Technical How to build a 1932 Ford frame
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Sep 13, 2016.
  1. edwardlloyd
    edwardlloyd
    from Germany
    Now I've done a few tech articles before on how to build these. It isn't easy, but if you're building a traditional roadster and haven't got an original frame, or your rod has had some reproduction boxed TCI style frame slipped under it at one time or another, this is the route you need to go.
    I decided to picture this frame because this one in particular has just about all the go faster options.
    ASC Rails with all side and top holes drilled the right size and in the right place.
    Model-A front crossmember modified to fit a '32.
    Mercury motor mounts
    1932 Ford K-member
    Strengthening legs from Industrial Ch***is
    Kick-up strengtheners
    Model-A rear crossmember modified to fit the '32 frame.
    This frame is now twice as rigid as a stock frame, which still isn't anywhere near as rigid as a boxed frame but this is for a flathead, right! DSCN1141.JPG DSCN1144.JPG DSCN1145.JPG DSCN1148.JPG DSCN1149.JPG DSCN1150.JPG DSCN1152.JPG DSCN1153.JPG DSCN1154.JPG DSCN1156.JPG DSCN1157.JPG
  2. hotcoupe
    hotcoupe
    FACTORY!
    kidcampbell71 likes this.
  3. alchemy
    alchemy
    What are the motor mounts from? And you should also add the dip under the cowl band, since the rest of the ch***is looks so legit.
    Nice.
  4. edwardlloyd
    edwardlloyd
    from Germany
    Mounts are 1940s Mercury. Can be cut and shaped to fit without any welding.
  5. MAD 034
    MAD 034
    from Washington
    I like it a lot! Rivets give it that correct look we all like.
  6. Texas Webb
    Texas Webb
  7. X38
    X38
    Thinking the same. Also, is there a reason why you riveted everything except the IC rear leg parts?
    It's good to see a frame like that.
  8. Nice work.
    Al.
    OZY DEUCE likes this.
  9. adam401
    adam401
    Very clean. I love the use of the factory mounts and riveted construction. Awesome when all the components look like they were born together.
  10. edwardlloyd
    edwardlloyd
    from Germany
    The IC parts are not Ford. If you bolt them in they remain bolt on modifications not permanent ones. It's a legal issue here regarding registration laws.
    Andrew Jordan and stillrunners like this.
  11. X38
    X38
    O.k. thanks. That's interesting.
  12. Barnmiester
    Barnmiester
    from wyoming
  13. alchemy
    alchemy
    What's he think of the ASC rails? Glad we don't have to deal with that over here.
  14. Malcolm
    Malcolm
    from Nebraska
    Very nice work!
    Yes, I was wondering the same --- do you just stamp a VIN and call them original Ford?
  15. Dan
    Dan
    Very cool!
    Your driveway makes me dizzy though :)
  16. edwardlloyd
    edwardlloyd
    from Germany
    No. Replacing the rails is legal. Adding or modifying the frame is where it gets difficult. If you crash a 2005 Mercedes Benz, it's legal to replace the front clip with new parts. Pattern reproductions are legal too. Same in the US as here. Go welding in structural parts to that body shell and you're going to get into trouble in most places as it won't be type approved anymore.
  17. Matt Spencer
    Matt Spencer
    where can I get the 1940s Mercury motor mounts?
    Thanks Matt
  18. Fortunateson
    Fortunateson
    Where did you get the rear kick up reinforcements?
  19. brady1929
    brady1929
  20. warhorseracing
    warhorseracing
    from cameron wv
    Beautiful work and detail.
  21. edwardlloyd
    edwardlloyd
    from Germany
    Make them myself.
    Sent from my SM-G935F using The H.A.M.B. mobile app
  22. edwardlloyd
    edwardlloyd
    from Germany
    Hard to find these days. From 1940s Mercurys being parted out.
  23. Fortunateson
    Fortunateson
    I hank you. Do you have pics or can you describe the process?
