My 41 Chevy P/U Build
Discussion in 'Off Topic Hot Rods & Customs' started by swade41, Jan 9, 2010.
  1. Dooley
    Dooley
    from Buffalo NY
    looks great
    swade41 likes this.
  2. swade41
    swade41
    from Buffalo,NY
    Frame work done and it tilts smoothly 20160831_172425.jpg 20160831_172352.jpg
  3. swade41
    swade41
    from Buffalo,NY
    After a 23 year lapse I took this rig on it's maiden voyage and made it back home too. The convertor seems loose, spinning more rpms than it should mathematically at 45-50mph but the temperature was good in the 180-190 range.
    It sure sets you back in the seat when you nail it at 50mph ! 20160905_191640.jpg 20160905_191700.jpg
    Dooley likes this.
  4. Dooley
    Dooley
    from Buffalo NY
    Bad ***!
    truck looks really nice, bet it moves really good too
  5. Fullfendered
    Fullfendered
  6. nunattax
    nunattax
    much better now inmo the early chevy pu s to the art deco model are the best looking pu s ever
  7. swade41
    swade41
    from Buffalo,NY
    I took the truck to my pacemaker reading this morning, it looks small when compared to modern trucks, got the "click" at the solenoid 45 minutes later when it was time to leave. This is the second time now, cables all look good, battery fully charged and only puts out 14 volts on the gauge after the jump. I'm going to take the NAPA starter from the Henry J and put it on and wait and see what happens, I currently have a mini starter on this thing.
    I've also hit a couple cruise nights with it with temps creeping to the 210 mark while stuck in traffic, seems to drive fine other than the loose convertor, power brakes work too. The exhaust hits hard and people look when it comes rolling by, they seem to like that engine as much as I do when the front is tilted forward....lol truckVA.jpg truckdrive.jpg truckcruise.jpg
    Dooley and LOST ANGEL like this.
  8. swade41
    swade41
    from Buffalo,NY
    LOST ANGEL and henryj1951 like this.
  9. henryj1951
    henryj1951
    from USA
    boolya
    translation ---> bad@$$
    swade41 likes this.
  10. swade41
    swade41
    from Buffalo,NY
    I took out the weeping plastic flat bottom fuel cell and replaced it with an aluminum cell with a sump and bigger AN fittings. As always these projects turn into more work than expected like cutting the bed floor, cutting and dropping rear frame crossmember, cutting rear bed cross seal for AN fitting clearanc, making new hold down straps and making new lines up. 20170215_141937.jpg 20170215_142302.jpg 20170219_172335.jpg 20170228_170941.jpg 20170310_163515.jpg 20170418_154647.jpg
  11. swade41
    swade41
    from Buffalo,NY
    I also had another annoying problem with the lower V groove pulley the lower blower pulley was bolted to. It was hand drilled and drilled a little off center at that, you could see a little Getty up in the V belt and only ***ume blower belt had one too.
    The Blower Shop hooked me up with the correct pulley which was also a little smaller which should speed up my water pump, bonus. All back together and comptimplating changing that torque convertor now. 20170421_133940.jpg 20170419_152154.jpg 20170419_152318.jpg
    Chucky and LOST ANGEL like this.
  12. swade41
    swade41
    from Buffalo,NY
    Procrastination is over, time to tackle the loose as a goose green FB_IMG_1496323583168.jpg FB_IMG_1496323590017.jpg FB_IMG_1496323599593.jpg FB_IMG_1496323617027.jpg FB_IMG_1496323627298.jpg convertor !
    I figure a little a day shouldn't beat me up to bad, over a 3 day period I got it out and felt pretty good, 2 days later I'm at the chiropractor, si joint and floating rib out of place...lol
    It turns out the convertor was spragless, no anti-ballooning plate, torch brazed with one fin practically burnt in half and the fins almost straight. No wonder it didn't work to good on the street with shifts like mush ! I had a new one built by Compe***ion Transmission a local racer owned shop, he reviewed the dyno sheets and delivered the product yesterday.
    Now to reverse the procedure and see if it can better transfer the 750+ ft lbs of torque on this beast.
    Dooley and LOU WELLS like this.
  13. swade41
    swade41
    from Buffalo,NY
    20160814_164347_zpsm3kgnyba.jpg 20170919_135417.jpg FB_IMG_1507745769135.jpg FB_IMG_1507745779709.jpg FB_IMG_1507745795600.jpg FB_IMG_1507745822516.jpg Smoothing the fenders of the headlight bucket indentations, coming up with a compound curve backer was a bit of a challenge.
