Hot Rods Engine turning or Damascening
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Sep 14, 2016.
  1. lothiandon1940
    lothiandon1940
    I love the sight of engine turned panels. It creates a cl***ic look of old world craftsmanship. This is just my crummy aftermarket gauge panel in my Roadster. Show us your work or any engine turning you may have seen and couldn't resist taking a picture. Don't limit it to gauge panels.:) 20160914_152236.jpg
  2. Deuced Up!
    Deuced Up!
  3. Dino 64
    Dino 64
    from Virginia
    Sure didn't look ****ppy to me when I saw it ![​IMG]
  4. There are several great threads if you do a search.
    osage orange and lothiandon1940 like this.
  5. lothiandon1940
    lothiandon1940
    .................You're too kind.
  6. buck 32
    buck 32
    from Maryland
    Nothing crummy about that. Cl***ic simple never out of style look.
  7. mike bowling
    mike bowling
    #1- rear spring cover-'31 roadster (sold)
    #2- dash panel- '30 Tudor sedan
    #3- gas tank straps- '30 coupe-
    #4- dash panel, switch panel, and column drop - '30 coupe
    All done on a drill press - I'm a big fan of engine turning ( and louvers)
    All cars have new owners; on to the next one.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I haven't tried damascening but I have done some engine turning. HRP
    lothiandon1940 likes this.
  9. mcmopar
    mcmopar
    from Strum, wi
    I haven't done it yet, but I sure like the look of it also. I like the look on old lettering with gold leaf.
    Tony
    HOTRODPRIMER and lothiandon1940 like this.
  10. lothiandon1940
    lothiandon1940
    Gold leaf is way cool.
    HOTRODPRIMER and lothianwilly71 like this.
  11. lothiandon1940
    lothiandon1940
  12. 56don
    56don
    SoCal panel.JPG Its hard to tell in this photo, but the panel is engine turned black anodized.
  13. lothianwilly71
    lothianwilly71
    They all look great guy`s keep up the good work.
  14. HOTRODPRIMER
    HOTRODPRIMER
    The 1954 Ford's had a engine turned aluminum panel as original equipment.
    When I decided I wanted to modify the dash in the wagon to install gauges I knew I had a lot of work ahead of me but I still wanted to retain the beauty of the original engine turned panel.
    I did a lot of cutting on the dash to accommodate the gauges and then made a poster board template to make a new insert to fit the original panel.
    I then made the panel. HRP
    72yenkonova, kiwijeff, 504640 and 7 others like this.
  15. big duece
    big duece
    from kansas
    This started out as a piece of 1/8" stainless.
  16. Pat Thompson
    Pat Thompson
    I use a Bridgeport with a screw on scotch rite round disc. Come down and let it touch and then move over a determined amount. really not that hard once you get the pattern started.
  17. David Gersic
    David Gersic
    from DeKalb, IL
  18. Bandit Billy
    Bandit Billy
    One trick I learned was to use a wood dowel chucked up in the mill and glue hook velcro to it. Then buy the velcro backed abrasive discs and punch circles out if to fit the dowel. It makes changing the abrasive quick and easy.
  19. hotcoupe
    hotcoupe
    `33 instrument panel, nickel plated, engine turned, then chrome plated. engine turning nickel is the hard part.
    tom
  20. Fortunateson
    Fortunateson
    That panel should be on display at Tiffany's! Beautiful.
  21. roseville carl
    roseville carl
  22. lothiandon1940
    lothiandon1940
    Beautiful work, guys. Thanks for posting the pictures.
  23. Petejoe
    Petejoe
  24. hotcoupe
    hotcoupe
    thanx for the positive comments. this is a `32 panel, i used a computer generated Asymmetric grid to duplicate the original Ford produced pattern. again copper plate, nickel plate, engine turned, and then chrome plate. it is hard to photograph with reflections going every which way, but the pattern lines up every way you turn it.
    tom
  25. ClayMart
    ClayMart
    Thanks! That throws a lot of new light on the subject. The examples shown in the posts above would more accurately be described as "spotting" than "engine turning". Some other beautiful finishing techniques illustrated in the article as well. :cool:
    osage orange likes this.
  26. Devoz
    Devoz
    This puzzles me....it seems chroming over the turnings would cover them. I had to dig up a piece I own that was supposedly done by Eamonn Keogh, it's chromed, the turnings look beautiful and are smooth to the touch like plain chrome. I always thought the turning was done after chrome. Learn something new everyday!
  27. dechrome
    dechrome
    Aluminum dash on the sprintcar.
  28. seb fontana
    seb fontana
    from ct
  29. Runnin shine
    Runnin shine
    My personal favorite as it started my infatuation with the stuff
