn't much room for the mount.
    It clears, but with only a few mm to spare.
    One thing I have are pretty large rubber mount pads to help minimize vibration from the 4-banger.
    jt1949 and RoddyB34 like this.
  26. CoolYourJets
    CoolYourJets
    Are you going to be able to keep the rumble seat in the back? Or is that too "grandpa"? I love mine. It adds a flair to the car that everyone wants to see.
  27. jt1949
    jt1949
    Definitely keeping it. :)
  28. jt1949
    jt1949
    Looks awesome! Post more pic of your motor pls. Love to see more ideas.
  29. flynbrian48
    flynbrian48
    From a grampa: when you kick all that "grampa" off it, make sure not too much of the dumb kid shows, OK? [emoji12] ImageUploadedByH.A.M.B.1492794423.387212.jpg
  30. jt1949
    jt1949
    Haha... for sure! Im keeping the rumble seat...