  14. swade41
    swade41
    from Buffalo,NY
    I hate body work but stuck with it to finish them off, pretty happy with it. 20171004_144754.jpg 20171009_131519.jpg 20171009_131529.jpg 20171009_131556.jpg
    Chavezk21 likes this.
  15. swade41
    swade41
    from Buffalo,NY
    Cut open the surfer scoop and reformed that too to hold two 6x3 filters and sit just right out of the hood. FB_IMG_1507746487427.jpg FB_IMG_1507746496236.jpg FB_IMG_1507746503367.jpg FB_IMG_1507746509030.jpg FB_IMG_1507746516164.jpg FB_IMG_1507746522907.jpg FB_IMG_1507746533492.jpg FB_IMG_1507746538719.jpg FB_IMG_1507746560346.jpg
  16. Dooley
    Dooley
    from Buffalo NY
    looks good, getting good with the gl***,,,lol
    swade41 likes this.
  17. swade41
    swade41
    from Buffalo,NY
    One more little section to make, filling in part of the hole that I cut for the other scoops. 20171010_180042.jpg 20171010_180113.jpg
    SS327 and LOST ANGEL like this.
  18. Dooley
    Dooley
    from Buffalo NY
    looking very sharp coming together nice!
  19. swade41
    swade41
    from Buffalo,NY
    Gl***ed in and ready for filler, oh the joy of body work..lol 20171013_171804.jpg
  20. Dooley
    Dooley
    from Buffalo NY
    Will you go tiger hair then filler?
  21. swade41
    swade41
    from Buffalo,NY
    Short strand (Nice and waterproof), then gold 20171014_115534.jpg 20171014_115602.jpg
  22. Dooley
    Dooley
    from Buffalo NY
    Nice
    I used both and they work good when I redid my rumble lid
    swade41 likes this.
  23. swade41
    swade41
    from Buffalo,NY
  24. swade41
    swade41
    from Buffalo,NY
    Painted the fenders and gave it a bath, I would like to go hidden headlights on this thing, really like the look. 20171022_180726.jpg 20171022_180734.jpg 20171022_180807.jpg
    LOST ANGEL and Dooley like this.
  25. Dooley
    Dooley
    from Buffalo NY
    Damn...like it
    swade41 likes this.
  26. swade41
    swade41
    from Buffalo,NY
    Since we have this off topic side of things I figure I might update this forgotten thread.
    I never did do the hidden headlights but kept them up top on the 1940 headlight stands.
    It was running pretty good so I just drove it without any major changes for a couple yrs.
    I found a 40 to compare notes with at one show, I've altered everything on this truck except the cowl.
    SS327, Dooley and chevy57dude like this.
  27. swade41
    swade41
    from Buffalo,NY
    In 2019 I decided to fix an oil leak at the front China wall, it was small and at first I thought it was coming from the blower.
    20190619_150705.jpg 20190619_151511.jpg 20190619_151658.jpg 20190619_154225.jpg
    Gasket looked like it was leaking and there was some fuel in the pockets of the intake.
  28. swade41
    swade41
    from Buffalo,NY
    It was about this time that I became my own worst enemy on only fixing a small oil leak.
    If you remember back I was originally going to do a 496 so this 6-71 on the 540 always kind of bugged me as being to small and inefficient. So I decided to get an 8-71 and preferably a vintage Mooneyham.
    I find one on marketplace and bought it, but what showed up wasn't what it was.
    Front discharge delta and was actually a 6-71, the seller honestly didn't know and issued a refund.
    20190715_172726.jpg Screenshot_20190709-223137_Facebook.jpg Screenshot_20190709-223212_Facebook.jpg
    SS327 and chevy57dude like this.
  29. chevy57dude
    chevy57dude
    Glad he made it right. Cool blower, though!
    swade41 likes this.
  30. swade41
    swade41
    from Buffalo,NY
    The search is on again and luckily I find this beautiful stripped, anodized 8-71 and make a deal on it
    Guy lines the box with plywood and foam and this is how UPS wants to deliver it
    It had gotten dropped somewhere along the line and broke the case, I refused the delivery and started the hunt all over again.
    SS327 likes this.
